    No function after update
    Firmware installation
    731
      dc42 administrators @Wladekcz
      @wladekcz which firmware version were you running previously?
      Have you checked that you are also running version 3.4.0 of DWC?
        Phaedrux Moderator @Wladekcz
        @wladekcz said in No function after update:
        Extrusion Control does not work after the update.
        It's most likely that the tool isn't selected. Do you have a T0 in your config.g?
        Compensation & Calibration doesn't work either
        What exactly doesn't work? Can you be more specific?
        Perhaps you should try uploading the full 3.4 zip file to the system tab in DWC to ensure everything is actually up to date.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
        • Wladekczundefined
          Wladekcz
          Hello. Previously, I was using software 3.3. Once again, I installed 3.4 zip via WD. The effect is the same. I'm sending a video showing the problems. https://1drv.ms/v/s!Ahan8cAuwVYih94ZoeZSctyYY6vCTQ?e=7CWDLl
          Władekcz
            Please post the contents of your config.g and bed.g files.
            The extrude and retract buttons not being active may mean you don't have an extruder drive assigned to the tool.
            The true bed leveling G32 not running may mean you don't actually have a bed.g file created.
            Not sure what is happening with the temperature display when translation is in effect. It does seem to jump. Perhaps @chrishamm could take a look at that.
            • Wladekczundefined
              Wladekcz
              I'm sending config.g and bed.g
              Please check what I broke.config.g bed.g
              Władekcz
              • chrishammundefined
                chrishamm administrators @Wladekcz
                @wladekcz You should not use Google Translate to translate DWC, it's better to go to Settings -> General and to select Polish there - else the web interface appears to freeze as you could observe.
                Can you confirm that you have DWC 3.4.0 installed as well (check on Settings -> General)? It's hard to tell if the malfunction is caused by the external translation service but if it perists after a fresh reload (without Google Translate), please press F12, go to the JS console, and post the log here. Perhaps DWC fails to parse something from the object model.
                Duet software engineer
                • Wladekczundefined
                  Wladekcz
                  Was that what it was about?
                  chrome-extension://ihcjicgdanjaechkgeegckofjjedodee/content-scripts.js
                  Władekcz
                  • Wladekczundefined
                    Wladekcz
                    After selecting the Polish language in the settings, you can see the temperature. There is no change under the tools with the heater on and off. The inscription in English OFF regardless of its condition.
                    Władekcz
                    • Wladekczundefined
                      Wladekcz
                      WDC 3,4,0
                      Władekcz
                      • Wladekczundefined
                        Wladekcz
                        content-scripts.txt
                        Władekcz
                          @wladekcz Looks like a Chrome extension so nothing caused by DWC. Please try another browser and check if the problem persists. If it does, please share your homeall.g as well.
                            ; Configuration file for Duet 3 (firmware version 3.3)
                            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 21 2022 10:03:29 GMT+0200 (czas środkowoeuropejski letni)
                            M575 P1 S1 B57600                                         ; enable support for PanelDue
                            G90                                                       ; send absolute coordinates...
                            M83                                                       ; ...but relative extruder moves
                            M550 P"My Duet3"                                          ; set printer name
                            M669 K1                                                   ; select CoreXY mode
                            ; Wait a moment for the CAN expansion boards to start
                            G4 S2
                            M552 P0.0.0.0 S1                                          ; enable network and acquire dynamic address via DHCP
                            M586 P0 S1                                                ; enable HTTP
                            M586 P1 S0                                                ; disable FTP
                            M586 P2 S0                                                ; disable Telnet
                            M569 P0.0 S0                                              ; physical drive 0.0 goes backwards
                            M569 P0.2 S0                                              ; physical drive 0.2 goes backwards
                            M569 P0.3 S1                                              ; physical drive 0.3 goes forwards
                            M569 P0.4 S1                                              ; physical drive 0.4 goes forwards
                            M584 X0.0 Y0.2 Z0.3 E0.4                                  ; set drive mapping
                            M350 X16 Y16 Z16 E16 I1                                   ; configure microstepping with interpolation
                            M92 X80.00 Y80.00 Z407.00 E1168.00                        ; set steps per mm
                            M566 X900.00 Y900.00 Z60.00 E120.00                       ; set maximum instantaneous speed changes (mm/min)
                            M203 X6000.00 Y6000.00 Z180.00 E1200.00                   ; set maximum speeds (mm/min)
                            M201 X500.00 Y500.00 Z20.00 E250.00                       ; set accelerations (mm/s^2)
                            M906 X800 Y800 Z800 E800 I30                              ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30                                                   ; Set idle timeout
                            M208 X0 Y0 Z0 S1                                          ; set axis minima
                            M208 X330 Y330 Z370 S0                                    ; set axis maxima
                            M574 X1 S1 P"io2.in"                                      ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io2.in
