    CNC Pause and Resume config files
    Gcode meta commands
    1.7k
    • Nightowlundefined
      Nightowl @OwenD
      @owend Whoops, sorry. I kinda progressed this in the other thread you've responded to 😊
      Thank you, anyway 👍
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @Nightowl
        @nightowl999
        Probably better to keep this here as it's more specific than the other thread as it's become messy.
        I'm not really familiar with all requirements of CNC mode but it may be prudent to do some more checks in your macro.
        Also I note that there are some other spindle related object model values.
        These might help trace what's going on
        ; first ensure we have an active tool
        if state.currentTool =-1
               echo "No tool active.  Selecting tool zero"
               T0 ; select tool zero
        if state.currentTool >= 0
              echo "Spindle state on tool " , state.currentTool , " is " ,   spindles[state.currentTool].active
        if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
               M3 S{global.savedSpindleSpeed}	; resume saved spindle speed
               G4 S1					; wait 1 second to allow the spindle to spin up
               echo "Spindle speed resumed at ", spindles[state.currentTool].active, "RPM" ; this should show that the setting was successful
               G1 R1 X0 Y0 F2400
        else
               echo "condition not met.  Spindle speed remains at " , tools[state.currentTool].spindleRpm ,  "RPM"
        EDIT
        I noticed an error here. Code amended above
        echo "Spindle speed resumed at ", spindles[].active, "RPM"
        Nightowlundefined 1 Reply Last reply Reply Quote 0
        • Nightowlundefined
          Nightowl @OwenD
          @owend This is the text from the console after changing the resume.g file...
          27/05/2022, 20:02:40 	M0
          Printing paused at X125.6 Y125.8 Z65.0
          Cancelled printing file 0:/gcodes/Calibration Toolpath.gcode, print time was 0h 0m
          27/05/2022, 20:02:27 	Spindle speed saved at 0 RPM
          27/05/2022, 20:02:24 	M25
          Resume state saved
          27/05/2022, 20:02:22 	Printing resumed
          27/05/2022, 20:02:09 	Spindle speed resumed at  0 RPM
          27/05/2022, 20:02:09 	M24
          Spindle state on tool  0  is  5000
          27/05/2022, 20:02:00 	Printing paused at X128.8 Y122.6 Z66.0
          27/05/2022, 20:01:47 	Spindle speed saved at 0 RPM
          27/05/2022, 20:01:46 	M25
          Resume state saved
          27/05/2022, 20:01:29 	M32 "0:/gcodes/Calibration Toolpath.gcode"
          File 0:/gcodes/Calibration Toolpath.gcode selected for printing
          • OwenDundefined
            OwenD @Nightowl
            @nightowl999
            OK,
            We are getting close.
            It seems there is no tool selected after the pause.
            If you have multiple tools then it may be necessary to record which was selected.
            I made a small error on one part that didn't give me the value I wanted in one of tehechos.
            Please change both files
            ; pause.g
            G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)} ; move the Z axis to a safe height
            	set global.savedSpindleSpeed = tools[state.currentTool].spindleRpm ; save current spindle speed
            	G1 X273.5 Y560 F2400 ; move XY to a safe place
            	M5 ; turn the spindle off
            	echo "Spindle speed saved at " ^ { global.savedSpindleSpeed } ^ "RPM"
            else
            	echo "condition not met - Tool is ", state.currentTool, " Spindle RPM is ", tools[state.currentTool].spindleRpm
            and
            resume.g
            	echo "Spindle state on tool " , state.currentTool , " is " ,   spindles[state.currentTool].state
            	G1 R1 X0 Y0 F2400
            else
            EDIT:
            Apologies.
            I got the indenting on pause.g all wrong. (lack of sleep). Corrected above
            • Nightowlundefined
              Nightowl @OwenD
              @owend I'm happy to leave this for now, if you need to get some beauty sleep!
              Here's the console text:
              27/05/2022, 20:25:40 	M0
              27/05/2022, 20:25:27 	Printing paused at X128.8 Y122.6 Z66.0
              27/05/2022, 20:25:26 	Error: in file macro line 20 column 81: meta command: array index out of bounds
              27/05/2022, 20:25:24 	M25
              Resume state saved
              27/05/2022, 20:25:19 	M32 "0:/gcodes/Calibration Toolpath.gcode"
              PS You have nothing to apologise for!
              • OwenDundefined
                OwenD @Nightowl
                @nightowl999
                All good.
                Can you try this pause.g
                I can't understand the index out of bounds if there's a tool selected.
                There is no line 20, but you're probably getting extra carriage returns when copy/pasting
                ; pause.g
                if state.currentTool = -1
                	echo "No tool selected"
                {if state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
                else
                Nightowlundefined 3 Replies Last reply Reply Quote 0
                • Nightowlundefined
                  Nightowl @OwenD
                  @owend Doing that now, but I REMd out the other lines, so that's why there's a line 20.
