    I could use some help
    682
    64.0k
    • fcwiltundefined
      fcwilt @A Former User
      @mac said in I could use some help:
      @fcwilt are we okay even though the code still says "forwards?"
      Everything after the ; character is just a comment - it affects nothing - you could put a line from a Shakespeare play there and it would make no difference at all.
      All that matters is you find the right S parameter so the Z axis moves in the correct direction.
      And the same is true for X and Y - if it turns out they are not moving in the correct direction.
      • fcwiltundefined
        fcwilt @droftarts
        @droftarts said in I could use some help:
        @fcwilt look at his bed. It’s not 10mm cast aluminium plate, well-constrained and moving on linear rails. It’s a (please forgive me, @Mac ) cheap bedslinger setup. He’s going to need mesh compensation to have half a chance getting the first layer to stick. The probe was working fine. Fiddling around with a Z min endstop is excruciating with flimsy beds.
        Doing kids bath and bed. Not around for a while.
        Rest assured Mesh Bed Compensation will be implemented.
        One small step at a time.
        A Former User? 2 Replies Last reply Reply Quote 0
          A Former User @fcwilt
          @fcwilt got it, I've offended you. Please accept my apologies. I've spent 70 years making life miserable for others. It's hard to get out of that habit.
            @fcwilt I'm not opposed to buying a decent bed. Given that the one I have on this printer now has failed the PID tests horribly, I'm looking for a good bed. Any recommendations you can provide (preferably links that will make you some money), would be appreciated.
            • fcwiltundefined
              I'm not offended at all.
              I'm glad we are making progress.
              I hope we can get Z working.
              If we can do that, I think you can get X and Y working on your own since the issues are the same and the homing code is pretty much the same, just specifying a different axis.
              I am running out of time today though.
                @fcwilt My BLV rebuild of my old Anet A8 had linear rails. Marvelous kit, those. I still have them, and putting them on this POS seems possible with a little elbow grease and a drill press (both of which I have).
                  @fcwilt got it, ship me the X and Y code please. I'll test Z right now to confirm that the changes accomplished what I may have to use to correct X and Y if they aren't up to snuff.
                  A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                  • fcwiltundefined
                    I know very little about your type of printer. I know that some popular models have upgrade parts available from different sources.
                    I just upgraded the bed on my E3D Tool Changer printer with a bed from Mandela Rose Works (I think that is the correct spelling).
                      A Former User @A Former User
                      @fcwilt Z went up, and then it went down. It sounded like a real printer / that's a first. My guess is, it's about 30mm off the bed at the moment. I think that was a choice in the RRF? That the first time Z homed, it stopped at 30 above?
                        @fcwilt I'll google them and go from there.
                          @fcwilt if you have the time, please send the X and Y code, then be off with you to your own time, and thank you in advance.
                          • fcwiltundefined
                            OK
                            Homing X should look something like this:
                            G91
                            G1 H1 X-230 F3600
                            G1 X15
                            G1 H1 X-10 F360
                            G90
                            G1 X110 F3600 ; this just moves X to the centerline of the bed - doesn't matter where - it can be any place at all that suits you.
                            Homing Y should look something like this:
                            G91
                            G1 H1 Y-230 F3600
                            G1 Y15
                            G1 H1 Y-10 F360
                            G90
                            G1 Y110 F3600 ; this just moves Y to the centerline of the bed - doesn't matter where - it can be any place at all that suits you.
                            Now I would do homeall.g like this:
                            M98 P"homeZ.g"
                            M98 P"homeX.g"
                            M98 P"homeY.g"
                            It is not as efficient as it can be but it does re-use the code you already have in the other axis homing files.
                            Now I have no idea what kinds of speeds your printer is capable off. I just used F3600 and F360 since they should be workable and safe. Feel free to pick other speeds as suits you.
                              @fcwilt thanks very much. hopefully, I'll be printing the next time we speak.
                              • fcwiltundefined
                                Did you get Z homing to work?
                                  @fcwilt Let's talk later. If I make a video of it, I'll send you a link.
                                    This post is deleted!
                                      @fcwilt
                                      G91                      ; relative positioning
                                      G1 H2 Z5 F3600           ; lift Z relative to current position
                                      G1 H1 X225 Y225 F1800    ; move quickly to X and Y axis endstops and stop there (first pass)
                                      G1 H2 X-5 Y-5 F3600      ; go back a few mm
                                      G1 H1 X225 Y225 F360     ; move slowly to X and Y axis endstops once more (second pass)
                                      G90                      ; absolute positioning
                                      G1 X-10.875 Y4.375 F3600 ; go to first bed probe point and home Z
                                      G30                      ; home Z by probing the bed
                                      This is the code that's in the system. It doesn't look like your suggestion? So I'm not sure how to proceed.
                                      • fcwiltundefined
                                        @fcwilt
                                        As I mentioned that is the code for homing with a Z probe.
                                        You have a Z endstop switch as well so you can use that, instead of the Z probe, and get quicker and simpler homing.
                                        We discussed getting rid of that code and replacing it with my code.
                                        What happened to doing that?
                                          @fcwilt
                                          ; homeall.g
                                          ; called to home all axes
                                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jun 27 2022 06:45:01 GMT-0700 (Pacific Daylight Time)
                                          M98 P"homeZ.g"
                                          M98 P"homeX.g"
                                          Mpo P"homeY.g"
                                          ;G91                     ; relative positioning
                                          ;G1 Z5 F60               ; lift Z relative to current position
                                          ;G90                     ; absolute positioning
                                          This is what I put in homeall.g's place.
                                            @fcwilt link text
                                            The is Z homing again.
