    New firmware 1.20beta1
    Firmware installation
    14
    34
    5.3k
      Thanks everyone for the feedback. Beta 1 is turning out to be very stable.
      • fmaundefined
        fma
        I just switched to this release yesterday, and my 2 prints worked fine.
        But I still have some AJAX errors (they have never been very frequent though).
        Frédéric
          @fma:
          Have you worked through https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors ?
          • fmaundefined
            fma
            Yes, but I could not improve things.
            As said, it does not occur very often; only during prints, but not on every print. It may be a external issue…
            I may try to switch to the ESP-07S (once the warranty has expired ;)).
            Frédéric
              I've added an item to that wiki page about a possible correlation with the temperature of the Duet.
              • fmaundefined
                fma
                Well, I have 2 big 40mm fans blowing on the Duet/Duex, triggered when CPU rises above 45°C, as you do…
                Frédéric
                  OK so temperature shouldn't be an issue, assuming you have calibrated the CPU temperature reading.
                  • fmaundefined
                    fma
                    No, I didn't calibrate it! I have to do this…
                    Frédéric
                      If your uncalibrated CPU temperature under-reads a lot, then the Duet could still be getting quite warm.
                      • fmaundefined
                        fma
                        Well, in fact, default reading was 13°C above real CPU temp. So, fans started running at 35°C instead of 45°C. So CPU temp is not the issue.
                        Frédéric
                        • dcaronundefined
                          dcaron
                          Hi David,
                          Is using the HW floating point beneficial to specific performance aspects at this point? Also, is this release including all of alpha 7 enhancements?
                          • SuperJETTundefined
                            SuperJETT
                            Feedback:
                            In Chrome on Win10 x64 I can scroll down on pages (print status, gcode files, etc) but within a second or two (AJAX refresh?) it pops back to the top. 1.19 was the same where earlier versions did not.
                            On a print I had going this morning, I was at 97% and slid the speed control from 100% to 112% and the board crashed/restarted. The print is still usable, just not done, but it was a functional part and the top doesn't matter really. At some point during that print, it had acquired a different IP address also which was interesting.
                            Custom CoreXY at home with Duet Wifi, Hemera
                              @dcaron:
                              Hi David,
                              It mostly benefits particular machine architectures like SCARA which need to do a lot of floating point computations.
                              @SuperJETT:
                              Feedback:
                              …On a print I had going this morning, I was at 97% and slid the speed control from 100% to 112% and the board crashed/restarted. The print is still usable, just not done, but it was a functional part and the top doesn't matter really. At some point during that print, it had acquired a different IP address also which was interesting.
                              Did you run M112 after the restart to capture the software reset data? If so, please share it.
                                SuperJETT
                                I actually did try m112 but it reset again. I'll do some testing to learn how to use that properly?
                                • PropellerHatundefined
                                  PropellerHat
                                  Great to have the new version out.
                                  In case of a heater error, will it pause the printer?
                                    @PropellerHat:
                                    Beta 1 doesn't, but beta 2 will.
                                    • kingfisherundefined
                                      kingfisher
                                      @SuperJETT:
                                      Feedback:
                                      Same thing happens to me (Also In Chrome on Win10 x64) I'm still on 1.19, I was hoping 1.2 might fix it (but I guess not?)
                                        That would almost certainly be an issue between Chrome and DWC, so a firmware change won't help. I mostly use FireFox to access my Duets these days, because Chrome on my Win64 PC had a frequent habit of become completely unresponsive (on all tabs) for about 30 seconds before recovering - even when I wasn't connected to a Duet.
