    Problems with Duet 3 Mini 5+ WiFi
    3.8k
      Phaedrux Moderator @Unforgivenll
      @unforgivenll said in Problems with Duet 3 Mini 5+ WiFi:
      I keep have issues with the WiFi and the SD card getting corrupted.
      Can you be more specific about what the issues you are have are?
      See here for the kinds of info we're looking for to better provide assistance to you.
      https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
      • Unforgivenllundefined
        Unforgivenll @jay_s_uk
        @jay_s_uk Initially it would say it was connected but I couldn't get to the server. The IP it listed was actually the subnet mask for some reason. I realized it was having a problem with my router. I then setup a guest network and ran the online Reprap setup again and it was fine on first boot. Each subsequent boot it would show as connected but the status as idle. If I put the SD card back in the any PC it couldn't read the card un less I repaired it. I tried a few different SD cards with and was given the same issues and outcome. What is odd is if I ran the Reprap config again with the exact same settings and copied the files over to the card, It would boot fine exactly once each time. I am running the latest firmware and the board version is V1.0.config.g
          Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
          Unforgivenllundefined 2 Replies Last reply Reply Quote 0
            Unforgivenll @Phaedrux
            @phaedrux Thank you. I really appreciate your time.
              @phaedrux I received the new board thank you. I'm still having issues with the WIFI. It says it's connected but I can't connect to the web control. I tried setting a static IP and that doesn't work either. I've tried troubleshooting and making changes for most of the day and I am at a loss. Should it be this hard to get the WIFI connected to my network?
              • fcwiltundefined
                fcwilt @Unforgivenll
                Are you still trying to use a "guest" network?
                Unforgivenllundefined 1 Reply Last reply Reply Quote 0
                  Please connect via YAT USB terminal and send M122 and copy paste the results here. Make sure you change the line endings so we can see the full report.
                    Unforgivenll @fcwilt
                    @fcwilt Yes I'm still using the same network.
                    Duet 3 Mini 5 WIFI +.txt
                    • fcwiltundefined
                      Well, most "guest" WiFi setups don't allow communication between one "guest" and another.
                      Unforgivenllundefined 2 Replies Last reply Reply Quote 1
                        @fcwilt I can try my main network but that didn't work either.
                          @fcwilt Okay, that seemed to do it. Thank you. It worked on that network before. I have another printer on the guest network connected and it is working correctly for 2 years now.
                          • fcwiltundefined
                            But were you trying to connect to the printer from another "guest"?
                            • Phaedruxundefined Phaedrux has marked this topic as solved
                              @fcwilt I had the original board connected on the guest ssid/network and with the exception of the wifi module not working properly it connected fine. I have a second printer on the same network.
                                @fcwilt I'm not sure what happened but it looks like even though the router showed as connected on that SSID, it wasn't working. I double checked after my last reply to you and the other printer couldn't connect either. Figures it was something simple. Sorry to bug you. Thank you for everything. I really appreciate it.
                                fcwiltundefined 1 Reply Last reply Reply Quote 2
                                • fcwiltundefined
                                  @unforgivenll
                                  Glad to be of help when I can.
                                  A typical WiFi "guest" setup is for guests to your home who want Internet access but you don't want them to have access to your network.
                                  It generally provides a dedicated DHCP server to handout IP addresses to the guests and it prevents one guest from seeing another.
                                    @fcwilt I understand. The only reason I set it up that way is because it wasn't working initially. I should have tried the main network first. I am having another issue with the new Moons motors I just received. I've tried every possible combination in the wiring and keep getting an out of phase error. Any idea what I'm doing wrong?
                                    MS17HD4P4065.pdf
                                      Have you identified the phase pairs?
                                      https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting#identifying-the-stepper-motor-phases
                                        @phaedrux Yes I have.
                                          And do your pairs match what they show in the data sheet?
                                            @phaedrux Yes they do.
