BLTouch Almost There
Could some BLTouch gurus look over my stuff? I still can't get the probe to deploy or retract on command. Here is config.g for starters.
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 24 2022 20:50:56 GMT-0500 (Eastern Standard Time); General preferences
M550 P"CoreXY 1" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z400.00 E852 ; set steps per mm
M203 X6000.00 Y6000.00 Z500.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E1300 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X320 Y185 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
M574 Z1 S2 ; Define Z to use Probe. Home to Min; Z-Probe
M558 P9 C"^zprobe.in" H5 F120 T6000
G31 X-41.8 Y32.2 Z-0; Heaters
M307 H0 R0.495 K0.404:0.000 D4.40 E1.35 S1.00 B0; disable bang-bang mode for the bed heater and set PWM limit
M501 -
@gbusy24
The lines for BL Touch in the config are for RRF2.
Have you used the config tool? -
Yes, but not successfully. I suppose I need to try set e-thing up through it?
@diy-o-sphere I'm currently running 3.3
Depending on the servo pin you are using something like this is missing,,,,
(In front of the M558 line)M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
@diy-o-sphere Understood. I set e-thing up manually when going to 3.3, because of certain reasons. I'm going to try and run the configurator shortly, hoping that will sort out the things I have wrong. Thanks
Everything works as should now. Thanks
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
