    Minty Release Manager Install
    Third-party software
    458
    • fcwiltundefined
      fcwilt
      Now do you install the release manager from Minty?
      I cannot find the instructions.
        jay_s_uk @fcwilt
        @fcwilt it can be found here https://github.com/MintyTrebor/ReleaseMgr
        Install like any other plugin
        • fcwiltundefined
          fcwilt @jay_s_uk
          @jay_s_uk said in Minty Release Manager Install:
          I had no problem installing BtnCmd 00.10.09 from the file BtnCmd_DWC3.4_Beta.0.10.09.zip.
          But finding downloads like for ReleaseMgr that has eluded me.
          I found a file ReleaseMgr-0.01.13Beta.zip but it does not install like BtnCmd did. After uploading It appeared to unzip a number of files but when that was done nothing else happened.
          I cannot even determine where the files ended up.
            jay_s_uk @fcwilt
            @fcwilt installed ok for me.
            Did you download the release zip file from here for 3.4?
            https://github.com/MintyTrebor/ReleaseMgr/releases
            • fcwiltundefined
              fcwilt @jay_s_uk
              Those are the files I could not find.
              I find navigating github confusing.
              Thanks much.
              Nightowlundefined 1 Reply Last reply Reply Quote 1
              • Nightowlundefined
                Nightowl @fcwilt
                @fcwilt
                Just out of curiosity, is BtnCmd browser specific?
                What I mean is, can I install BtnCmd etc. on my Chrome browser without it affecting how DWC looks on my Edge browser, if they're on the same computer (i.e. my iMac)?
                Thanks
                Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                I'm still on my learning curve, so take everything I say with caution!
                RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
                MintyTreborundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                • MintyTreborundefined
                  MintyTrebor @Nightowl
                  @nightowl999 Yes It's browser specific. You can use the backup & restore features to move configurations between browsers.
                  NodeDSF - Native Node-Red integration with Duet boards.
                  BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
                  ReleaseMgr - Duet update info inside DWC.
                  Repo
                  fcwiltundefined 1 Reply Last reply Reply Quote 2
                  • fcwiltundefined
                    fcwilt @Nightowl
                    @nightowl999 said in Minty Release Manager Install:
                    @fcwilt
                    As Minty responded installing it for one browser will not affect the other.
                    And under Duet firmware 3.4 you can do some truly useful things with the most recent version of BtnCmd.
                    Motivated by some recent discussions here I set out to devise an easy way to create a variety of heightmaps without having to edit code.
                    Here is what I was able to do with BtnCmd, a set of controls modifying global memory settings which control the generation of the heightmap.
                    Each heightmap file created is given a unique name based on the selected settings so I can view or use them as needed.
                    I'm happy as a clam at high tide.
                    • fcwiltundefined
                      fcwilt @MintyTrebor
                      @mintytrebor
                      I did notice that when specifying the settings for a slider control the entered values are saved and the slider works as expected.
                      But when editing that slider control the current settings are not displayed, just the default settings.
                      It would be nice if the current settings could be displayed.
                      And a ton of thanks for a incredible addition to the Duet world. You deserve some sort of an award.
                      • Nightowlundefined
                        Nightowl
                        Ah, an update. It's been a while since I looked at this (other things got in the way) so would someone please remind me where I can get the latest BtnCmd files.
                        • fcwiltundefined
                          fcwilt @Nightowl
                          BtnCmd Beta_0.10.09
                          You do need to be using Duet firmware 3.4.x to use this version with it's new features.
                          I had postponed upgrading from 3.3.0 to 3.4.x but when I read about the new features in BtnCmd I made the leap to 3.4.x.
