    I could use some help
    682
    64.0k
      A Former User @A Former User
      @droftarts @fcwilt I wonder where that puts us?
      • fcwiltundefined
        fcwilt @A Former User
        @mac said in I could use some help:
        @fcwilt @droftarts FREAKIN' SUCCESS!
        With all of the endstops up, all of them are off, with Y endstop depressed, it is at min stop. with Z depressed, it is at min stop, and with X depressed, it is at MIN STOP!
        Congrats.
        Now that you know the endstops are working you can proceed to fine tune your homing code.
        Because you have a Z endstop you can start with that.
        One Z is homed then homing X and Y is a piece of cake.
        How about doing one at a time.
        Please post your Z homing code which should be in homeZ.g
          A Former User @fcwilt
          @fcwilt
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 06:45:01 GMT-0700 (Pacific Daylight Time)
          G91                      ; relative positioning
          G1 H2 Z5 F3600           ; lift Z relative to current position
          G90                      ; absolute positioning
          G1 X-10.875 Y4.375 F3600 ; go to first probe point
          G30                      ; home Z by probing the bed
          ;G91                     ; relative positioning
          ;G1 Z5 F60               ; lift Z relative to current position
          ;G90                     ; absolute positioning
          • fcwiltundefined
            @mac
            OK that is code for homing with a Z probe.
            Now that you have a working Z endstop you can use simpler code.
            Something like:
            G91               ; relative movements
            G1 H1 Z-250 F3600 ; fast move toward Z endstop
            G1 Z10            ; backup off a bit
            G1 H1 Z-15 F360   ; slow move toward Z endstop
            G90               ; absolute movements
            G1 Z10 F3600      ; move to 10mm off the bed to allow X and Y movements
              @fcwilt so you're saying I can copy and paste your suggestion into the homez.g, correct?
              • fcwiltundefined
                As long as you make sure none of the existing code is there.
                Or you can rename the existing file if you want to save it.
                And then create a new homeZ.g file and paste what I posted into it.
                  @fcwilt So, I copy what's there from G91 to G30, delete that, then copy your code to that space to replace what was there, correct?
                  Doing that preserves the first 4 lines of code, and the last 6 lines as well.
                  • fcwiltundefined
                    Well if you wish to preserve those 2 or 3 first lines, that's fine.
                    But you don't need any code other than what I posted.
                      @fcwilt I just concerned that if I delete everything, then paste your code into that blank space, I'll loose the ; homez.g (header)?
                      It's not that I don't trust you, I've just never done any coding.
                      A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                        @fcwilt okay, done
                          @fcwilt on to Y, X?
                            @fcwilt or should we test Z?
                            • fcwiltundefined
                              Just open the file, move down after the header lines, delete everything there to the end and paste what I posted into the blank space after the header.
                              Even if you did accidently delete the header lines you could simply type them in again.
                              ; homeZ.g
                                @fcwilt or are they related such that we have to do all 3 first, then test?
                                  @fcwilt I see, but the header is in the list of files. it makes for a cleaner look, I think.
                                  • fcwiltundefined
                                    You can test homing Z and see if it works.
                                    Then we will do X and Y.
                                    • fcwiltundefined
                                      Absolutely - I include headers and footers.
                                      ; === homeZ.g BOF ===
                                      ;  the actual code would go here
                                      ; === homeZ.g EOF ===
                                      Just FYI, BOF is for "beginning of file", EOF is for "end of file"
                                        @fcwilt so you write the code, but you don't put the line numbers in; that's what the program you write the code in does?
                                        And the === before what you wrote, and the === after what you wrote create the idea of a "Header?"
                                        fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
                                        • fcwiltundefined
                                          The part at the top of the file is the "header"
                                          The part at the bottom of the file is the "footer"
                                          I actually put more than I posted into the header and footer - I was just posting a simple example.
                                            @fcwilt link text
                                            Here’s a link to the video of Z’s first attempt at homing.
