BLTouch Not Working After Firmware Update to 3.4
@Phaedrux It was previously firmware version 3.3
Here's the m112 results:
M122
RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (SBC mode)
Board ID: 08DJM-9P63L-DJMSS-6JTDA-3SS6J-1BG7B
Used output buffers: 1 of 40 (12 max)
Static ram: 151000
Dynamic ram: 67900 of which 0 recycled
Never used RAM 131700, free system stack 154 words
Tasks: ACCEL(notifyWait,0.0%,348) SBC(resourceWait:,0.5%,468) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,269) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,333) TMC(notifyWait,7.8%,92) MAIN(running,91.5%,1231) IDLE(ready,0.1%,30), total 100.0%
Owned mutexes: HTTP(MAIN)
Last reset 00:47:11 ago, cause: software
Last software reset at 2022-05-25 13:15, reason: User, GCodes spinning, available RAM 131700, slot 2
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
Error status: 0x00
Step timer max interval 135
MCU temperature: min 43.3, current 47.0, max 48.0
Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
Events: 0 queued, 0 completed
Driver 0: standstill, SG min 0, mspos 456, reads 5490, writes 19 timeouts 0
Driver 1: standstill, SG min 0, mspos 8, reads 5490, writes 19 timeouts 0
Driver 2: standstill, SG min 0, mspos 8, reads 5495, writes 14 timeouts 0
Driver 3: standstill, SG min 0, mspos 216, reads 5490, writes 19 timeouts 0
Driver 4: standstill, SG min 0, mspos 216, reads 5490, writes 19 timeouts 0
Driver 5: standstill, SG min 0, mspos 216, reads 5490, writes 19 timeouts 0
Date/time: 2022-05-25 14:02:51
Slowest loop: 50.72ms; fastest: 0.04ms
=== Storage ===
Free file entries: 10
DMs created 125, segments created 3, maxWait 319256ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 8, completed 8, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Segments left: 0
Movement lock held by null
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty
=== Filament sensors ===
Extruder 0 sensor: ok
=== CAN ===
Messages queued 25458, received 0, lost 0, boc 0
Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 14158/0/0
Tx timeouts 0,0,14157,0,0,11299 last cancelled message type 4514 dest 127
=== SBC interface ===
Transfer state: 4, failed transfers: 0, checksum errors: 0
RX/TX seq numbers: 46466/46466
SPI underruns 0, overruns 0
State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x2b880
Buffer RX/TX: 0/0-0, open files: 0
=== Duet Control Server ===
Duet Control Server v3.4.0
Code buffer space: 4096
Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
Full transfers per second: 39.23, max time between full transfers: 240.7ms, max pin wait times: 69.5ms/17.3ms
Codes per second: 0.06
Maximum length of RX/TX data transfers: 3132/856M98 P"config.g" returns these:
Warning: M307: Heater 1 predicted maximum temperature at full power is 831°C
M307: Heater 0 predicted maximum temperature at full power is 210°C -
Please try uploading the 3.4 zip file as is to the system tab in DWC to make sure all files are up to date.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
It's strange that M401/M402 will work to deploy but G30 won't.
Can you post your homing files and deploy/retract macros please?
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Apr 06 2022 16:00:08 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-475 Y605 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y-5 F6000 ; go back a few mm G1 H1 X-475 Y605 F360 ; move slowly to X and Y axis endstops once more (second pass) G1 H2 Z5 F6000 ; lift Z relative to current position - we are about to move X and Y and we want to be sure the nozzle is clear of the bed. G90 G1 X222 Y500 F6000 ; move the probe to the center of the bed - for aaa, bbb, ccc use values suitable for your printer G30 ; probe the bed and set the logical position of Z thus homing the Z axis ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Apr 06 2022 16:00:08 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-475 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F6000 ; go back a few mm G1 H1 X-475 F360 ; move slowly to X axis endstop once more (second pass) ;G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Apr 06 2022 16:00:08 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y605 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y-5 F6000 ; go back a few mm G1 H1 Y605 F360 ; move slowly to Y axis endstop once more (second pass) ;G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Apr 06 2022 16:00:08 GMT-0700 (Pacific Daylight Time) ;G90 ; relative positioning ;G1 Z5 F6000 ; lift Z relative to current position G90 G1 X222 Y500 F6000 ; go to first probe point G30 ;G1 H1 Z-305 F1800 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 Z5 F100 ; lift Z relative to current position G90 ; absolute positioning
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Apr 06 2022 16:00:07 GMT-0700 (Pacific Daylight Time) M280 P0 S90 ; retract BLTouch
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Apr 06 2022 16:00:07 GMT-0700 (Pacific Daylight Time) M280 P0 S10 ; deploy BLTouch
@Phaedrux Is it ok to run?
Ok so uploaded the zip and performed the update. At this moment the problem still persists
Unrelated to your problem, but
@alecsanchez said in BLTouch Not Working After Firmware Update to 3.4:
In your homez you have a G92 Z0 after the G30 to force the z position to 0. This is not likely what you intend to happen when using the probe as it would ignore the probe offset. Remove that G92 Z0.
When you updated to 3.4 did you use sudo apt update and sudo apt upgrade on the Pi?
I don't see anything incorrect in your config, other than lacking a measured XYZ probe offset in G31.
Do you get any error messages when you send G30 by itself?
@Phaedrux Yes I did use sudo update and sudo apt upgrade. G30 also doesn't give me any error messages
Is the pin perhaps sticking? You say it drops when you do an emergency stop.
It doesn't seem like it, I can send m401/m402 successively many times and it doesn't stick. How it deploys when I emergency stop is very odd though. This never occurred before
I confirmed that bltouch still triggers and stops the bed if I deploy it and then send G30. I'm just not sure what is preventing it from deploying when I send g30
As a test can you add the M401 deploy command before the G30 in your homing macros and see if it behaves then? If it does work, does it retract afterwards?
@Phaedrux I added M401 to the homez.g macro and it did not deploy
Where did you add it?
Right before G30
Try adding a M400 between, like this.
G1 X Y positioning move
M400
M401
M400
G30 -
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Apr 06 2022 16:00:08 GMT-0700 (Pacific Daylight Time) ;G90 ; relative positioning ;G1 Z5 F6000 ; lift Z relative to current position G90 M401 G1 X222 Y500 F6000 ; go to first probe point G30 ;G1 H1 Z-305 F1800 ; move Z down until the endstop is triggered ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 Z5 F100 ; lift Z relative to current position G90 ; absolute positioning
I added it here now and it did deploy, but it did not retract after I triggered it with my finger. However it did stop the bed. M401/M402 commands did not work after this
@phaedrux The M400 commands did not appear to work, bltouch did not deploy
Does M401 and M402 work manually and repeatedly when the print head is in the probing position? Perhaps it's a loose cable when in certain locations.
@Phaedrux I found something interesting about this situation, sorry for the late reply. So if the y axis is homed and the y endstop is triggered, the probe will deploy and retract normally. But if I home the z axis in a location thats not at y-min, it wont deploy since the y endstop isn't triggered. However if I manually trigger the y endstop while in the process of homing z, the probe will deploy. Very odd
What relation does your Y axis endstop wiring have with the BLtouch wiring? Are they co-located possibly causing interference? Or a short?
