1XD Closed Loop Servo Setup
41
2.6k
    code7
    I would like to setup a servo motor to run from the 1XD on a Duet 3 Mini 5+. Can someone tell me how to wire the 1XD to the Duet 3 Mini? I feel like I'm overlooking something in the instructions here: https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Expansion_1XD
    Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
    undefined undefined 2 Replies Last reply 1 Jul 2022, 22:11 Reply Quote 0
      fcwilt @code7
      @code7
      What is it that you don't understand? Do the items below cover it?
      • You need to feed the board power on the VIN terminals.
      • You need to connect one of the boards CAN jacks to the Duet 3 Mini but it does not have CAN jacks - just a 2 pin connector.
      undefined 1 Reply Last reply 1 Jul 2022, 23:01 Reply Quote 1
        code7 @fcwilt
        @fcwilt Thanks. The picture and tips really help and the wiring the CAN-FD Bus makes sense now after revisiting the link.
        Could you give me an example of how the config.g would look with this scenario?
        undefined undefined 2 Replies Last reply 2 Jul 2022, 01:03 Reply Quote 0
          alankilian @code7
          @code7
          THIS PAGE states which pins are PWM capable.
          Then just use the normal PWM syntax to configure a pin and set the value as shown HERE.
            fcwilt @code7
            @code7 said in 1XD Servo Setup:
            For the most part inputs, outputs, etc. are treated much like the same on the main board.
            What differs is the need for a board address
            ; 3HC temp sensors
            M308 S0 P"1.temp0" Y"pt1000" ; configure sensor (S), name (A), pin name (P), type (Y), properties (T,B)
            M308 S1 P"1.temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor (S), name (A), pin name (P), type (Y), properties (T,B)
            M308 S2 P"1.temp2" Y"pt1000" ; configure sensor (S), name (A), pin name (P), type (Y), properties (T,B)
            ; 6HC temp sensors
            M308 S3 P"temp1" Y"pt1000" ; configure sensor (S), name (A), pin name (P), type (Y), properties (T,B)
            M308 S4 P"temp0" Y"thermistor" T100000 B4267 ; configure sensor (S), name (A), pin name (P), type (Y), properties (T,B)
            Notice the temp sensor inputs on the 3HC board, which has an assigned address of 1.
            When specifying a temp sensor input on that board the P parameter needs both the address and the pin name - thus the P"1.temp0" above.
            Every board on the CAN bus has a unique address. How the address is set varies with the specific type of board. And every board type has a default address from the factory. IF that default address is all you need than you can use it.
            undefined 1 Reply Last reply 2 Jul 2022, 05:12 Reply Quote 0
              code7 @fcwilt
              @fcwilt How do I state the board address "122" for the 1XD within the config? M308 is used for temperature sensors isn't it?
              This is what I have in the config.g
              ;Servo Configuration
              G4 S2 ; wait for expansion boards to start...
              M950 S1 C"out9" ; assign GPIO port to out9 (Servo header), servo mode
              Then I'm trying to turn the servo with this command. Can you tell me what I am still missing?
              M280 P1 S80
              undefined 1 Reply Last reply 2 Jul 2022, 05:16 Reply Quote 0
                fcwilt @code7
                M280 P1 S80
                As I said you need to include the board address for the parameter that specifies a pin name.
                I gave what I thought was just a simple example showing the addition of the board address where a pin name was needed.
                So, in your case, M950 S1 C"out9" becomes M950 S1 C"122.out0".
                undefined 1 Reply Last reply 2 Jul 2022, 05:26 Reply Quote 0
                  code7 @fcwilt
                  @fcwilt Ok - I'm using M950 S1 C"122.out0" but am still not getting motion. I'll double check my wiring again.
                    dc42 administrators @code7
                    @code7 when you say "servo motor" do you mean:
                    1. A closed loop servo motor that takes step and direction inputs, typically used to control a machine axis; or
                    2. A hobby servo with three wires, that takes 5V power, ground, and a control input?
                    undefined 1 Reply Last reply 2 Jul 2022, 17:34 Reply Quote 0
                      code7 @dc42
                      @dc42 It's a closed loop servo with an incremental type 2500-line quadrature encoder, 10,000 PPR.
