    Endstop issues
    395
    • tecnoundefined
      tecno
      @infiniteloop said in Endstop issues:
      The SME-8K is a sensor with (according to the data sheet) less-than-optimal accuracy; the +/- 0.1 mm repeatability tolerance adds up to the height of a typical first layer. A cheap microswitch would be an adequate replacement, a high-quality switch gives better results. In order to get the Festo to work, try this:
      Connect BN to GND, BU to V_IN (no PWM output needed), and BK to io1.in.
      Then, configure your end stop like this:
      M574 X2 S1 Pβ€œ^40.io.inβ€œ
      Should work.
      Did not work. No LED at all.
      So time to dig out some mechanical end switches
      Just a note PWM out was easiest way to get power so it is needed πŸ˜‰
      infiniteloopundefined 2 Replies Last reply Reply Quote 0
      • infiniteloopundefined
        infiniteloop @tecno
        @tecno said in Endstop issues:
        Using a multimeter, what voltage do you read at BK when the Festo is at the magnet, what do you read when it's not?
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @infiniteloop
          @infiniteloop
          Connected as per your instruction = 0.2V with or without magnet
            infiniteloop @tecno
            I wouldn't trust a PWM signal to be always high. Festo and their suppliers do not provide application notes, but this thing should be, at the bottom, a simple reed switch, which I suppose to work fine with 5V, too.
              infiniteloop @tecno
              Did you measure BK against BU?
              • tecnoundefined
                tecno @infiniteloop
                @infiniteloop
                Haven't tried to use 5V = same shit no go
                So I will use some mechanical
                Nightowlundefined 1 Reply Last reply Reply Quote 0
                • Nightowlundefined
                  Nightowl @tecno
                  @tecno
                  I don't know anything about these proximity sensors, but experience with mechanical end switches is that they're less consistent.
                  Have you tried something like these or these? I replaced my mechanical switches with the UK ones, and they work really well - even at 5V.
                  Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                  I'm still on my learning curve, so take everything I say with caution!
                  RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
                  • tecnoundefined
                    tecno @Nightowl
                    @nightowl999
                    Way too big for my taste, and yes I have tried.
                    • fcwiltundefined
                      fcwilt @tecno
                      @nightowl999
                      Just about every kind of inductive sensor you might need. This is the source I use.
                      Inductive Sensors Supplier
                      • tecnoundefined
                        tecno @fcwilt
                        @fcwilt
                        I know about them but way too expensive to get parts to Sweden.
                        • fcwiltundefined
                          fcwilt @tecno
                          @fcwilt
                          My bad - didn't know you were in Sweden.
                          • tecnoundefined
                            tecno @fcwilt
                            @fcwilt
                            No worries Frederick
                            • tecnoundefined
                              tecno @tecno
                              Problem solved !
                              Micro switches on each tower now.
                                A Former User @tecno
                                This post is deleted!
                                • fcwiltundefined
                                  fcwilt @A Former User
                                  @arnold_r_clark said in Endstop issues:
                                  @tecno
                                  On my Delta i use These
                                  I use them for Z probes but never thought of using them for endstops.
                                  To date I have used micro-switches or IR beam-break detectors.
                                  Thanks for sharing another approach.
                                    A Former User @fcwilt
