    Macro for cleaning and purging nozzle
    Gcode meta commands
    6.2k
    • Exerqtorundefined
      Exerqtor @fcwilt
      @fcwilt said in Macro for cleaning and purging nozzle:
      @exerqtor
      The reason || works is you are checking for not homed via the exclamation point character proceeding the move.axes[#].homed value.
      You only need to find one not homed axis to have it be true, thus || works as desired.
      But when trying to determine if all axes are homed you need to check them all, thus the need for the &&.
      That makes sense! 😃
      As to my editor:
      The editor I am using is one I have used for years - EditPad Pro.
      It is somewhat quirky. Example, when something goes wrong, say a file cannot be accessed, the error message may end with "Bummer!".
      But it is very powerful and once learned you can do just about anything.
      The Duet boards support FTP which stands for File Transport Protocol. This means you can upload/download files using any FTP client.
      This editor supports FTP.
      It also has the concept of a Project - which is basically a group of files that you assign to a Project which you have created and named.
      When you open a Project it opens all the assigned files. When you close the Project it closes all the files.
      Things like find or replace can work across all the files in the Project.
      But the great thing for me is the the editor supports Projects using an FTP connection.
      So when I setup a Project correctly and associate it with the correct FTP connection, then when the Project is opened all the files are downloaded from the Duet and are available for editing.
      When a file is changed and saved it is automatically uploaded back to the Duet.
      That's a very brief overview.
      Okok, i'll check it out if i find working with spaces etc. in notepad to be to annoying. I'm using WinSCP to FTP into the duet if i need to work on the files in the printer allready but ther project functions sounds sweet though!
      Other than that i've made some small minute changes to the macro, but i think(?) the math is setup wrong with the parenthesis and stuff in some places.
      And the "loop" part for where it's supposed to actually wipe on the brush for the amout of times defined by var.wipe_qty don't seem to work. (Don't know if i'm just to dense or the fact that my programming skills is way bellow what it should be while working with conditional stuff. But i really miss some more examples of how to "make" the different functions etc. in the docs).
      • fcwiltundefined
        fcwilt @Exerqtor
        @exerqtor said in Macro for cleaning and purging nozzle:
        Okok, i'll check it out if i find working with spaces etc. in notepad to be to annoying. I'm using WinSCP to FTP into the duet if i need to work on the files in the printer allready but ther project finctions sounds sweet though!
        There are likely other good editors that have similar features. I know one called UltraEdit that has been around for ages.
        Be glad to look at it.
        Be glad to create some examples for you.
        Just let me know.
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @fcwilt
          I'll have a look at both once i've got some spare time to "waste" 🙂
          Just let me know.
          Sure, if you want to take a look at it you can use this(it's pretty much the same exactly the same as your V1), don't mind the stuff i've uncommented it's something i'm working on in parallell:
          nozzle_scrub_v1.1.g
          • Exerqtorundefined
            Exerqtor @Exerqtor
            Ok so now i've messed around some more with the macro and everything should be working EXCEPT the brush "loop".
            Wanna have a look @fcwilt ?
            nozzle_scrub_v1.2.g
            fcwiltundefined 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @Exerqtor
              nozzle_scrub_v1.2.g
              Sure. Downloading it now.
              What is the problem with the "loop"?
              • fcwiltundefined
                fcwilt @Exerqtor
                @exerqtor
                Aren't you seeing warnings about mixed indentation (tabs and spaces)?
                I am seeing a lot of tab characters.
                • Exerqtorundefined
                  Exerqtor @fcwilt
                  nozzle_scrub_v1.2.g
                  Well it just don't loop i guess? it just does one brush motion and stops.
                  @exerqtor
                  Haven't tried running it yet, but it shouldn't be many tabs? ( I forgot using spaces on those few lines i added after the last time you looked at it).
                  This should be purged for any tabs (i think lol):
                  nozzle_scrub_v1.3.g
                  • fcwiltundefined
                    fcwilt @Exerqtor
                    Haven't tried running it yet, but it should be many tabs? ( I forgot using spaces on those few lines i added after the last time you looked at it).
                    I would be glad to buy you a proper editor - it would make my "proof reading" easier as I wouldn't have to try to work out what the indentation was supposed to be.
                    • Exerqtorundefined
                      Exerqtor @fcwilt
                      Haha i THINK all the indentations should be spaces now, it was some left in the clear lines i didn't know about. Sorry for making it harder than it should😮
                      • fcwiltundefined
                        fcwilt @Exerqtor
                        I can buy a copy of EditPad online and license it to you. Then you can download it and start to use it today.
                        • fcwiltundefined
                          fcwilt @Exerqtor
                          @exerqtor
                          I made a change to first test for non-homed axes. It eliminates that else all the way at the end of the file. It tests and if it fails it warns you and aborts.
                          And I added a missing S parameter to a M118. Given the other times you used echo what was the reason for the M118?
