    Macro for cleaning and purging nozzle
    Gcode meta commands
    6.1k
    • fcwiltundefined
      fcwilt @Exerqtor
      @exerqtor said in Macro for cleaning and purging nozzle:
      Ok so now i've messed around some more with the macro and everything should be working EXCEPT the brush "loop".
      Wanna have a look @fcwilt ?
      nozzle_scrub_v1.2.g
      Sure. Downloading it now.
      What is the problem with the "loop"?
      • fcwiltundefined
        fcwilt @Exerqtor
        @exerqtor
        Aren't you seeing warnings about mixed indentation (tabs and spaces)?
        I am seeing a lot of tab characters.
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @fcwilt
          @fcwilt said in Macro for cleaning and purging nozzle:
          nozzle_scrub_v1.2.g
          Well it just don't loop i guess? it just does one brush motion and stops.
          @exerqtor
          Haven't tried running it yet, but it shouldn't be many tabs? ( I forgot using spaces on those few lines i added after the last time you looked at it).
          This should be purged for any tabs (i think lol):
          nozzle_scrub_v1.3.g
          • fcwiltundefined
            fcwilt @Exerqtor
            Haven't tried running it yet, but it should be many tabs? ( I forgot using spaces on those few lines i added after the last time you looked at it).
            I would be glad to buy you a proper editor - it would make my "proof reading" easier as I wouldn't have to try to work out what the indentation was supposed to be.
            • Exerqtorundefined
              Exerqtor @fcwilt
              Haha i THINK all the indentations should be spaces now, it was some left in the clear lines i didn't know about. Sorry for making it harder than it should😮
              fcwiltundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @Exerqtor
                I can buy a copy of EditPad online and license it to you. Then you can download it and start to use it today.
                • fcwiltundefined
                  fcwilt @Exerqtor
                  @exerqtor
                  I made a change to first test for non-homed axes. It eliminates that else all the way at the end of the file. It tests and if it fails it warns you and aborts.
                  And I added a missing S parameter to a M118. Given the other times you used echo what was the reason for the M118?
                  nozzle_scrub_v1.3_fcw.g
                  • Exerqtorundefined
                    Exerqtor @fcwilt
                    I really appreciate the offer, but i think it's to much to ask of you to buy me a license. It's EditPad Pro you were vouching for right? I'll actually sit my ass down and take a good look at it now.
                    @exerqtor
                    Ah cool, much better way of doing it for sure!
                    To be honest the M118's was just some "garbage" i put in there while i started to retrofit the macro from Klipper to RRF, and since it wasn't mission critical i didn't care to do anything about it until i had other stuff fixed.
                    For reference the klipper macro i worked off is this one:
                    https://github.com/VoronDesign/VoronUsers/blob/master/abandoned_mods/printer_mods/edwardyeeks/Decontaminator_Purge_Bucket_%26_Nozzle_Scrubber/Macros/nozzle_scrub.cfg
                    I did one little itteration where i removed some of the uncommented code and fixed a bug where i had called for "var.brush_gap" instead of "var.bucket_gap" in line 151.
                    So now it works, loops and all. BUT i get Error: in file macro line 169 column 209: G1: expected ')' and i can't really understand what part of the equation it's refering to when i look at the code.
                    nozzle_scrub_v1.4.g
                    • Exerqtorundefined
                      Exerqtor @Exerqtor
                      I figured out what was wrong with line 169 (as i'm sure you will the secound you have a look at it even though it took me like 20min lol).
                      I also streamlined the "var.brush_oh" calculation in line 153 and fixed the timeout for the message in line 137.
                      Lastly i added M400 at the end before M118 so that it would actually be finished with the moves before saying so.
                      nozzle_scrub_v1.5.g
                      • fcwiltundefined
                        fcwilt @Exerqtor
                        nozzle_scrub_v1.5.g
                        Glad to hear it is working for you.
