    I could use some help
    682
    64.0k
      A Former User @A Former User
      @droftarts I LOVE doing that!
      fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @A Former User
        @mac said in I could use some help:
        OK now that we think the M574 commands are all correct you need to verify the endstop switches are all working.
        So switch to the DWC Console and type in M119 and press the enter key.
        Please post back what you see displayed as a result of the M119.
          @droftarts M119 reports: "X not stopped: Y not stopped, Z no endstop, Zprobe: not stopped
          A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
            @droftarts
            M552 S1                                            ; enable network
            M586 P0 S1                                         ; enable HTTP
            M586 P1 S0                                         ; disable FTP
            M586 P2 S0                                         ; disable Telnet
            M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
            M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
            M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
            M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
            M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
            M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
            M92 X80.00 Y80.00 Z4000.00 E420.00                 ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z600.00 E1200.00            ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z200.00 E250.00               ; set accelerations (mm/s^2)
            M906 X600 Y600 Z600 E600                           ; set motor currents (mA)
            M84 S0
              @droftarts check out the existing M92 line.
              droftartsundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                droftarts administrators @A Former User
                @mac I think those M92 numbers should be halved.
                • fcwiltundefined
                  We are making progress.
                  After you edited the config.g file and updated the M574 command for the Z endstop did you re-boot your printer to cause the changes to the config.g file to take effect?
                  The M119 reported no Z endstop so I am thinking the changes you posted were not applied by re-boot.
                    A Former User @fcwilt
                    @fcwilt
                    M92 X40.00 Y40.00 Z2000.00 E420.00                 ; set steps per mm
                      @droftarts I've been saving and rebooting after each change (after the last few changes, but not the first two).
                      • fcwiltundefined
                        Hi mac.
                        It seems you may have missed the post I made about the benefit of placing the M92 command before the M350 command.
                        There is no downside to doing so and it allows you to make changes to the M350 command, if you wish to experiment, without having to change the M92 command, once the M92 command is correct for 16x micro-stepping.
                        • fcwiltundefined
                          I see the problem with the M574 for the Z endstop.
                          The command has an S2 when it should be S1.
                          Edit and re-boot, then execute M119 again.
                          We are close to getting homing working.
                            @fcwilt I'm still considering your M92 edit (moving it to ABOVE the M350 line). Can I simply copy and paste? Will the form renumber itself?
                            • fcwiltundefined
                              Yes, you can cut-and-paste a line of code with no problems.
                                @droftarts
                                M574 X1 S1 P"!io5.in"                              ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !io5.in
                                M574 Y1 S1 P"!io6.in"                              ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !io6.in
                                M574 Z1 S1 P"io2.in"                                       ; configure Z-probe endstop for low end on Z
                                • fcwiltundefined
                                  @droftarts
                                  Great!
                                  Now execute the M119 again and let us know what is reports.
                                    @droftarts new M119: X not stopped, Y not stopped, Z at min stop, Z probe not stopped
                                      @droftarts the print head's six inches off the bed
                                      • fcwiltundefined
                                        Great!
                                        Notice that it says Z at min stop - was the Z endstop switch actually closed when you ran the M119?
                                        • fcwiltundefined
                                          I just asked a related question about the Z endstop switch.
                                          Now you need to find a way to execute the M119 while both the X and Y endstop switches are closed - maybe with a bit of tape or a rubber band?
                                            @fcwilt the only thing that would close the z endstop is if the X axis came down and closed it.
