    Solved: Jogging past axis limits..?
    CNC
    1.6k
    • Nightowlundefined
      Nightowl @jay_s_uk
      I did that, @jay_s_uk, but then the endstops didn't activate, but I'll try (anything) again!
      UPDATE: Now I get the G0/G1: target position outside machine limits when I try to move any axis. The proximity sensors do work, though!
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        jay_s_uk @Nightowl
        @nightowl999 you'll need to do the same with your Z endstop too.
        There's also no need to include M564 as S1 H1 are the default setup
        Nightowlundefined 1 Reply Last reply Reply Quote 1
        • Nightowlundefined
          Nightowl @jay_s_uk
          I'm in the process of doing that now, @jay_s_uk, but won't I still have the same problem?
            jay_s_uk @Nightowl
            @nightowl999 not if you're jogging to the -ve once homed
            • Nightowlundefined
              Nightowl @jay_s_uk
              Blinkin' 'eck, @jay_s_uk, you've only gone and sorted it!
              The only thing, and I might just have to get used to this, is that the machine home coordinates are back to the maxima values, rather than 0, 0, 0 I was hoping to achieve.
              I don't care any more 😊 😊 . It's not as if the machine co-ordinates really matter with a CNC, as the starting point of the work being cut is more important!
                jay_s_uk @Nightowl
                @nightowl999 exactly. Typically front left is 0,0. Ideally you want it there as otherwise whatever you're cutting is the opposite way it appears on screen.
                Homing to max is perfectly fine.
                If you did want to flip it the other way you'd have to change your M574s back, flip the move direction in M569 and rewrite your homing files to move towards the minima rather than the maxima
                Nightowlundefined 1 Reply Last reply Reply Quote 0
                • Nightowlundefined
                  Nightowl @jay_s_uk
                  Thanks, @jay_s_uk. I think it's time I started doing stuff, rather than messing about!
                  Talking of homing... Because I can't really reach the back of the machine when it's homed, I temporarily REM'd out the lines relating to the Y axes in the homeall.g file. But, it still homed the Y axes.
                  Does the Home All button on the dashboard run the homeall.g file, or the individual home files?
                  jay_s_ukundefined sinned6915undefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @Nightowl
                    @nightowl999 homeall but if a certain axis isn't there, it then calls the homing file for that axis, unless they're hidden
                    • Nightowlundefined
                      Nightowl @jay_s_uk
                      Well, I don't know who had that foresight, @jay_s_uk, but that would explain the magical event 😄 😄
                      I really appreciate the help, thank you.
                      • sinned6915undefined
                        sinned6915 @Nightowl
                        @nightowl999 said in Solved: Jogging past axis limits..?:
                        That will leave a bruise if your don't sort this out!
                        Did you follow the basic comissioning procedure that it outlined in the docs?
                        https://docs.duet3d.com/en/How_to_guides/Commissioning#h-7-check-endstops
                        Its really straight forward to to take it step by step
                        If you do it 'half-way' then it WILL come back to haunt you someday. DAMHIKT!
                        • Nightowlundefined
                          Nightowl @sinned6915
                          @sinned6915 said in Solved: Jogging past axis limits..?:
                          Yeah, I followed those instructions closely, but it's in changing things to suit my situation that made it difficult (in my mind, anyway), and trying to keep track of incremental changes is a bit challenging.
                          I believe this is sorted now, so apart from one or two other capabilities I want to integrate into the system (using an old Carbide3D touch probe, install a power fail/resurrect ability and install an externally switched feed hold (pause/resume) facility, I'm almost ready to cut stuff!
                          sinned6915undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                            Carbide3D
                            I am in the middle of comissioning a mill right now too. I understand what you are going through.
                            GOOD LUCK!
                            • fcwiltundefined
                              fcwilt @Nightowl
                              Would you post a picture or two of your mill?
                              Nightowlundefined 2 Replies Last reply Reply Quote 0
                              • Nightowlundefined
                                Nightowl @fcwilt
                                Sure, @fcwilt, but I’ll do it tomorrow 🥱😴😴
                                • Nightowlundefined
                                  Nightowl @fcwilt
                                  Not sure if this is what you wanted, @fcwilt, but here you go:
                                  The machine is a RatRig 1075 KillerBee, although I've made a few amendments to the supplied machine, including using 4x proximity sensors instead of limit switches, and redesigned the spoil board supports. It has a Duet 3 MB6HC control board (as you already know!) connected via a wired network to a Microsoft Surface Pro.
                                  Most of my work is done on my iMac, which is in the house, so I connect to the Surface Pro and the Duet via a wired network using powerline adapters.
                                  Apart from my own knowledge limits, everything seems to work well - but the proof will be when I eventually make something!
                                  fcwiltundefined 1 Reply Last reply Reply Quote 2
                                  • fcwiltundefined
                                    fcwilt @Nightowl
                                    @nightowl999
                                    Thanks for the pictures.
                                    • droftartsundefined droftarts marked this topic as a question
                                    • droftartsundefined droftarts has marked this topic as solved
