I could use some help
@droftarts kids need their Dad, I had 3 (they're all adults now, although the oldest is living with us currently). Thank you for being so helpful Ian!
@fcwilt are we okay even though the code still says "forwards?"
@mac said in I could use some help:
Everything after the ; character is just a comment - it affects nothing - you could put a line from a Shakespeare play there and it would make no difference at all.
All that matters is you find the right S parameter so the Z axis moves in the correct direction.
And the same is true for X and Y - if it turns out they are not moving in the correct direction.
@droftarts said in I could use some help:
@fcwilt look at his bed. It’s not 10mm cast aluminium plate, well-constrained and moving on linear rails. It’s a (please forgive me, @Mac ) cheap bedslinger setup. He’s going to need mesh compensation to have half a chance getting the first layer to stick. The probe was working fine. Fiddling around with a Z min endstop is excruciating with flimsy beds.
Doing kids bath and bed. Not around for a while.
Rest assured Mesh Bed Compensation will be implemented.
One small step at a time.
@fcwilt got it, I've offended you. Please accept my apologies. I've spent 70 years making life miserable for others. It's hard to get out of that habit.
@fcwilt I'm not opposed to buying a decent bed. Given that the one I have on this printer now has failed the PID tests horribly, I'm looking for a good bed. Any recommendations you can provide (preferably links that will make you some money), would be appreciated.
I'm not offended at all.
I'm glad we are making progress.
I hope we can get Z working.
If we can do that, I think you can get X and Y working on your own since the issues are the same and the homing code is pretty much the same, just specifying a different axis.
I am running out of time today though.
@fcwilt My BLV rebuild of my old Anet A8 had linear rails. Marvelous kit, those. I still have them, and putting them on this POS seems possible with a little elbow grease and a drill press (both of which I have).
@fcwilt got it, ship me the X and Y code please. I'll test Z right now to confirm that the changes accomplished what I may have to use to correct X and Y if they aren't up to snuff.
I know very little about your type of printer. I know that some popular models have upgrade parts available from different sources.
I just upgraded the bed on my E3D Tool Changer printer with a bed from Mandela Rose Works (I think that is the correct spelling).
@fcwilt Z went up, and then it went down. It sounded like a real printer / that's a first. My guess is, it's about 30mm off the bed at the moment. I think that was a choice in the RRF? That the first time Z homed, it stopped at 30 above?
@fcwilt I'll google them and go from there.
@fcwilt if you have the time, please send the X and Y code, then be off with you to your own time, and thank you in advance.
OK
Homing X should look something like this:
G91 G1 H1 X-230 F3600 G1 X15 G1 H1 X-10 F360 G90 G1 X110 F3600 ; this just moves X to the centerline of the bed - doesn't matter where - it can be any place at all that suits you. Homing Y should look something like this:
G91 G1 H1 Y-230 F3600 G1 Y15 G1 H1 Y-10 F360 G90 G1 Y110 F3600 ; this just moves Y to the centerline of the bed - doesn't matter where - it can be any place at all that suits you. Now I would do homeall.g like this:
M98 P"homeZ.g"
M98 P"homeX.g"
M98 P"homeY.g"It is not as efficient as it can be but it does re-use the code you already have in the other axis homing files.
Now I have no idea what kinds of speeds your printer is capable off. I just used F3600 and F360 since they should be workable and safe. Feel free to pick other speeds as suits you.
@fcwilt thanks very much. hopefully, I'll be printing the next time we speak.
Did you get Z homing to work?
@fcwilt Let's talk later. If I make a video of it, I'll send you a link.
This post is deleted! -
G91 ; relative positioning G1 H2 Z5 F3600 ; lift Z relative to current position G1 H1 X225 Y225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X-5 Y-5 F3600 ; go back a few mm G1 H1 X225 Y225 F360 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X-10.875 Y4.375 F3600 ; go to first bed probe point and home Z G30 ; home Z by probing the bed This is the code that's in the system. It doesn't look like your suggestion? So I'm not sure how to proceed.
As I mentioned that is the code for homing with a Z probe.
You have a Z endstop switch as well so you can use that, instead of the Z probe, and get quicker and simpler homing.
We discussed getting rid of that code and replacing it with my code.
What happened to doing that?
