    Something is wrong with G3 d3 or fusion/pp
    CNC
    • chernogorskyundefined
      chernogorsky
      I found some curios bug if Im using G3 operation with f360 + universal pp 1.5 + enabled arc/circle
      It creates oval (X axis is the most affected one)
      The greater cutting feed the worse the "circle". That one on a picture if I remember correctly was made with 2400 mm/min
      And here the result when I disabled arc movements (same feed rate)
      c-inner_failed.gcode c-inner.gcode
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6XD FIRMWARE_VERSION: 3.4.1 ELECTRONICS: Duet 3 MB6XD v0.1 FIRMWARE_DATE: 2022-06-01 21:10:05
      • 3DPMicroundefined
        3DPMicro
        Can you post the program with the arc moves. I can run it through my cad/cam which will back plot the gcode to geometrygcode.JPG
        Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
        chernogorskyundefined 1 Reply Last reply Reply Quote 0
          chernogorsky @3DPMicro
          @3dpmicro Hi, not shure I follow
          I attached c-inner_failed (which is with arc, g2/g3) and c-inner (which is g0/g1 only)
          alankilianundefined 2 Replies Last reply Reply Quote 0
          • alankilianundefined
            alankilian @chernogorsky
            This post is deleted!
              @chernogorsky Boy, that's strange.
              I concatenated your G1 path and your G1/G3 path and rendered them using THIS online rendering program and they plot preciously the same path in the X-Y plane.
              Using a previous version of RRF on a Duet2 I was able to make prefect objects using millions of G2 commands so it has worked in the past. I was using small G2 arcvs however, so maybe I just didn't see a small variation in X-Y dimensions.
              I can try updating my system to whatever version of RRF you are using and test your file and see what shape I get.
                chernogorsky
                I have not seen any issue with a printer (and ASFAIK it utilizes g2/3 at some points)
                but as you can see from the pictures with CNC it looks different
                It may be still post processor issue, but g2/g3 code looks ok-ish
