    CNC Pause and Resume config files
    Gcode meta commands
    1.7k
      dc42 administrators @Nightowl
      @nightowl999 have you declared the savedSpindleSpeed variable in config.g, like this?
      global savedSpindleSpeed = 0
      Also, if you temporarily remove the M5 command from pause.g does the spindle continue to run?
      Nightowlundefined 2 Replies Last reply Reply Quote 0
      • Nightowlundefined
        Nightowl @dc42
        @dc42 said in CNC Pause and Resume config files:
        Exactly like that, yes, and way down the file, as you suggested.
        I'll check that tomorrow and let you know.
        Thank you
        Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
        I'm still on my learning curve, so take everything I say with caution!
        RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        • Nightowlundefined
          Nightowl @dc42
          @dc42 A bit of an update...
          With the M5 command disabled, the spindle continues to run.
          In the DWC, the Current RPM is shown as 10,000rpm but the Set RPM is 18,000rpm.
          The first lines of code within the gcode file are...
          1 ; VECTRIC POST REVISION
          2 ; A long string of random letters and numbers
          3 T1
          4 G17
          5 G21
          6 G90
          7 G0Z5.090
          8 G0X0.000Y0.000
          9 M3P0S18000
          ... and so on
          When I click Pause, I get this in the Console:
          26/05/2022, 12:20:07 Printing paused at X155.3 Y188.6 Z66.0
          26/05/2022, 12:19:56 Spindle speed saved at 0 RPM
          26/05/2022, 12:19:54 M25
          Resume state saved
          Thank you
          • OwenDundefined
            OwenD @Nightowl
            @nightowl999 said in CNC Pause and Resume config files:
            ; resume.g
            if state.currentTool >= 0 & tools[state.currentTool].spindle >= 0
            M3 S{global.savedSpindleSpeed} ; resume saved spindle speed
            This won't resolve to true because you have a couple of errors
            Try
             if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
            Nightowlundefined 1 Reply Last reply Reply Quote 1
            • Nightowlundefined
              Nightowl @OwenD
              @owend Whoops, sorry. I kinda progressed this in the other thread you've responded to 😊
              Thank you, anyway 👍
              OwenDundefined 1 Reply Last reply Reply Quote 0
              • OwenDundefined
                OwenD @Nightowl
                @nightowl999
                Probably better to keep this here as it's more specific than the other thread as it's become messy.
                I'm not really familiar with all requirements of CNC mode but it may be prudent to do some more checks in your macro.
                Also I note that there are some other spindle related object model values.
                These might help trace what's going on
                ; first ensure we have an active tool
                if state.currentTool =-1
                       echo "No tool active.  Selecting tool zero"
                       T0 ; select tool zero
                      echo "Spindle state on tool " , state.currentTool , " is " ,   spindles[state.currentTool].active
                       G4 S1					; wait 1 second to allow the spindle to spin up
                       echo "Spindle speed resumed at ", spindles[state.currentTool].active, "RPM" ; this should show that the setting was successful
                       G1 R1 X0 Y0 F2400
                else
                       echo "condition not met.  Spindle speed remains at " , tools[state.currentTool].spindleRpm ,  "RPM"
                EDIT
                I noticed an error here. Code amended above
                echo "Spindle speed resumed at ", spindles[].active, "RPM"
                Nightowlundefined 1 Reply Last reply Reply Quote 0
                • Nightowlundefined
                  Nightowl @OwenD
                  @owend This is the text from the console after changing the resume.g file...
                  27/05/2022, 20:02:40 	M0
                  Printing paused at X125.6 Y125.8 Z65.0
                  Cancelled printing file 0:/gcodes/Calibration Toolpath.gcode, print time was 0h 0m
                  27/05/2022, 20:02:27 	Spindle speed saved at 0 RPM
                  27/05/2022, 20:02:24 	M25
                  Resume state saved
                  27/05/2022, 20:02:22 	Printing resumed
                  27/05/2022, 20:02:09 	Spindle speed resumed at  0 RPM
                  27/05/2022, 20:02:09 	M24
                  Spindle state on tool  0  is  5000
                  27/05/2022, 20:02:00 	Printing paused at X128.8 Y122.6 Z66.0
                  27/05/2022, 20:01:47 	Spindle speed saved at 0 RPM
                  27/05/2022, 20:01:46 	M25
                  Resume state saved
                  27/05/2022, 20:01:29 	M32 "0:/gcodes/Calibration Toolpath.gcode"
                  File 0:/gcodes/Calibration Toolpath.gcode selected for printing
                  • OwenDundefined
                    OwenD @Nightowl
                    @nightowl999
                    OK,
                    We are getting close.
                    It seems there is no tool selected after the pause.
                    If you have multiple tools then it may be necessary to record which was selected.
                    I made a small error on one part that didn't give me the value I wanted in one of tehechos.
