Macro for cleaning and purging nozzle
@exerqtor said in Macro for cleaning and purging nozzle:
Okok, i'll check it out if i find working with spaces etc. in notepad to be to annoying. I'm using WinSCP to FTP into the duet if i need to work on the files in the printer allready but ther project finctions sounds sweet though!
There are likely other good editors that have similar features. I know one called UltraEdit that has been around for ages.
Other than that i've made some small minute changes to the macro, but i think(?) the math is setup wrong with the parenthesis and stuff in some places.
Be glad to look at it.
And the "loop" part for where it's supposed to actually wipe on the brush for the amout of times defined by var.wipe_qty don't seem to work. (Don't know if i'm just to dense or the fact that my programming skills is way bellow what it should be while working with conditional stuff. But i really miss some more examples of how to "make" the different functions etc. in the docs).
Be glad to create some examples for you.
Just let me know.
@fcwilt said in Macro for cleaning and purging nozzle:
I'll have a look at both once i've got some spare time to "waste"
Just let me know.
Sure, if you want to take a look at it you can use this(it's pretty much the same exactly the same as your V1), don't mind the stuff i've uncommented it's something i'm working on in parallell:
nozzle_scrub_v1.1.g -
Ok so now i've messed around some more with the macro and everything should be working EXCEPT the brush "loop".
Wanna have a look @fcwilt ?
nozzle_scrub_v1.2.g -
nozzle_scrub_v1.2.gSure. Downloading it now.
What is the problem with the "loop"?
Aren't you seeing warnings about mixed indentation (tabs and spaces)?
I am seeing a lot of tab characters.
Well it just don't loop i guess? it just does one brush motion and stops.
Haven't tried running it yet, but it shouldn't be many tabs? ( I forgot using spaces on those few lines i added after the last time you looked at it).
This should be purged for any tabs (i think lol):
nozzle_scrub_v1.3.g -
Haven't tried running it yet, but it should be many tabs? ( I forgot using spaces on those few lines i added after the last time you looked at it).
This should be purged for any tabs (i think lol):I would be glad to buy you a proper editor - it would make my "proof reading" easier as I wouldn't have to try to work out what the indentation was supposed to be.
Haha i THINK all the indentations should be spaces now, it was some left in the clear lines i didn't know about. Sorry for making it harder than it should
I can buy a copy of EditPad online and license it to you. Then you can download it and start to use it today.
I made a change to first test for non-homed axes. It eliminates that else all the way at the end of the file. It tests and if it fails it warns you and aborts.
And I added a missing S parameter to a M118. Given the other times you used echo what was the reason for the M118?
I really appreciate the offer, but i think it's to much to ask of you to buy me a license. It's EditPad Pro you were vouching for right? I'll actually sit my ass down and take a good look at it now.
Ah cool, much better way of doing it for sure!
To be honest the M118's was just some "garbage" i put in there while i started to retrofit the macro from Klipper to RRF, and since it wasn't mission critical i didn't care to do anything about it until i had other stuff fixed.For reference the klipper macro i worked off is this one:
https://github.com/VoronDesign/VoronUsers/blob/master/abandoned_mods/printer_mods/edwardyeeks/Decontaminator_Purge_Bucket_%26_Nozzle_Scrubber/Macros/nozzle_scrub.cfgI did one little itteration where i removed some of the uncommented code and fixed a bug where i had called for "var.brush_gap" instead of "var.bucket_gap" in line 151.
So now it works, loops and all. BUT i get
Error: in file macro line 169 column 209: G1: expected ')'
and i can't really understand what part of the equation it's refering to when i look at the code.
nozzle_scrub_v1.4.g -
I figured out what was wrong with line 169 (as i'm sure you will the secound you have a look at it even though it took me like 20min lol).
I also streamlined the "var.brush_oh" calculation in line 153 and fixed the timeout for the message in line 137.
Lastly i added M400 at the end before M118 so that it would actually be finished with the moves before saying so.
Glad to hear it is working for you.
I have to ask - what the heck is this code for?
G1 X{208.5 + ((23.5 - 12.5) / (2 - 1)) + (1 * 25) + (1 * ((12.5 + ((35.5 / 2) + (1 x 12.5))} ; code with overhang compensation
Everything there is a constant - why not just do the math and enter the result?
Back to perusing the file.
G4 with a S parameter is the time in seconds no need to do the math below:
G4 P{var.ooze_dwell * 1000}
As to the rest of your code - your math teachers must have loved you.
Clever but harder to understand than simple conditional code.
Do you have a video of this brushing thing?
Hahaha it's the math for the code above, i needed to visualize what i tried to do and forgot to remove it. It's NOT meant to be in there and won't be once i get everything working 100%
Looks like i've got a bug or two to iron out, when the hotend is hot and it actually does a purge it purges outside the damned purge bin
But that will have to be a challenge for tomorrow.
Good catch, i'll change that right away.
Clever but harder to understand than simply conditional code.
I can't take the credit for the math in that code, i've done adjustments to make it suit what i want and added a variable here and there. But the bulk of it is made by a user/users from the Voron discord.
Tbh i think the next step here is to make the purge point selection etc. conditional so that that long ass equation can be emited.
I'll take a video tomorrow and post here, want to get that damn purge position to work first
I will look at the intro more closely and see if I can fully understand what is the goal.
I'm retired but I was a programmer for 30+ years.
My gut tells me that code is more complicated than it needs to be.
But to be sure I have know what the intent of the processes are.
@fcwilt The over all goal with the random part is to split up what purge bucket (left/right) is used so that they don't fill up as fast.
And with that also make it "random" if the scrub starts right to left or left to right depending on where it did the purge.
I'm at work now so i can't look at the code to give an better explanation, but it's the main goal.
I'm at work now so i can't look at the code to give an better explenation, but it's the main goal.
I hope you will be able to make a quick video or some pictures. I would like to see what the brush and buckets are. I only know them from theory. Never actually seen any.
@fcwilt I shot a short clip yesterday before i fixed the bug in line 169. But it shows what i'm trying to do, the clip was with the hotend off since i wanted to check that it didn't try to purge or flipped out while it was cold.
As for the brush and bucket combo it's derived from this: https://github.com/VoronDesign/VoronUsers/tree/master/abandoned_mods/printer_mods/edwardyeeks/Decontaminator_Purge_Bucket_&_Nozzle_Scrubber
I see the brush, look like brass but I don't see any little buckets.
What did you use for the brush? Any concerns for damaging the nozzle?
