    I could use some help
    682
    65.0k
      A Former User @fcwilt
      @fcwilt
      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X40.00 Y40.00 Z2000.00 E420.00                 ; set steps per mm
        A Former User @A Former User
        @droftarts I've been saving and rebooting after each change (after the last few changes, but not the first two).
        • fcwiltundefined
          fcwilt @A Former User
          @mac said in I could use some help:
          @droftarts check out the existing M92 line.
          Hi mac.
          It seems you may have missed the post I made about the benefit of placing the M92 command before the M350 command.
          There is no downside to doing so and it allows you to make changes to the M350 command, if you wish to experiment, without having to change the M92 command, once the M92 command is correct for 16x micro-stepping.
          • fcwiltundefined
            I see the problem with the M574 for the Z endstop.
            The command has an S2 when it should be S1.
            Edit and re-boot, then execute M119 again.
            We are close to getting homing working.
              @fcwilt I'm still considering your M92 edit (moving it to ABOVE the M350 line). Can I simply copy and paste? Will the form renumber itself?
              fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                Yes, you can cut-and-paste a line of code with no problems.
                  @droftarts
                  M574 X1 S1 P"!io5.in"                              ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !io5.in
                  M574 Y1 S1 P"!io6.in"                              ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !io6.in
                  M574 Z1 S1 P"io2.in"                                       ; configure Z-probe endstop for low end on Z
                  • fcwiltundefined
                    @droftarts
                    Great!
                    Now execute the M119 again and let us know what is reports.
                      @droftarts new M119: X not stopped, Y not stopped, Z at min stop, Z probe not stopped
                      A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                        @droftarts the print head's six inches off the bed
                        • fcwiltundefined
                          Great!
                          Notice that it says Z at min stop - was the Z endstop switch actually closed when you ran the M119?
                          • fcwiltundefined
                            I just asked a related question about the Z endstop switch.
                            Now you need to find a way to execute the M119 while both the X and Y endstop switches are closed - maybe with a bit of tape or a rubber band?
                              @fcwilt the only thing that would close the z endstop is if the X axis came down and closed it.
                                @fcwilt wait, fcwilt? not droftarts? jeeze you guys are ganging up on me!
                                • fcwiltundefined
                                  OK that's good to know.
                                  If the white wire is actually connected to the NO connection of the Z endstop switch it should not be indicating Z at min stop.
                                  Find a way to close the Z endstop switch and execute M119.
                                  I want to see if it still reports Z at min stop or if it reports something different.
                                    @droftarts @fcwilt if we're going to work on this together, I need to know you two are in agreement before I do anything.
                                    Do you both agree that I should tape X and Y closed? Then M119 again?
                                    fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                    • fcwiltundefined
                                      No - it just gets confusing when posts overlap in time.
                                      I'm typing, your typing, droftarts is typing - and things get a bit out of order - time wise.
                                      • fcwiltundefined
                                        Mac! You've cut me to the quick! Have you no faith in me! 😉
                                        I've only been doing this stuff for years.
                                          @fcwilt @droftarts I closed the z-endstop with my left finger, and hit M110 Send with my right finger. M119 reported Z: at end stop, Z probe: not stopped.
                                          I'm not making this up, guys.
                                            @fcwilt @droftarts I'm just trying to be respectful to Ian and you.
