Bondtech LGX Lite settings
Has anyone "finished" tuning their LGX Lite (direct drive) yet and want to share what they ended up running?
I'm running what i feel is quite modest settings atm (24v):
; Extruder accelerations and speeds M566 E120.00 P1 ; set maximum instantaneous speed changes (mm/min) and jerk policy M203 E1200.00 ; set maximum speeds (mm/min) M201 E250.0 ; set accelerations (mm/s^2)
Those do seem shockingly conservative. How did you land on those values? What firmware version?
@phaedrux TBH i don't remember where/how/why i ended on those numbers.
I'm on 3.4.1. -
Well you could probably comfortably add a 0 to all of your values.
M566 E1200
M203 E12000
M201 E2500 -
Gonna try with these:
; /sys/lib/speed/speed_printing.g ; called to set speed and accelerations settings for printing ; Axis accelerations and speeds M566 X900.00 Y900.00 Z60.00 P1 ; set maximum instantaneous speed changes (mm/min) and jerk policy M203 X18000.00 Y18000.00 Z3000.00 ; set maximum speeds (mm/min) M201 X2000.00 Y2000.00 Z250.00 ; set accelerations (mm/s^2) ; Extruder accelerations and speeds M566 E8000.00 P1 ; set maximum instantaneous speed changes (mm/min) and jerk policy M203 E15000.00 ; set maximum speeds (mm/min) M201 E1800.0 ; set accelerations (mm/s^2) ; Printing and travel accelerations M204 P1500 T20000 ; Set printing acceleration and travel accelerations (mm/s²)
; /sys/lib/speed/speed_probing.g ; called to set speed and accelerations settings for probing ; Axis accelerations and speeds M566 X900.00 Y900.00 Z20.00 P1 ; set maximum instantaneous speed changes (mm/min) and jerk policy M203 X18000.00 Y18000.00 Z3000.00 ; set maximum speeds (mm/min) M201 X2000.00 Y2000.00 Z100.00 ; set accelerations (mm/s^2) ; Extruder accelerations and speeds M566 E3600.00 P1 ; set maximum instantaneous speed changes (mm/min) and jerk policy M203 E5000.00 ; set maximum speeds (mm/min) M201 E800.0 ; set accelerations (mm/s^2) ; Printing and travel accelerations M204 P500 T2000 ; Set printing acceleration and travel accelerations
How did those values turn out?
@phaedrux
Sorry for the slow reply, but it seems to be working. No "strange" stuff has happened yet. But i haven't gotten any real print time on it yet so i'm not sure if it's actually good or not for the long run.
