    SD card not found
    sd card troubleshoot
    1.3k
    • Masterpc96undefined
      Masterpc96 @infiniteloop
      @infiniteloop ahh sorry 😅 I don't know because in duet website I normal cpu temp bed is on 100* but in chamber I have only 60* I have Voron 2.4
      infiniteloopundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
      • infiniteloopundefined
        infiniteloop @Masterpc96
        @masterpc96 said in SD card not found:
        That's rather hot. 🔥
        So you have the Duet mounted inside of your chamber? Do you actively cool the board?
        Masterpc96undefined 1 Reply Last reply Reply Quote 0
          jay_s_uk @Masterpc96
          @masterpc96 duet boards are typically rated for 85 degrees I believe
            @infiniteloop no it is under printer (outside the printer). on cpu I have about 28*C I have blower on board.
            jay_s_ukundefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
              @masterpc96 what do you have using 5v plugged into the board?
                I'm sorry, just had a look at the doku which says:
                Unfortunately the SAME54P20A chip used in the Duet 3 Mini 5+ does not have a functioning temperature sensor. In theory it does have an on-chip temperature sensor, but the errata document for the chip says it doesn't work. However, it has been enabled in RRF 3.3 as an experiment, and does appear to give useful readings on the samples tested.
                So we cannot trust the MCU temps. Your 100°C reading can be far off.
                For the arrangement of the blower, the same document states:
                If active cooling is needed then a fan blowing across the back of the board along the line of the stepper drivers is recommended.
                Aside from this, I wonder why U1 would "desolder". Have you an impression how hot this chip becomes during operation?
                  @infiniteloop no I don't how hot it is. But blower is connected to 12V and it works all time it blows on all board
                  infiniteloopundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                    @masterpc96 Then, I don't think the "desoldering" is related to insufficient cooling. Maybe you should answer @jay_s_uk's question about what 5V you have plugged into the board. Other than that, I can only imagine a defective U1 running very hot - can you touch the chip with your fingertips for a second, or is it too hot for that exercise?
                      droftarts administrators @Masterpc96
                      @masterpc96 Are you sure it is U1 that is the problem? U1 is the Driver 0 stepper driver, not really connected in any way to the SD card socket, and at the other end of the board. Unless it has failed, and somehow shorting internally. Do you get any warnings that the stepper driver is overheating, or any other errors?
                      Masterpc96undefined 2 Replies Last reply Reply Quote 1
                        Can you post some photos of the soldering around the SD card socket and the repairs you've made?
                          Masterpc96 @Phaedrux
                          This post is deleted!
                            Masterpc96 @droftarts
                                @masterpc96 Soldering on the SD card socket looks okay. Is it U20 that you have reflowed? That is a CM1624−08DE which is an EMI Filter for MicroSD Interfaces.
                                  @droftarts Yes U20
                                    Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