                        I have to ask - what the heck is this code for? 🤔 🤔 🤔 🤔
                        G1 X{208.5 + ((23.5 - 12.5) / (2 - 1)) + (1 * 25) + (1 * ((12.5 + ((35.5 / 2) + (1 x 12.5))} ; code with overhang compensation
                        Everything there is a constant - why not just do the math and enter the result?
                        Back to perusing the file.
                        • fcwiltundefined
                          fcwilt @Exerqtor
                          @exerqtor
                          G4 with a S parameter is the time in seconds no need to do the math below:
                          G4 P{var.ooze_dwell * 1000}
                          As to the rest of your code - your math teachers must have loved you.
                          Clever but harder to understand than simple conditional code.
                          Do you have a video of this brushing thing?
                          • Exerqtorundefined
                            Exerqtor @fcwilt
                            @fcwilt
                            Hahaha it's the math for the code above, i needed to visualize what i tried to do and forgot to remove it. It's NOT meant to be in there and won't be once i get everything working 100%
                            Looks like i've got a bug or two to iron out, when the hotend is hot and it actually does a purge it purges outside the damned purge bin 🤣 But that will have to be a challenge for tomorrow.
                            @exerqtor
                            Good catch, i'll change that right away.
                            Clever but harder to understand than simply conditional code.
                            I can't take the credit for the math in that code, i've done adjustments to make it suit what i want and added a variable here and there. But the bulk of it is made by a user/users from the Voron discord.
                            Tbh i think the next step here is to make the purge point selection etc. conditional so that that long ass equation can be emited.
                            I'll take a video tomorrow and post here, want to get that damn purge position to work first😃
                            • fcwiltundefined
                              fcwilt @Exerqtor
                              @exerqtor
                              I will look at the intro more closely and see if I can fully understand what is the goal.
                              I'm retired but I was a programmer for 30+ years.
                              My gut tells me that code is more complicated than it needs to be.
                              But to be sure I have know what the intent of the processes are.
                              • Exerqtorundefined
                                Exerqtor @fcwilt
                                @fcwilt The over all goal with the random part is to split up what purge bucket (left/right) is used so that they don't fill up as fast.
                                And with that also make it "random" if the scrub starts right to left or left to right depending on where it did the purge.
                                I'm at work now so i can't look at the code to give an better explanation, but it's the main goal.
                                • fcwiltundefined
                                  fcwilt @Exerqtor
                                  I'm at work now so i can't look at the code to give an better explenation, but it's the main goal.
                                  I hope you will be able to make a quick video or some pictures. I would like to see what the brush and buckets are. I only know them from theory. Never actually seen any.
                                  • Exerqtorundefined
                                    Exerqtor @fcwilt
                                    @fcwilt I shot a short clip yesterday before i fixed the bug in line 169. But it shows what i'm trying to do, the clip was with the hotend off since i wanted to check that it didn't try to purge or flipped out while it was cold.
                                    As for the brush and bucket combo it's derived from this: https://github.com/VoronDesign/VoronUsers/tree/master/abandoned_mods/printer_mods/edwardyeeks/Decontaminator_Purge_Bucket_&_Nozzle_Scrubber
                                    • fcwiltundefined
                                      fcwilt @Exerqtor
                                      I see the brush, look like brass but I don't see any little buckets. 😉
                                      What did you use for the brush? Any concerns for damaging the nozzle?
                                      • Exerqtorundefined
                                        Exerqtor @fcwilt
                                        Not a video, but it's at least the buckets! 🤣
                                        Not really too woried about nozzle wear to be honest, but if it turns out to be a problem other brush types is a posibility 😊
                                        • fcwiltundefined
                                          fcwilt @Exerqtor
                                          @exerqtor
                                          Thanks much.
                                          Now I understand the needs of the process.
                                          • Exerqtorundefined
                                            Exerqtor @fcwilt
                                            @fcwilt
                                            Goodie!
                                            As a sidenote, i downloaded the EditPad Pro demo yesterday and it for sure has alot more to offer than what i've been using! BUT, have you made or dug up a syntax highlighting profile for RRF? 😬
