    Large Format Printer
    My Duet controlled machine
    • Nathanundefined
      Nathan
      I build a printer based on the duet 3 Mainboard with the two Toolboards.
      I named it: TAUT ONE
      https://6brueder.wordpress.com/2022/07/01/taut-one-large-format-printer/
      -printvolume: 1000x550x1100mm3
      -footprint 1170x770mm2(europalett)
      -1.75mm DualHotend automated selectable for two colours or soluble material(Dualoption integrated in the latest version)
      closed housing
      all motion parts are metal(except the belt)
      Wi-Fi
      integrated webcam useful for multi day prints….(based on raspberry pi)
      automated z-axis leveling of all z-axis
      meshbedleveling
      external cooling air for the printhead
      printhead can be easily opened and removed with 4 screws and 3 connectors – for external maintenance
      no milled parts – just lasercutting and printed
      Corexy motion system
      mostly internal cabeling
      1500W heated bed made of 10mm Aluminium with 5mm glass
      z-axis geared 5:1(but belt driven – in my opinion ok for large format
      width can easily reduced(removing some external parts) to standard 80x200cm roomdoors
      Hermera Extruder – open to other products
      Mosquito Hotend
      Big Hotends with up to 1.8mm Nozzle size for high layer heights
      Corexy
      all steppers are outside the housing for better cooling
      printhead is cooled with external air
      target accuracy +-1mm in all directions….
      3000€ material costs
      easy to build
      mostly no cheap parts from china
      filamentrunout sensor
      chamber temperature sensor
      automated cooling fans
        Very nice. Thanks for sharing.
        MrDuiundefined 1 Reply Last reply Reply Quote 0
        • MrDuiundefined
          MrDui @Phaedrux
          @phaedrux Very cool build!
          Also, where did you find the 3D files of the kayak? I'd really like to try and print one too!!!
          Nathanundefined 1 Reply Last reply Reply Quote 0
          • Nathanundefined
            Nathan @MrDui
            @mrdui I know the designer of the model.
