    Pinda 2 dilemma
    1.6k
    • fcwiltundefined
      fcwilt @sinole
      @sinole said in Pinda 2 dilemma:
      the probe doesn't really behave linearly and it doesn't behave exactly the same every time, but marlin algorithm with 2 tables for bed and probe temperature makes a pretty good use of it.
      Well it would be easy to implement a table or two with firmware 3.3.x or 3.4.x
      • fcwiltundefined
        fcwilt @sinole
        repeatability is pretty good
        What is "pretty good"?
        sinoleundefined 1 Reply Last reply Reply Quote 0
        • sinoleundefined
          sinole @fcwilt
          @fcwilt standard deviation of 8 micron
          • fcwiltundefined
            fcwilt @sinole
            0.008 mm? That is very good. And that is at what probing speed?
            • sinoleundefined
              sinole @fcwilt
              @fcwilt need to mention my setup triple probes everytime at 5000 speed it backs of only 0.4 mm each probe. you can set that stuff up in marlin, im noobi here i hope i get to do that here too. its a very nice probing setup. you can mitigate a lot of hardware errors with a good software. thats why im using RepRap now the motion system is more advanced.
              • fcwiltundefined
                fcwilt @sinole
                @sinole
                With v3.3.x and 3.4.x you can control:
                • travel speed (XY movement)
                • probe speed (Z movement)
                • dive height (the height above the trigger height where probing starts)
                • tolerance if probing for 2 consecutive readings
                • probing behavior (how many times to probe - either for 2 consecutive readings or averaging all readings)
                • optional delay after XY move before doing Z move
                When you say 5000 is that mm/sec or mm/min and is that for XY moves or Z moves?
                • BoAundefined
                  BoA
                  Personally, I would use SuperPINDA which is temperature compensated internally. Not much more money, a lot less headache 😄 Been there, did that.
                  martin7404undefined 1 Reply Last reply Reply Quote 0
                  • martin7404undefined
                    martin7404 @BoA
                    @boa I second that. My initial setup was pinda2 that I had in hand that kind of worked. But since I went for super pinda my 600x400 bed in 60 deg C chamber bed leveling is in 0.08 mm every time
                    Muldex IDEX Duet2+Duex5
                    Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                    Sapphire Pro with Duet2, with closed-loop motors
                    custom high temp E3D tool changer with Duet2+Duex
                    • oliofundefined
                      oliof @martin7404
                      @sinole the SuperPINDA is made by Pepperl+Fuchs, no Prusa magic. In Europe there are various sellers (VonWange, CR3D, RatRig) selling very similar or identical probes. In the US, SquishWorx carries the SuperPINDA (ref https://squishworx.com/prusa-superpinda/ ) which is the same P+F part Prusa procures as far as I know, for 39$.
                      BoAundefined 1 Reply Last reply Reply Quote 1
                      • BoAundefined
                        BoA @oliof
                        @oliof Basically any internally temperature compensated probe will do (with proper output type obviously). I did some research once and Prusa's was cheapest one that works with 5V power supply (original prusa board back then, not required for duet) and is temp. compensated and in 8mm diameter).
