    Solved: Jogging past axis limits..?
    CNC
    1.7k
    • Nightowlundefined
      Nightowl @jay_s_uk
      Thanks, @jay_s_uk. I think it's time I started doing stuff, rather than messing about!
      Talking of homing... Because I can't really reach the back of the machine when it's homed, I temporarily REM'd out the lines relating to the Y axes in the homeall.g file. But, it still homed the Y axes.
      Does the Home All button on the dashboard run the homeall.g file, or the individual home files?
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      jay_s_ukundefined sinned6915undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Nightowl
        @nightowl999 homeall but if a certain axis isn't there, it then calls the homing file for that axis, unless they're hidden
        Nightowlundefined 1 Reply Last reply Reply Quote 0
        • Nightowlundefined
          Nightowl @jay_s_uk
          Well, I don't know who had that foresight, @jay_s_uk, but that would explain the magical event 😄 😄
          I really appreciate the help, thank you.
          • sinned6915undefined
            sinned6915 @Nightowl
            @nightowl999 said in Solved: Jogging past axis limits..?:
            That will leave a bruise if your don't sort this out!
            Did you follow the basic comissioning procedure that it outlined in the docs?
            https://docs.duet3d.com/en/How_to_guides/Commissioning#h-7-check-endstops
            Its really straight forward to to take it step by step
            If you do it 'half-way' then it WILL come back to haunt you someday. DAMHIKT!
            • Nightowlundefined
              Nightowl @sinned6915
              @sinned6915 said in Solved: Jogging past axis limits..?:
              Yeah, I followed those instructions closely, but it's in changing things to suit my situation that made it difficult (in my mind, anyway), and trying to keep track of incremental changes is a bit challenging.
              I believe this is sorted now, so apart from one or two other capabilities I want to integrate into the system (using an old Carbide3D touch probe, install a power fail/resurrect ability and install an externally switched feed hold (pause/resume) facility, I'm almost ready to cut stuff!
              sinned6915undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                Carbide3D
                I am in the middle of comissioning a mill right now too. I understand what you are going through.
                GOOD LUCK!
                • fcwiltundefined
                  fcwilt @Nightowl
                  Would you post a picture or two of your mill?
                  Nightowlundefined 2 Replies Last reply Reply Quote 0
                  • Nightowlundefined
                    Nightowl @fcwilt
                    Sure, @fcwilt, but I’ll do it tomorrow 🥱😴😴
                    • Nightowlundefined
                      Nightowl @fcwilt
                      Not sure if this is what you wanted, @fcwilt, but here you go:
                      The machine is a RatRig 1075 KillerBee, although I've made a few amendments to the supplied machine, including using 4x proximity sensors instead of limit switches, and redesigned the spoil board supports. It has a Duet 3 MB6HC control board (as you already know!) connected via a wired network to a Microsoft Surface Pro.
                      Most of my work is done on my iMac, which is in the house, so I connect to the Surface Pro and the Duet via a wired network using powerline adapters.
                      Apart from my own knowledge limits, everything seems to work well - but the proof will be when I eventually make something!
                      fcwiltundefined 1 Reply Last reply Reply Quote 2
                      • fcwiltundefined
                        fcwilt @Nightowl
                        @nightowl999
                        Thanks for the pictures.
                        • droftartsundefined droftarts marked this topic as a question
                        • droftartsundefined droftarts has marked this topic as solved
