Duet Smart Effector not triggering on first probe point
Smart effector for delta printers
407
    Daniel_Lacroix
    When auto leveling, the first probe point is not considered triggered although the nozzle hits the bed. The green indicator light is not turned on either although the nozzle scrapes against the bed. On all subsequent probe points the green indicator comes on and the point is considered triggered. Only the first point fails to trigger.
    Here is my Config.G:
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 20 2020 19:57:06 GMT-0500 (Central Daylight Time)
    M550 P"Anycubic Predator" ; set printer name
    M665 R227 L440.45 B185 H410 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
    M552 P192.168.86.37 S1 ; enable network and acquire dynamic address via DHCP
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P1 S0 ; physical drive 1 goes forwards
    M569 P3 S0 ; physical drive 3 goes forwards
    ; M92 X80.00 Y80.00 Z80.00 E3292.68 ; set steps per mm (TPU)
    M92 X80.00 Y80.00 Z80.00 E4500 ; set steps per mm (PLA)
    M566 X1500.00 Y1500.00 Z1500.00 E40.00 P1 ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E10000.00 ; set maximum speeds (mm/min)
    M201 X1500.00 Y1500.00 Z1500.00 E120.00 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    ; Retraction
    ; M207 S1 F1800 Z0.388 ; Firmware retraction
    M208 Z0 S1 ; set minimum Z
    M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
    M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
    ; M591 D0 P7 C"e0stop" L7 R50:200 E15 S1 ; filament sensor connected to e0_stop
    M558 P8 R0.4 C"zprobe.in+zprobe.mod" H10 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
    G31 P100 X0 Y0 Z.1 ; set Z probe trigger value, offset and trigger height
    M557 R180 S20 ; define mesh grid
    M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; disable bang-bang mode for the bed heater and set PWM limit
    M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
    M950 F0 C"fan0" Q500 ; create fan 2 on pin fan2 and set its frequency
    M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
    M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
    M572 D0 S0.2 ; pressure advance
    M501 ; set the active parameters to those stored in sys/config-override.g
      jay_s_uk
      I guess you need to check your wiring.
      Does the led light up on board power on?
      Does it light up if you tap the nozzle with your finger fairly hard?
      undefined 3 Replies Last reply 6 Jun 2022, 23:19 Reply Quote 0
        Daniel_Lacroix @jay_s_uk
        @jay_s_uk
        I checked the wiring on both ends and they make a connection. The LED blinks twice when powering on and blinks once when tapped.
          @jay_s_uk
          I am getting this error when activating the hotend: new tool too close to z axis limit. aborting tool change
            @jay_s_uk
            Here is my homedelta.g file:
            ; homedelta.g
            ; called to home all towers on a delta printer
            G91 ; relative positioning
            G1 H1 X505 Y505 Z505 F1800 ; move all towers to the high end stopping at the endstops (first pass)
            G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
            G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
            ;G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
            G90 ; absolute positioning
            ;G1 X0 Y0 F6000 ; move X+Y to the centre
              Does it trigger properly on a single G30?
              Can you post your bed.g as well?
              Can you post a video of it happening?
              undefined 1 Reply Last reply 11 Jun 2022, 22:44 Reply Quote 0
                Daniel_Lacroix @Phaedrux
                @phaedrux
                Here is my bed.g:
                ; bed.g
                ; called to perform automatic delta calibration via G32
                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 20 2020 19:57:05 GMT-0500 (Central Daylight Time)
                G28 ; home all towers
                G1 E-1.9 F300 ; retract a little
                ; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
                ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
                G30 P0 X0 Y179.9 H0 Z-99999
                G30 P1 X155.8 Y89.95 H0 Z-99999
                G30 P2 X155.8 Y-89.95 H0 Z-99999
                G30 P3 X0 Y-179.9 H0 Z-99999
                G30 P4 X-155.8 Y-89.95 H0 Z-99999
                G30 P5 X-155.8 Y89.95 H0 Z-99999
                G30 P6 X0 Y89.9 H0 Z-99999
                G30 P7 X77.86 Y44.95 H0 Z-99999
                G30 P8 X77.86 Y-44.95 H0 Z-99999
                G30 P9 X0 Y-89.9 H0 Z-99999
                G30 P10 X-77.86 Y-44.95 H0 Z-99999
                G30 P11 X-77.86 Y44.95 H0 Z-99999
                G30 P12 X0 Y0 H0 Z-99999 S6
                ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
                ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
                G29 ; grid map
                G30 results in a successful probe.
                Here is a video of it happening. This time it triggered after ramming the bed and grinding against it:
                https://imgur.com/a/axEAujM
                It seems to have a problem with that area on the second pass as well. I'm guessing it may have to do with the sensor wiring touching or coming into proximity with the magnets in the rods.
                undefined 1 Reply Last reply 11 Jun 2022, 23:10 Reply Quote 0
                  Phaedrux Moderator @Daniel_Lacroix
                  @daniel_lacroix said in Duet Smart Effector not triggering on first probe point:
                  Which ones fails? I can't tell from the video that one is failing.
                  undefined 1 Reply Last reply 12 Jun 2022, 03:46 Reply Quote 0
                    @phaedrux
                    The first point. I have since moved the wires away from the rods and am not getting any failures. It seems to have been the magnets in the rods interfering with the current going to and from the sensor.
                    undefined 1 Reply Last reply 12 Jun 2022, 06:28 Reply Quote 1
                    • undefined Phaedrux marked this topic as a question 12 Jun 2022, 05:13
                    • undefined Phaedrux has marked this topic as solved 12 Jun 2022, 05:13
                      dc42 administrators @Daniel_Lacroix
                      @phaedrux
                      Most likely you have a poor crimp connection and one of the wires was only making contact sometimes depending on the angle between the wire and the connector.
                      undefined 1 Reply Last reply 12 Jun 2022, 19:10 Reply Quote 0
                        Daniel_Lacroix @dc42
                        That's what I thought, too, so I reinstalled new crimps with no luck
                        2 out of 11