                            M574 Y1 S1 P"io1.in"                                      ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
                            M574 Z1 S2                                                ; configure Z-probe endstop for low end on Z
                            M558 P1 C"!io7.in" H5 F120 T6000                          ; set Z probe type to unmodulated and the dive height + speeds
                            G31 P500 X19 Y5 Z2.26                                    ; set Z probe trigger value, offset and trigger height
                            M557 X30:280 Y30:280 S30                                  ; define mesh grid
                            M308 S0 P"temp0" Y"thermistor" T100000 B5438 C1.335272e-7 ; configure sensor 0 as thermistor on pin temp0
                            M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
                            M307 H0 B1 S1.00                                          ; enable bang-bang mode for the bed heater and set PWM limit
                            M140 H0                                                   ; map heated bed to heater 0
                            M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
                            M308 S1 P"temp3" Y"thermistor" T100000 B5438 C1.335272e-7 ; configure sensor 1 as thermistor on pin temp3
                            M950 H1 C"out1" T1                                        ; create nozzle heater output on out1 and map it to sensor 1
                            M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
                            M143 H1 S280                                              ; set temperature limit for heater 1 to 280C
                            M308 S2 P"1.temp1" Y"thermistor" T9400 B5438 C1.335272e-7 ; configure sensor 2 as thermistor on pin 1.temp1
                            M950 H2 C"out2" T2                                        ; create chamber heater output on out2 and map it to sensor 2
                            M307 H2 B1 S1.00                                          ; enable bang-bang mode for the chamber heater and set PWM limit
                            M141 H2                                                   ; map chamber to heater 2
                            M143 H2 S60                                               ; set temperature limit for heater 2 to 60C
                            M950 F0 C"out9" Q500                                      ; create fan 0 on pin out9 and set its frequency
                            M106 P0 S0 H T45                                          ; set fan 0 value. Thermostatic control is turned on
                            M950 F1 C"out4" Q500                                      ; create fan 1 on pin out4 and set its frequency
                            M106 P1 S1 H1 T45                                         ; set fan 1 value. Thermostatic control is turned on
                            M950 F2 C"out5" Q500                                      ; create fan 2 on pin out5 and set its frequency
                            M106 P2 S1 H2:1 T45                                       ; set fan 2 value. Thermostatic control is turned on
                            M950 F3 C"out7" Q500                                      ; create fan 3 on pin out7 and set its frequency
                            M106 P3 S1 H1 T40                                         ; set fan 3 value. Thermostatic control is turned on
                            M563 P0 D0 H1 F0                                          ; define tool 0
                            G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
                            G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
                            M912 P0 S-17											  ;Kalibracja temperatury MCU
                            M501                                                      ; load saved parameters from non-volatile memory
                            M911 S20 R21 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power loss
                            Can you please try adding T0 to the end of your config.g to see if it will allow you to extrude when the hotend is at temp.
                            ; bed.g
                            G29  ; probe the bed and enable compensation
                            Do you have a mesh.g file in your system folder?
                            When you choose "True Bed Leveling (G32)" from the drop down, what are you expecting to happen?
                            Selecting that drop down item will call bed.g, which in your case, only contains a call for G29 which itself just runs mesh.g.
                            What do you want it to do?
                              Phaedrux Moderator @Phaedrux
                              @phaedrux said in No function after update:
                              This M106 line should be M106 P0 S0 H-1
                              Can you also send M122 and M98 P"config.g" and post the results here?
                              • Wladekczundefined
                                Wladekcz
                                M98 P"config.g"
                                In the old version, pressing G32 would start probing the table.
                                Give me an example of how T0 should look like.
                                The printer prints models, but it is not possible to withdraw or load the filament.
                                M122.txt
                                M98.txt
                                homeall.g
                                Władekcz
                                • Wladekczundefined
                                  Wladekcz
                                  Should it be like that?
                                  config.g modyfikacja1.txt
                                  Władekcz
                                    Edit your bed.g and change the G29 command to G29 S1 and see if that makes a difference for you. Make sure the axis are homed first.
                                    T0 Nothing more.
                                    • Wladekczundefined
                                      Wladekcz
                                      T0 at the end of G-config helped. You can control the filament in the Extrusion Control window.
                                      Changing the browser to Edge eliminated the problem with viewing the temperature. Thank you for your help.
                                      Władekcz