                    Please change both files
                    ; pause.g
                    G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)} ; move the Z axis to a safe height
                    	set global.savedSpindleSpeed = tools[state.currentTool].spindleRpm ; save current spindle speed
                    	G1 X273.5 Y560 F2400 ; move XY to a safe place
                    	M5 ; turn the spindle off
                    	echo "Spindle speed saved at " ^ { global.savedSpindleSpeed } ^ "RPM"
                    else
                    	echo "condition not met - Tool is ", state.currentTool, " Spindle RPM is ", tools[state.currentTool].spindleRpm
                    and
                    resume.g
                    	echo "Spindle state on tool " , state.currentTool , " is " ,   spindles[state.currentTool].state
                    	G1 R1 X0 Y0 F2400
                    else
                    EDIT:
                    Apologies.
                    I got the indenting on pause.g all wrong. (lack of sleep). Corrected above
                    • Nightowlundefined
                      Nightowl @OwenD
                      @owend I'm happy to leave this for now, if you need to get some beauty sleep!
                      Here's the console text:
                      27/05/2022, 20:25:40 	M0
                      27/05/2022, 20:25:27 	Printing paused at X128.8 Y122.6 Z66.0
                      27/05/2022, 20:25:26 	Error: in file macro line 20 column 81: meta command: array index out of bounds
                      27/05/2022, 20:25:24 	M25
                      Resume state saved
                      27/05/2022, 20:25:19 	M32 "0:/gcodes/Calibration Toolpath.gcode"
                      PS You have nothing to apologise for!
                      • OwenDundefined
                        OwenD @Nightowl
                        @nightowl999
                        All good.
                        Can you try this pause.g
                        I can't understand the index out of bounds if there's a tool selected.
                        There is no line 20, but you're probably getting extra carriage returns when copy/pasting
                        ; pause.g
                        if state.currentTool = -1
                        	echo "No tool selected"
                        {if state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
                        else
                        Nightowlundefined 3 Replies Last reply Reply Quote 0
                        • Nightowlundefined
                          Nightowl @OwenD
                          @owend Doing that now, but I REMd out the other lines, so that's why there's a line 20.
                          Not any more, though!
                          • Nightowlundefined
                            Nightowl @OwenD
                            @owend Here you go...
                            27/05/2022, 20:38:47 	M0
                            27/05/2022, 20:38:33 	Printing paused at X128.8 Y122.6 Z66.0
                            27/05/2022, 20:38:32 	No tool selected
                            Error: Bad command: {if state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
                            Error: in file macro line 6 column 36: meta command: array index out of bounds
                            27/05/2022, 20:38:30 	M25
                            Resume state saved
                            27/05/2022, 20:38:24 	M32 "0:/gcodes/Calibration Toolpath.gcode"
                            • Nightowlundefined
                              Nightowl @OwenD
                              @owend Should the wriggly brackets be after the second "if"?
                              I changed it anyway, and now get this in the Console:
                              27/05/2022, 20:46:49 	M0
                              27/05/2022, 20:46:44 	Printing paused at X125.6 Y125.8 Z66.0
                              27/05/2022, 20:46:43 	No tool selected
                              Error: in file macro line 11 column 81: meta command: array index out of bounds
                              27/05/2022, 20:46:40 	M25
                              Resume state saved
                              27/05/2022, 20:46:35 	M32 "0:/gcodes/Calibration Toolpath.gcode"
                              BTW, when I click pause, the spinde keeps running and the XY stays where it is, not returning to the safe XY.
                              • OwenDundefined
                                OwenD @Nightowl
                                Yes, I thought I corrected that.
                                But now it's clear there's no tool selected when you are pausing.
                                Therefore none of the subsequent code can work as it relies on a tool being selected.
                                Is this a real job, or a dummy one?
                                I'm willing to bet this would work (if I haven't mage any syntax errors LOL)
                                ; pause.g
                                	echo "No tool selected - selecting tool zero"
                                	T0
                                else
                                EDIT
                                If this works then we need to know how many tools you have.
                                • Nightowlundefined
                                  Nightowl @OwenD
                                  @owend I'll try it, but I'm aware you're tired (as am I!)
                                  • OwenDundefined
                                    OwenD @Nightowl
                                    It's 5:51 AM here. I'm tired because I woke at 3am and couldn't get back to sleep 😧
                                    Try it when you can and report back.
                                    Nightowlundefined 2 Replies Last reply Reply Quote 1
                                    • Nightowlundefined
                                      Nightowl
                                      It works! And the spindle turns off with pause and on with resume!
                                      • Nightowlundefined
                                        Nightowl @OwenD
                                        @owend It's only 9pm here, but I've been trying to sort this all day!
                                        • OwenDundefined
                                          OwenD @Nightowl
                                          @nightowl999
                                          OK,
                                          So the problem was there was no tool selected.
                                          I would have thought that was necessary to turn a spindle on, but maybe not.
                                          If you have multiple tools then you'll need to consider how to store which tool was selected when you pause (if RRF doesn't store that in CNC mode)
                                          • Nightowlundefined
                                            Nightowl @OwenD
                                            @owend This is how my spindle is configured in config.g:
                                            ; Makita and relay configuration
                                            M950 R0 C"out1+out7" L0:18000	; enable router relay on out7
                                            M563 P0 S"Makita" R0 		; assign spindle 0 to tool 0 and name it Makita
                                            T0				; select tool 0
                                            This was only configured to turn the spindle off/on via a relay, but I figured I will need this resolved for when my speed-contollable milling motor turns up. My assumption is the speed thing isn't relevant as the DI isn't connected.
