No function after update
Hello.
Extrusion Control does not work after the update.
Compensation & Calibration doesn't work either
Turning on the translation into Polish suspends the viewing of temperatures.
M122
RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode) -
3.4.1 is in the pre-release stage - perhaps it mentions some of the issues you are facing.
@wladekcz which firmware version were you running previously?
Have you checked that you are also running version 3.4.0 of DWC?
@wladekcz said in No function after update:
It's most likely that the tool isn't selected. Do you have a
T0
in your config.g?@wladekcz said in No function after update:
What exactly doesn't work? Can you be more specific?
Perhaps you should try uploading the full 3.4 zip file to the system tab in DWC to ensure everything is actually up to date.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
Hello. Previously, I was using software 3.3. Once again, I installed 3.4 zip via WD. The effect is the same. I'm sending a video showing the problems. https://1drv.ms/v/s!Ahan8cAuwVYih94ZoeZSctyYY6vCTQ?e=7CWDLl
Please post the contents of your config.g and bed.g files.
The extrude and retract buttons not being active may mean you don't have an extruder drive assigned to the tool.
The true bed leveling G32 not running may mean you don't actually have a bed.g file created.
Not sure what is happening with the temperature display when translation is in effect. It does seem to jump. Perhaps @chrishamm could take a look at that.
@wladekcz You should not use Google Translate to translate DWC, it's better to go to Settings -> General and to select Polish there - else the web interface appears to freeze as you could observe.
Can you confirm that you have DWC 3.4.0 installed as well (check on Settings -> General)? It's hard to tell if the malfunction is caused by the external translation service but if it perists after a fresh reload (without Google Translate), please press F12, go to the JS console, and post the log here. Perhaps DWC fails to parse something from the object model.
Was that what it was about?
chrome-extension://ihcjicgdanjaechkgeegckofjjedodee/content-scripts.js
After selecting the Polish language in the settings, you can see the temperature. There is no change under the tools with the heater on and off. The inscription in English OFF regardless of its condition.
WDC 3,4,0
@wladekcz Looks like a Chrome extension so nothing caused by DWC. Please try another browser and check if the problem persists. If it does, please share your homeall.g as well.
; Configuration file for Duet 3 (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 21 2022 10:03:29 GMT+0200 (czas środkowoeuropejski letni) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Duet3" ; set printer name M669 K1 ; select CoreXY mode ; Wait a moment for the CAN expansion boards to start G4 S2 ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 ; physical drive 0.0 goes backwards M569 P0.2 S0 ; physical drive 0.2 goes backwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M569 P0.4 S1 ; physical drive 0.4 goes forwards M584 X0.0 Y0.2 Z0.3 E0.4 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z407.00 E1168.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X330 Y330 Z370 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io2.in M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M558 P1 C"!io7.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X19 Y5 Z2.26 ; set Z probe trigger value, offset and trigger height M557 X30:280 Y30:280 S30 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B5438 C1.335272e-7 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp3" Y"thermistor" T100000 B5438 C1.335272e-7 ; configure sensor 1 as thermistor on pin temp3 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C M308 S2 P"1.temp1" Y"thermistor" T9400 B5438 C1.335272e-7 ; configure sensor 2 as thermistor on pin 1.temp1 M950 H2 C"out2" T2 ; create chamber heater output on out2 and map it to sensor 2 M307 H2 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit M141 H2 ; map chamber to heater 2 M143 H2 S60 ; set temperature limit for heater 2 to 60C ; Fans M950 F0 C"out9" Q500 ; create fan 0 on pin out9 and set its frequency M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency M106 P2 S1 H2:1 T45 ; set fan 2 value. Thermostatic control is turned on M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency M106 P3 S1 H1 T40 ; set fan 3 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M912 P0 S-17 ;Kalibracja temperatury MCU ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S20 R21 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
Can you please try adding
T0
to the end of your config.g to see if it will allow you to extrude when the hotend is at temp.; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 21 2022 10:03:29 GMT+0200 (czas środkowoeuropejski letni) M561 ; clear any bed transform G29 ; probe the bed and enable compensation
Do you have a mesh.g file in your system folder?
When you choose "True Bed Leveling (G32)" from the drop down, what are you expecting to happen?
Selecting that drop down item will call bed.g, which in your case, only contains a call for G29 which itself just runs mesh.g.
What do you want it to do?
@phaedrux said in No function after update:
M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned onThis M106 line should be
M106 P0 S0 H-1
Can you also send M122 and M98 P"config.g" and post the results here?
M98 P"config.g"
In the old version, pressing G32 would start probing the table.
Give me an example of how T0 should look like.
The printer prints models, but it is not possible to withdraw or load the filament. -
Should it be like that?
Edit your bed.g and change the
G29
command toG29 S1
and see if that makes a difference for you. Make sure the axis are homed first.@wladekcz said in No function after update:
T0
Nothing more. -
T0 at the end of G-config helped. You can control the filament in the Extrusion Control window.
Changing the browser to Edge eliminated the problem with viewing the temperature. Thank you for your help.
