    Mo not working on E3D toolchanger with duet3
    • Cavemanundefined
      Caveman
      I have an issue. I have a toolchanger with duet 3 in sbc mode with raspberry pi and expansion board.
      After print is finished heaters stay on. In my slicer config is M0 at the end of end gcode.
      ;Drop Bed
      G91
      G1 Z10 F1000
      G90
      ; Drop off the tool
      T-1
      ; Disable Mesh Compensation.
      G29 S2
      ; Park
      G1 X-30 Y200 F50000
      ; Turn off all heaters
      M0
      What could cause this?
      • oliofundefined
        oliof
        There's a commit in the 3.5-dev tree that reintroduces "turn off all heaters on M0 if stop.g doesn't exist". Your short term solution is to add a stop.g in which you turn off the heaters.
        Cavemanundefined 1 Reply Last reply Reply Quote 0
        • Cavemanundefined
          Caveman @oliof
          @oliof thanks will do that.
            @caveman in RRF 3.4.0 the heaters should turn off anyway if there is no stop.g file. But if you do have a stop.g file, you need to turn the heaters off in it, if you want them off.
            • Cavemanundefined
              Caveman @dc42
              @dc42 this is my stop.g file
              ; stop.g
              ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
              M98 P"/macros/led_alert"
              ;Stop Printing (M0)
              G10 P0 S0; Turn off extruder heater
              M140 S0; Turn off bed heater
              M300 S100 P500; Sound beep using PanelDue buzzer, frequency Hz (Snn), Duration (Pnn)
              I am not entirerly sure if this is right for e3d toolchanger
