    I could use some help
    682
    64.0k
    • fcwiltundefined
      fcwilt @A Former User
      @mac said in I could use some help:
      @fcwilt @droftarts FREAKIN' SUCCESS!
      With all of the endstops up, all of them are off, with Y endstop depressed, it is at min stop. with Z depressed, it is at min stop, and with X depressed, it is at MIN STOP!
      Congrats.
      Now that you know the endstops are working you can proceed to fine tune your homing code.
      Because you have a Z endstop you can start with that.
      One Z is homed then homing X and Y is a piece of cake.
      How about doing one at a time.
      Please post your Z homing code which should be in homeZ.g
        A Former User @fcwilt
        @fcwilt
        ; homez.g
        ; called to home the Z axis
        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 06:45:01 GMT-0700 (Pacific Daylight Time)
        G91                      ; relative positioning
        G1 H2 Z5 F3600           ; lift Z relative to current position
        G90                      ; absolute positioning
        G1 X-10.875 Y4.375 F3600 ; go to first probe point
        G30                      ; home Z by probing the bed
        ;G91                     ; relative positioning
        ;G1 Z5 F60               ; lift Z relative to current position
        ;G90                     ; absolute positioning
        • fcwiltundefined
          @mac
          OK that is code for homing with a Z probe.
          Now that you have a working Z endstop you can use simpler code.
          Something like:
          G91               ; relative movements
          G1 H1 Z-250 F3600 ; fast move toward Z endstop
          G1 Z10            ; backup off a bit
          G1 H1 Z-15 F360   ; slow move toward Z endstop
          G90               ; absolute movements
          G1 Z10 F3600      ; move to 10mm off the bed to allow X and Y movements
            @fcwilt so you're saying I can copy and paste your suggestion into the homez.g, correct?
            • fcwiltundefined
              As long as you make sure none of the existing code is there.
              Or you can rename the existing file if you want to save it.
              And then create a new homeZ.g file and paste what I posted into it.
                @fcwilt So, I copy what's there from G91 to G30, delete that, then copy your code to that space to replace what was there, correct?
                Doing that preserves the first 4 lines of code, and the last 6 lines as well.
                • fcwiltundefined
                  Well if you wish to preserve those 2 or 3 first lines, that's fine.
                  But you don't need any code other than what I posted.
                    @fcwilt I just concerned that if I delete everything, then paste your code into that blank space, I'll loose the ; homez.g (header)?
                    It's not that I don't trust you, I've just never done any coding.
                    A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                      A Former User @A Former User
                      @fcwilt okay, done
                        @fcwilt on to Y, X?
                          @fcwilt or should we test Z?
                          • fcwiltundefined
                            Just open the file, move down after the header lines, delete everything there to the end and paste what I posted into the blank space after the header.
                            Even if you did accidently delete the header lines you could simply type them in again.
                            ; homeZ.g
                              @fcwilt or are they related such that we have to do all 3 first, then test?
                                @fcwilt I see, but the header is in the list of files. it makes for a cleaner look, I think.
                                • fcwiltundefined
                                  You can test homing Z and see if it works.
                                  Then we will do X and Y.
                                  • fcwiltundefined
                                    Absolutely - I include headers and footers.
                                    ; === homeZ.g BOF ===
                                    ;  the actual code would go here
                                    ; === homeZ.g EOF ===
                                    Just FYI, BOF is for "beginning of file", EOF is for "end of file"
                                      @fcwilt so you write the code, but you don't put the line numbers in; that's what the program you write the code in does?
                                      And the === before what you wrote, and the === after what you wrote create the idea of a "Header?"
                                      fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
                                      • fcwiltundefined
                                        The part at the top of the file is the "header"
                                        The part at the bottom of the file is the "footer"
                                        I actually put more than I posted into the header and footer - I was just posting a simple example.
                                          @fcwilt link text
                                          Here’s a link to the video of Z’s first attempt at homing.
                                            @fcwilt Z's going backwards. When I click on Z+0.5 it goes DOWN.
                                            droftartsundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
