    [3.4.1-rc2] update fail
    Firmware developers
    1.8k
      Can you please provide the results of sending M122 and M122 B# in the gcode console where # is the canbus address of your expansion boards?
      supertb1undefined 1 Reply Last reply Reply Quote 0
      • supertb1undefined
        supertb1 @Phaedrux
        @phaedrux
        6/5/2022, 10:04:17 PM M122 B51.0
        Diagnostics for board 51:
        Duet EXP1HCL firmware version 3.4.1 (2022-06-01 21:14:32)
        Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
        All averaging filters OK
        Never used RAM 52288, free system stack 194 words
        Tasks: Move(notifyWait,0.0%,152) HEAT(notifyWait,0.0%,88) CanAsync(notifyWait,0.0%,70) CanRecv(notifyWait,0.0%,79) CanClock(notifyWait,0.0%,72) TMC(notifyWait,34.5%,360) CLSend(notifyWait,0.0%,152) MAIN(running,63.7%,409) IDLE(ready,0.0%,30) AIN(notifyWait,1.8%,265), total 100.0%
        Last reset 00:02:14 ago, cause: power up
        Last software reset data not available
        Closed loop enabled: yes, pre-error threshold: 5.00, error threshold: 10.00, encoder type rotaryQuadrature, reverse polarity: no, position 1, raw count = 0, tuning mode: 0, tuning error: 0x1, collecting data: no
        Control loop runtime (ms): min=0.003, max=0.011, frequency (Hz): min=10870, max=17442
        Driver 0: pos 0, 81.7 steps/mm,not tuned, SG min 0, mspos 8, reads 27185, writes 23 timeouts 0, steps req 0 done 0
        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
        Peak sync jitter -4/4, peak Rx sync delay 186, resyncs 0/0, no step interrupt scheduled
        VIN voltage: min 24.3, current 24.3, max 24.4
        V12 voltage: min 12.2, current 12.2, max 12.2
        MCU temperature: min 23.8C, current 26.8C, max 26.8C
        Last sensors broadcast 0x00000000 found 0 44 ticks ago, 0 ordering errs, loop time 0
        CAN messages queued 1109, send timeouts 0, received 1220, lost 0, free buffers 37, min 37, error reg 0
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
        6/5/2022, 10:04:10 PM M122 B50.0
        Diagnostics for board 50:
        Never used RAM 52288, free system stack 200 words
        Last reset 00:02:08 ago, cause: power up
        Control loop runtime (ms): min=0.003, max=0.011, frequency (Hz): min=11538, max=17442
        Driver 0: pos 0, 80.5 steps/mm,not tuned, SG min 0, mspos 8, reads 58946, writes 23 timeouts 0, steps req 0 done 0
        Peak sync jitter -6/7, peak Rx sync delay 188, resyncs 0/0, no step interrupt scheduled
        V12 voltage: min 12.1, current 12.1, max 12.1
        MCU temperature: min 24.4C, current 26.4C, max 26.7C
        Last sensors broadcast 0x00000000 found 0 198 ticks ago, 0 ordering errs, loop time 0
        CAN messages queued 1059, send timeouts 0, received 1165, lost 0, free buffers 37, min 37, error reg 0
        6/5/2022, 10:04:01 PM M122
        RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (standalone mode)
        Board ID: 08DJM-956BA-NA3TJ-6J9F2-3SD6J-9B9AT
        Used output buffers: 3 of 40 (13 max)
        Static ram: 151000
        Dynamic ram: 96272 of which 0 recycled
        Never used RAM 103400, free system stack 200 words
        Tasks: NETWORK(ready,25.1%,251) ETHERNET(notifyWait,0.0%,173) HEAT(notifyWait,0.0%,327) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.9%,92) MAIN(running,66.8%,1101) IDLE(ready,0.1%,30), total 100.0%
        Owned mutexes:
        Last reset 00:01:58 ago, cause: power up
        Last software reset at 2022-06-05 16:14, reason: User, GCodes spinning, available RAM 103400, slot 2
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        Step timer max interval 126
        MCU temperature: min 21.3, current 33.0, max 33.0
        Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 0, mspos 8, reads 5515, writes 14 timeouts 0
        Driver 1: standstill, SG min 0, mspos 8, reads 5519, writes 11 timeouts 0
        Driver 2: standstill, SG min 0, mspos 8, reads 5519, writes 11 timeouts 0
        Driver 3: standstill, SG min 0, mspos 8, reads 5519, writes 11 timeouts 0
        Driver 4: standstill, SG min 0, mspos 8, reads 5516, writes 14 timeouts 0
        Driver 5: standstill, SG min 0, mspos 8, reads 5519, writes 11 timeouts 0
        Date/time: 2022-06-05 22:04:00
        Slowest loop: 2.61ms; fastest: 0.05ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 1.6ms, write time 0.0ms, max retries 0
        DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        === AuxDDARing ===
        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty
        === Filament sensors ===
        Extruder 0 sensor: no data received
        === CAN ===
        Messages queued 1080, received 1914, lost 0, boc 0
        Longest wait 6ms for reply type 6018, peak Tx sync delay 6, free buffers 50 (min 49), ts 594/593/0
        Tx timeouts 0,0,0,0,0,0
        === Network ===
        Slowest loop: 4.56ms; fastest: 0.02ms
        HTTP sessions: 1 of 8
        • Ethernet -
          State: active
          Error counts: 0 0 1 0 0
          So it looks like you're all up to date on 3.4.1 now. Assuming that's only after updating with bossa.