                          nozzle_scrub_v1.3_fcw.g
                          • Exerqtorundefined
                            Exerqtor @fcwilt
                            I really appreciate the offer, but i think it's to much to ask of you to buy me a license. It's EditPad Pro you were vouching for right? I'll actually sit my ass down and take a good look at it now.
                            @exerqtor
                            Ah cool, much better way of doing it for sure!
                            To be honest the M118's was just some "garbage" i put in there while i started to retrofit the macro from Klipper to RRF, and since it wasn't mission critical i didn't care to do anything about it until i had other stuff fixed.
                            For reference the klipper macro i worked off is this one:
                            https://github.com/VoronDesign/VoronUsers/blob/master/abandoned_mods/printer_mods/edwardyeeks/Decontaminator_Purge_Bucket_%26_Nozzle_Scrubber/Macros/nozzle_scrub.cfg
                            I did one little itteration where i removed some of the uncommented code and fixed a bug where i had called for "var.brush_gap" instead of "var.bucket_gap" in line 151.
                            So now it works, loops and all. BUT i get Error: in file macro line 169 column 209: G1: expected ')' and i can't really understand what part of the equation it's refering to when i look at the code.
                            nozzle_scrub_v1.4.g
                            • Exerqtorundefined
                              Exerqtor @Exerqtor
                              I figured out what was wrong with line 169 (as i'm sure you will the secound you have a look at it even though it took me like 20min lol).
                              I also streamlined the "var.brush_oh" calculation in line 153 and fixed the timeout for the message in line 137.
                              Lastly i added M400 at the end before M118 so that it would actually be finished with the moves before saying so.
                              nozzle_scrub_v1.5.g
                              • fcwiltundefined
                                fcwilt @Exerqtor
                                nozzle_scrub_v1.5.g
                                Glad to hear it is working for you.
                                I have to ask - what the heck is this code for? 🤔 🤔 🤔 🤔
                                G1 X{208.5 + ((23.5 - 12.5) / (2 - 1)) + (1 * 25) + (1 * ((12.5 + ((35.5 / 2) + (1 x 12.5))} ; code with overhang compensation
                                Everything there is a constant - why not just do the math and enter the result?
                                Back to perusing the file.
                                • fcwiltundefined
                                  fcwilt @Exerqtor
                                  @exerqtor
                                  G4 with a S parameter is the time in seconds no need to do the math below:
                                  G4 P{var.ooze_dwell * 1000}
                                  As to the rest of your code - your math teachers must have loved you.
                                  Clever but harder to understand than simple conditional code.
                                  Do you have a video of this brushing thing?
                                  • Exerqtorundefined
                                    Exerqtor @fcwilt
                                    @fcwilt
                                    Hahaha it's the math for the code above, i needed to visualize what i tried to do and forgot to remove it. It's NOT meant to be in there and won't be once i get everything working 100%
                                    Looks like i've got a bug or two to iron out, when the hotend is hot and it actually does a purge it purges outside the damned purge bin 🤣 But that will have to be a challenge for tomorrow.
                                    @exerqtor
                                    Good catch, i'll change that right away.
                                    Clever but harder to understand than simply conditional code.
                                    I can't take the credit for the math in that code, i've done adjustments to make it suit what i want and added a variable here and there. But the bulk of it is made by a user/users from the Voron discord.
                                    Tbh i think the next step here is to make the purge point selection etc. conditional so that that long ass equation can be emited.
                                    I'll take a video tomorrow and post here, want to get that damn purge position to work first😃
                                    • fcwiltundefined
                                      fcwilt @Exerqtor
                                      @exerqtor
                                      I will look at the intro more closely and see if I can fully understand what is the goal.
                                      I'm retired but I was a programmer for 30+ years.
                                      My gut tells me that code is more complicated than it needs to be.
                                      But to be sure I have know what the intent of the processes are.
                                      • Exerqtorundefined
                                        Exerqtor @fcwilt
                                        @fcwilt The over all goal with the random part is to split up what purge bucket (left/right) is used so that they don't fill up as fast.
                                        And with that also make it "random" if the scrub starts right to left or left to right depending on where it did the purge.
                                        I'm at work now so i can't look at the code to give an better explanation, but it's the main goal.
                                        • fcwiltundefined
                                          fcwilt @Exerqtor
                                          I'm at work now so i can't look at the code to give an better explenation, but it's the main goal.
                                          I hope you will be able to make a quick video or some pictures. I would like to see what the brush and buckets are. I only know them from theory. Never actually seen any.
                                          • Exerqtorundefined
                                            Exerqtor @fcwilt
                                            @fcwilt I shot a short clip yesterday before i fixed the bug in line 169. But it shows what i'm trying to do, the clip was with the hotend off since i wanted to check that it didn't try to purge or flipped out while it was cold.
                                            As for the brush and bucket combo it's derived from this: https://github.com/VoronDesign/VoronUsers/tree/master/abandoned_mods/printer_mods/edwardyeeks/Decontaminator_Purge_Bucket_&_Nozzle_Scrubber