                  Not any more, though!
                  • Nightowlundefined
                    Nightowl @OwenD
                    @owend Here you go...
                    27/05/2022, 20:38:47 	M0
                    27/05/2022, 20:38:33 	Printing paused at X128.8 Y122.6 Z66.0
                    27/05/2022, 20:38:32 	No tool selected
                    Error: Bad command: {if state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
                    Error: in file macro line 6 column 36: meta command: array index out of bounds
                    27/05/2022, 20:38:30 	M25
                    Resume state saved
                    27/05/2022, 20:38:24 	M32 "0:/gcodes/Calibration Toolpath.gcode"
                    • Nightowlundefined
                      Nightowl @OwenD
                      @owend Should the wriggly brackets be after the second "if"?
                      I changed it anyway, and now get this in the Console:
                      27/05/2022, 20:46:49 	M0
                      27/05/2022, 20:46:44 	Printing paused at X125.6 Y125.8 Z66.0
                      27/05/2022, 20:46:43 	No tool selected
                      Error: in file macro line 11 column 81: meta command: array index out of bounds
                      27/05/2022, 20:46:40 	M25
                      Resume state saved
                      27/05/2022, 20:46:35 	M32 "0:/gcodes/Calibration Toolpath.gcode"
                      BTW, when I click pause, the spinde keeps running and the XY stays where it is, not returning to the safe XY.
                      • OwenDundefined
                        OwenD @Nightowl
                        @nightowl999 said in CNC Pause and Resume config files:
                        Yes, I thought I corrected that.
                        But now it's clear there's no tool selected when you are pausing.
                        Therefore none of the subsequent code can work as it relies on a tool being selected.
                        Is this a real job, or a dummy one?
                        I'm willing to bet this would work (if I haven't mage any syntax errors LOL)
                        ; pause.g
                        	echo "No tool selected - selecting tool zero"
                        	T0
                        else
                        EDIT
                        If this works then we need to know how many tools you have.
                        Nightowlundefined 1 Reply Last reply Reply Quote 1
                        • Nightowlundefined
                          Nightowl @OwenD
                          @owend I'll try it, but I'm aware you're tired (as am I!)
                          • OwenDundefined
                            OwenD @Nightowl
                            It's 5:51 AM here. I'm tired because I woke at 3am and couldn't get back to sleep 😧
                            Try it when you can and report back.
                            Nightowlundefined 2 Replies Last reply Reply Quote 1
                            • Nightowlundefined
                              Nightowl
                              It works! And the spindle turns off with pause and on with resume!
                              • Nightowlundefined
                                Nightowl @OwenD
                                @owend It's only 9pm here, but I've been trying to sort this all day!
                                • OwenDundefined
                                  OwenD @Nightowl
                                  @nightowl999
                                  OK,
                                  So the problem was there was no tool selected.
                                  I would have thought that was necessary to turn a spindle on, but maybe not.
                                  If you have multiple tools then you'll need to consider how to store which tool was selected when you pause (if RRF doesn't store that in CNC mode)
                                  • Nightowlundefined
                                    Nightowl @OwenD
                                    @owend This is how my spindle is configured in config.g:
                                    ; Makita and relay configuration
                                    M950 R0 C"out1+out7" L0:18000	; enable router relay on out7
                                    M563 P0 S"Makita" R0 		; assign spindle 0 to tool 0 and name it Makita
                                    T0				; select tool 0
                                    This was only configured to turn the spindle off/on via a relay, but I figured I will need this resolved for when my speed-contollable milling motor turns up. My assumption is the speed thing isn't relevant as the DI isn't connected.
                                    • OwenDundefined
                                      OwenD @Nightowl
                                      @nightowl999
                                      What happens in the console when you run
                                      M98 P"0:/sys/config.g"
                                      You're selecting T0, so I'm at a loss why it's not selected in your job.
                                      Somewhere something is turning it off.
                                      • Nightowlundefined
                                        Nightowl @OwenD
                                        @owend said in CNC Pause and Resume config files:
                                        From the command line?
                                        • OwenDundefined
                                          OwenD @Nightowl
                                          @nightowl999
                                          yes
                                          • Nightowlundefined
                                            Nightowl @OwenD
                                            @owend
                                            Only this:
                                            27/05/2022, 21:02:24 M98 P"0:/sys/config.g"
                                            HTTP is enabled on port 80
                                            FTP is disabled
                                            TELNET is disabled
                                            Error: in file macro line 66 column 27: meta command: variable 'savedSpindleSpeed' already exists
                                            but I haven't 'rebooted' the Duet
