    Is this normal? PSU unsteady
    1.3k
    • Martin_Sundefined
      Martin_S
      Today I recieved a brand new chinese 24v power supply.
      The first thing I did was to test the output voltage, but it fluctuates a bit.
      Is this normal? or should I ask for another one?
      https://www.youtube.com/watch?v=Zai0dftsl40&feature=youtu.be
      Thanks in advance.
      Martin
      If it ain't broke, fix it till it is =)
      • number40fanundefined
        number40fan
        Is it fair to test Chinese stuff with other Chinese stuff? 😄 I'd run it under a load and see what you get, even if just a light load.
        • Martin_Sundefined
          Martin_S
          I'm currently thinking what to connect. I've some 24v fans but they won't draw much power.
            number40fan
            Shouldn't take much. Just something to give it a load.
            • Martin_Sundefined
              Martin_S
              Indeed my good sir. I connected the Duet and in stand by mode the readings are stable.
              Thank you for the help.
              Case closed 😛
              • fmaundefined
                fma
                Don't be fooled by the measure: I think your multi-meter have a 0.2V resolution as many, and the voltage is just at the edge, so very small variations make the voltmeter switch +-0.2V… I don't think the power supply really change that much.
                Frédéric
                • Martin_Sundefined
                  Martin_S
                  @fma:
                  I'm pretty sure that is stable with the load, it didn't fluctuate once. But yes, the resolution for measuring 24v is of ".0".
                  So as soon as I arrive home, I will dial it down to 19 volts and use the 20v range. With that one, the resolution is of ".00".
                  Either way, lets say the power supply didn't change much as you said.
                  Will this be an issue? Is this a symptom of a bad power supply or it's normal?
                  • fmaundefined
                    fma
                    The best way to check would be to use an oscilloscope. There is always a ripple, which should be given by the manufacturer. Usually, this ripple is fast, and you don't see it with a multimeter. As long as the period of the ripple is much higher than the thermal constant of heaters, I think it is not a problem.
                    Frédéric
                    • Martin_Sundefined
                      Martin_S
                      Hello Frédéric, thanks for the explanation, but I don't have access to such tool.
                      It was dialed down to 19.8v and it changes from 19.83v to 19.84 at much slower rates. It doesn't seems like a problem, but well I'm no expert here.
                      https://www.youtube.com/watch?v=RD8l8qHkiro&feature=youtu.be
                      Thanks for the help.
                      • fmaundefined
                        fma
                        Again, you may be at 19.835V, so your multimeter oscillate between 19.83V and 19.84V. Also keep in mind that real voltage is maybe 20.12V, 18.83V, 19.52V or anything else, as your multimeter is probably not calibrated.
                        Frédéric
                          T3P3Tony administrators
                          Martin, It looks fine. If you have your printer setup so you can load it with the full heaters on (or an equivalent load) then check. You may see a small amount of voltage sag between full power and almost no load but that is not a generally a problem.
                          • Martin_Sundefined
                            Martin_S
                            I know it's not a Meanwell PSU so I won't expect the same performance.
                            Tested it under motor load and the oscilation is practically none. Yes…. with this cheap multimeter. It's not the best way but I can't afford an oscilloscope or a more professional calibrated multimeter.
                            My concern was if I had to ask for a refund/return or to confirm the transaction.
                            I've already did the last one.
                            Thank you all for the help and have a nice weekend.
                            I will for sure stay at home nerding with the CoreXY build 😛