                      I double checked the wiring (single ended mode) and everything looks OK but I'm still having trouble turning the servo.
                      http://www.leadshine.com/UploadFile/Down/ELD2-RS400 User Manual for overseas_20191226(V_1.02).pdf
                      undefined 1 Reply Last reply 3 Jul 2022, 03:10 Reply Quote 0
                        ShaunCro @code7
                        @code7
                        Your link doesn't work, and can't find it on the main leadshine site so here is the manualslib link
                        https://www.manualslib.com/products/Leadshine-Eld2-Rs400-11165537.html
                        Following this as I have to setup two EL5-400's soon with ACM604 motors.
                        Lets just get one thing straight....
                        You don't own a Delta! It's true, you don't!
                        It owns you!
                        undefined 1 Reply Last reply 3 Jul 2022, 05:39 Reply Quote 0
                          code7 @ShaunCro
                          @shauncro Thanks for adding a valid link to the manual. After reading through more of the manual I'm seeing how much more complex driving a servo is than a stepper.
                          If anyone can recommend a servo driver that you are having success driving with the 1XD please let me know as I am open to switching if it would simplify things.
                          undefined undefined 2 Replies Last reply 3 Jul 2022, 16:35 Reply Quote 0
                            ShaunCro @code7
                            @code7 I'll let you know how my setup goes, had them sitting in a box for a while, and finally have the time to get started. I'm running the 6HC though, so will be a bit different. Have you tried to use the leadshine tuning software?
                            It owns you!
                            undefined 1 Reply Last reply 6 Jul 2022, 16:20 Reply Quote 0
                              Marcossf @code7
                              @code7 We sucesfull use Oriental Motor AZD-K series absolute enconder pulse-input type motor driver with a 1XD board.
                              https://www.orientalmotor.eu/Products/Stepper_motors/Closed_loop_stepper_motor_packages/az_dc/?&filter1=Standard&filter2=60+mm&feld040=0&arid=22968&dwn=artnr
                              Config example:
                              ;######################### AXIS BOARD DRIVERS DECLARATIONS #########################
                              M569 P40.0 S1 ; physical drive 40 goes forwards X
                              M569 P41.0 S0 ; physical drive 41 goes backwards Y1
                              M569 P42.0 S0 ; physical drive 42 goes backwards Y2
                              M569 P43.0 S0 ; physical drive 43 goes backwards Z1 (Z)
                              M569 P44.0 S0 ; physical drive 44 goes backwards Z2 (U)
                              M569 P45.0 S0 ; physical drive 45 goes backwards Z3 (V)
                              ; ############################## DRIVER PARAMETERS SETTINGS ##############################
                              M584 X40.0 Y41.0:42.0 Z43.0 U44.0 V45.0 ; axis drive mapping
                              M350 X1 Y1 V1 Z1 U1 V1 I1 ; configure axis microstepping with interpolation
                              M92 X150.53 Y150.53 Z100.12 U100.12 V100.12 ; axis steps per mm
                              M566 X900.00 Y900.00 Z500.00 U500.0 V500.0 ; set maximum instantaneous speed changes (mm/min)
                              M203 X18000.00 Y18000.00 Z12000.00 U12000.00 V12000.00 ; set maximum speeds (mm/min)
                              M201 X300.00 Y300.00 Z500.00 U500.00 V500.00 ; set accelerations (mm/s^2)
                              ;################################# AXIS ENDSTOPS #################################
                              M574 X1 S1 P"!40.io0.in" ; configure active-high endstop for low end on X via pin 40.io0.in
                              M574 Y1 S1 P"!41.io0.in" ; configure active-high endstop for low end on Y via pin 41.io0.in
                              M574 Z2 S1 P"!43.io0.in"
                              M574 U2 S1 P"!44.io0.in" ; configure active-high endstop for high end on U via pin 44.io0.in
                              M574 V2 S1 P"!45.io0.in" ; configure active-high endstop for high end on V via pin 45.io0.in
                              1 - Step area defined in the axis as virtual "endstop"
                              2 - Step and dir signals to motor driver
                              undefined 1 Reply Last reply 6 Jul 2022, 16:22 Reply Quote 1
                                code7 @ShaunCro
                                @shauncro Thanks for keeping me in the loop. I haven't tried the tuning software yet. Maybe once I get the closed loop servo turning.
