Solved Problems with Duet 3 Mini 5+ WiFi
@unforgivenll said in Problems with Duet 3 Mini 5+ WiFi:
@phaedrux I received the new board thank you. I'm still having issues with the WIFI. It says it's connected but I can't connect to the web control. I tried setting a static IP and that doesn't work either. I've tried troubleshooting and making changes for most of the day and I am at a loss. Should it be this hard to get the WIFI connected to my network?
Are you still trying to use a "guest" network?
Please connect via YAT USB terminal and send M122 and copy paste the results here. Make sure you change the line endings so we can see the full report.
@fcwilt Yes I'm still using the same network.
Well, most "guest" WiFi setups don't allow communication between one "guest" and another.
@fcwilt I can try my main network but that didn't work either.
@fcwilt Okay, that seemed to do it. Thank you. It worked on that network before. I have another printer on the guest network connected and it is working correctly for 2 years now.
But were you trying to connect to the printer from another "guest"?
@fcwilt I had the original board connected on the guest ssid/network and with the exception of the wifi module not working properly it connected fine. I have a second printer on the same network.
@fcwilt I'm not sure what happened but it looks like even though the router showed as connected on that SSID, it wasn't working. I double checked after my last reply to you and the other printer couldn't connect either. Figures it was something simple. Sorry to bug you. Thank you for everything. I really appreciate it.
Glad to be of help when I can.
A typical WiFi "guest" setup is for guests to your home who want Internet access but you don't want them to have access to your network.
It generally provides a dedicated DHCP server to handout IP addresses to the guests and it prevents one guest from seeing another.
@fcwilt I understand. The only reason I set it up that way is because it wasn't working initially. I should have tried the main network first. I am having another issue with the new Moons motors I just received. I've tried every possible combination in the wiring and keep getting an out of phase error. Any idea what I'm doing wrong?
Have you identified the phase pairs?
@phaedrux Yes I have.
And do your pairs match what they show in the data sheet?
@phaedrux Yes they do.
And how are they connected to the Duet?
When do you get the out of phase errors?
Does that happen on every driver?
@phaedrux I get the error when I try to home it. Tried different drivers and different motors. The error comes up when I press home. After a second the motor turns in the correct direction and after about 20 seconds or so it stutters.
Can you share your config file?
And it happens to every driver and with different motors? The scope of the problem keeps creeping.
Can you also post your homing files if that's when the problem happens?
If you want to test movement on an unhomed axis use
G1 H2 Z10
for instance.
