Duet 3 Mini 5+ and Loud Hiss from Z Motor
    blt3dp
    Hi All, I just finished assembling a Voron 0.1 using a Duet Mini 5+, MeanWell 24V PSU and a set of motors from Stepper Online (this set). I'm getting quite a loud hiss on the Z motor, generally all the time, but of course way more noticeable when it's idle.
    Nothing I know to do seems to have helped. Tried tweaking the motor current, idle factor and idle time. I've also tried adjusting M569 for that particular driver to switch between SpreadCycle and StealthChop. I've also tried disabling interpolation for that driver. Nothing seemed to have an effect.
    Here's my config.g
    ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
    ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Jun 03 2022 11:21:39 GMT-0700 (Pacific Daylight Time)
    M550 P"Voron" ; set printer name
    M669 K1 ; select CoreXY mode
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
    M92 X80.00 Y80.00 Z400.00 E1411.00 ; set steps per mm
    M566 X360.00 Y360.00 Z30.00 E360.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X12000.00 Y12000.00 Z900.00 E12000.00 ; set maximum speeds (mm/min)
    M201 X2000.00 Y2000.00 Z45.00 E200.00 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z280 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X0 Y0 Z0.1 S1 ; set axis minima
    M208 X120 Y120 Z120 S0 ; set axis maxima
    M574 X2 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io1.in
    M574 Y2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io2.in
    M574 Z1 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io3.in
    M558 P0 H5 F300 T12000 ; disable Z probe but set dive height, probe speed and travel speed
    M557 X20:100 Y20:100 S20 ; define mesh grid
    M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
    M307 H0 R0.535 K0.442:0.000 D3.99 E1.35 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
    M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
    M307 H1 R2.494 K0.474:0.000 D3.70 E1.35 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
    M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency
    M911 S21.9 R22.9 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
    Here's a link to the specific Z motor here
    Anyone have any suggestions?
    My 3D Printing YouTube Channel
    Better Living Through 3D Printing
    Follow me on Instagram and Twitter
    Instagram
    Twitter
    undefined 1 Reply Last reply 8 Jun 2022, 04:15 Reply Quote 0
      jumpedwithbothfeet @blt3dp
      @blt3dp have you tried swapping the motor/wiring with another to narrow down the cause?
      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
      undefined 2 Replies Last reply 8 Jun 2022, 04:26 Reply Quote 0
        blt3dp @jumpedwithbothfeet
        @jumpedwithbothfeet
        I can’t say I’ve tried that. It’s one of those motors with a detachable cable, I might be able to try that.
        But the motor seems to be working fine during homing and movement, just makes this hiss all the time. I’d have thought that if wiring were bad, it wouldn’t be working right.
        Instagram
        Twitter
          @jumpedwithbothfeet
          Swapped in another motor, used the same wiring, and config mostly (only changed steps per mm and current) and it's perfectly silent. While moving and while at idle. Of course I can't permanently use this motor as it doesn't have a short leadscrew attached. But something I noticed when I was looking at the original motor. When I put a multimeter on the pins to double check what pins were the ends of a coil, the beep from my multimeter would be scratchy/choppy, whereas on every other motor I've checked it beeps clear and steady. I'm starting to think it's something with this particular motor.
          Instagram
          Twitter
          undefined 1 Reply Last reply 8 Jun 2022, 17:08 Reply Quote 0
            blt3dp @blt3dp
            @blt3dp
            Well, LOL. I ended up cutting the leadscrew off of the "bad" motor and attached it to the other motor I had tested with. It's completely silent now.
            Instagram
            Twitter
            • undefined Phaedrux marked this topic as a question 8 Jun 2022, 18:13
            • undefined Phaedrux has marked this topic as solved 8 Jun 2022, 18:13
            2 out of 5