          Can you upload the zip file again now? Does it still produce an error? Is the only place you see the error on the PanelDue? What firmware version is the PanelDue?
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.1/Duet2and3Firmware-3.4.1.zip
            dc42 administrators @supertb1
            @supertb1 FWIW that error "Operation 3 failed after 5 retries" comes from the IAP when it tries to update the firmware. It means that an operation to write a block of firmware to flash memory failed. My guess is that the prior Erase operation didn't fully erase the flash memory. You fixed that with the Ease jumper and Bossa.
            The only suggestion I have is that you check that you have the latest version of the IAP file for the MB6HC in the /firmware folder on the SD card.
            If this issue comes up more often, I will modify the IAP to restart the whole process form scratch the first time an irrecoverable error like this happens.
            supertb1undefined 2 Replies Last reply Reply Quote 1
            • supertb1undefined
              supertb1 @dc42
              @dc42 in what release was the last "in app programmer" published?
              How do I check what version IAP I have?
              • supertb1undefined
                supertb1 @Phaedrux
                @phaedrux I updated the paneldue7i to the latest version and then ran the Duet2and3Firmware-3.4.1.zip again, it worked fine this time.
                  @supertb1 said in [3.4.1-rc2] update fail:
                  In release 3.4.1, however I don;t think there were any changes between 3.4.0 and 3.4.1. If you uploaded the 3.4.1 zip file then you should already have the latest version.
                  It can only be checked by date and file size at present.
                  supertb1undefined 2 Replies Last reply Reply Quote 0
                  • supertb1undefined
                    supertb1 @dc42
                    @dc42 so it is in the .ZIP file, I'm not sure what is going on with this new board, it has been giving me issues since RC1. It always comes up with error: "Operation 3 failed after 5 retries". while my 2 year old board has never given me any troubles.
                    • supertb1undefined
                      supertb1 @dc42
                      @dc42 Is there a way to install the IAP separate from the .zip file for issues like this?
                        @supertb1 yes, just upload it the same way that you upload a firmware binary, and it will appear in the /firmware folder.
                        • supertb1undefined
                          supertb1 @dc42
                          @dc42 so you unzip the file and upload the DuetAPI.xml?
                            Phaedrux Moderator @supertb1
                            No. The zip file should be uploaded intact. Do not unzip it first unless you want to upload a single specific file.
                            • supertb1undefined
                              supertb1 @dc42
                              I tried to update to the latest firmware and it did the same thing listed below. Is there a way to make it not do that? or would it be advisable to not update this particular board?
                              ***FWIW that error "Operation 3 failed after 5 retries" comes from the IAP when it tries to update the firmware. It means that an operation to write a block of firmware to flash memory failed. My guess is that the prior Erase operation didn't fully erase the flash memory. You fixed that with the Ease jumper and Bossa.
                              If this issue comes up more often, I will modify the IAP to restart the whole process form scratch the first time an irrecoverable error like this happens.******
                                What was the update method used this time?
                                • supertb1undefined
                                  supertb1 @Phaedrux
                                  @phaedrux I tried to upload the update zip file to the web interface, and it failed the third step just like it did before, I used the second fall back process and now am in the process to getting back on the web interface to install the tool board firmware updates manually. this being as big a head ache as this board has been on firmware updates I am trying to figure out if there are any reasons why I should update it in the future or if I should just wait until like update 4.0 before I reset the board and use bossa again. Any thoughts... Is there something that I should be doing outside the norm with this particular board?
                                    When and where did you purchase this Duet?
                                    • supertb1undefined
                                      supertb1 @Phaedrux
                                      @Phaedrux I purchased the Duet 3 6HC on April 1 2022 from filastruder. Board ID: 08DJM-956BA-NA3TJ-6J9F2-3SD6J-9B9AT
                                      Invoice c30699537694791.1. Is there a way to confirm that this board is actually a Duet3D manufactured board? I would be very interested to find out if this board was a knock off or if somehow there was some kind of defect/ different design/explanation for why this board does not behave like the other duet board I have.
                                        droftarts administrators @supertb1
                                        @supertb1 Filastruder is an official vendor of Duet3D hardware, and I’m sure your board is genuine. Feel free to post a picture of it if you are in any doubt.
                                        We have discussed this issue internally, as it’s not clear what is going wrong. We think most likely the flash chip may be damaged, or something is associated is interfering with the flash process.
                                        As such, we are happy to offer you a warranty replacement. Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                                        elmoretundefined 1 Reply Last reply Reply Quote 1
                                        • elmoretundefined
                                          elmoret @droftarts
                                          Tim here, from Filastruder. A couple things:
                                          • We do not, and have never, sold clones/knockoffs of any product.
                                          • Citing the PayPal Invoice ID tells me you might not be getting emails from us, as you'd have a 5 digit order ID from your order confirmation and shipping confirmation. So, you might want to check your spam filter settings.
                                          • supertb1undefined
                                            supertb1 @elmoret
                                            @elmoret Yes it is interesting, I log into my filastruder account to find where I have ordered this board and it doesn't show up but on my pay pal it shows that I purchased this board at 10:35 PM for 249.99 paid to Acceleration Labs, LLC. Invoice ID: c30699537694791.1
                                            Transaction ID: 036817299B715910L
                                            I have never ordered a DUET3D device from any other source besides directly from DUET3D or Filastruder. Am I missing something here, I am at a loss. Currently the printer is making a part and as soon as it is done I'm going to open the control box and get the serial number directly off the board to find out if it is different than the reported ID number.
                                            elmoretundefined 1 Reply Last reply Reply Quote 0