                                  code7 @Marcossf
                                  @marcossf Thanks for the detailed recommendation. I'll check it out.
                                  undefined 1 Reply Last reply 7 Jul 2022, 11:29 Reply Quote 0
                                    @code7 please share your config.g file.
                                    Which axis do you want to drive with this servo motor?
                                      code7
                                      @dc42 The closed loop servo is on drive 122.0 on the 1XD Exp Board. I'm able to turn the motor briefly until I receive the "Motor speed out of control" Alarm from the ELD2 servo driver.
                                      This is how I have it wired:
                                      ELD2 Manual:
                                      http://leadshineusa.com/UploadFile/Down/ELD2-RS70-- User Manual_2021_Ver1.09.pdf
                                      Config:
                                      G4 S2 ; wait a moment for the CAN expansion boards to start
                                      M569 P0.0 S0 ; physical drive 0.0 goes backwards
                                      M569 P0.1 S0 ; physical drive 0.1 goes backwards
                                      M569 P122.0 S0 ; physical drive 121.0 goes backwards
                                      M584 X0.0 Y0.1 Z0.2 E122.0 ; set drive mapping
                                      M350 X16 Y16 Z16 E1 I1 ; configure microstepping with interpolation
                                      M92 X80.00 Y80.00 Z400.00 E100.00 ; set steps per mm
                                      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                      M203 X9000.00 Y9000.00 Z360.00 E6000.00 ; set maximum speeds (mm/min)
                                      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z800 E1200 I50 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M208 X235 Y235 Z260 S0 ; set axis maxima
                                      M574 X1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in
                                      M574 Y2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io2.in
                                      M574 Z1 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io3.in
                                      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                      M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
                                      M143 H0 S150 ; set temperature limit for heater 0 to 150C
                                      M308 S1 P"temp1" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp1
                                      M143 H1 S275 ; set temperature limit for heater 1 to 275C
                                      M950 F0 C"!out3" Q500 ; create fan 0 on pin !out3 and set its frequency
                                      M950 F1 C"!out4" Q500 ; create fan 1 on pin !out4 and set its frequency
                                      M950 F2 C"out5" Q500 ; create fan 2 on pin !out5 and set its frequency
                                      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                                      M563 P0 S”Servo Extruder” D0 F0 ; define tool 0
                                      M563 P1 S”Tool1” F-1 ; define tool 1
                                      T0 ; select first tool
                                      jay_s_ukundefined undefined 2 Replies Last reply 7 Jul 2022, 17:36 Reply Quote 0
                                        jay_s_uk @code7
                                        @code7 you don't appear to have any driver timing on your M569. External drivers usually can't keep up the same way internal ones can. Try something like T5:5:10:10 as a first shout
                                          ShaunCro @code7
                                          @code7
                                          You need to choose whether you going to run high or low on the step/dir.
                                          So typically you daisy chain the positive from the 5V+ and the have the Negative as the pulse input, so only they get connected to the corresponding pins. ENA is typically left unconnected from the documentation I have read on my drivers.
                                          I assume your driver also has a 25\26 pin D-Sub interface, if so, you only need to connect up the corresponding wires and leave the rest, as they aren't used in our instance. But, you may need to grab the software from leadshine to change a few parameters and ensure they are funning step/dir and not RS485 for communication.
                                          It owns you!
                                          undefined 1 Reply Last reply 9 Jul 2022, 04:05 Reply Quote 0
                                          4 out of 41
