    Anybody wants a stepper motor analyzer?
    281
    31.6k
    • Keyboredundefined
      Keybored @zapta
      @zapta Thanks! I'll change the board design and proceed on this track then. Do you think the lower sensing resolution will impact the quality of the readings?
      • zaptaundefined
        zapta @Keybored
        @keybored, I don't expect the lower sensitivity to be significant.
        Of course, I don't know for sure since I never used that IC.
        • zaptaundefined
          zapta @zapta
          I am trying now a new approach, a BLE Stepper Motor Analyzer. It still at an early stage, but so far looks feasible. Imagine a small widget, smaller than a matchbox, with 4 pass through stepper motor wires. The widget harvests a small amount of power from the wires (~100mw) to power a small microcontroller (Nordic NRF52832) that monitors stepper signals, extracts information such as steps/speed/waveforms, and sends it wirelessly via BLE to an app on a computer, smart phone, or even to a DWC plugin (which uses Web Bluetooth).
          I don't know if it's all possible but initial tests look good. With a NRF52832 that samples two analog channels and sends the extracted data to a PC via bluetooth (max sampling rate I could get is 40Khz per channel compared to 100Khz on the Simple Stepper Analyzer). Power harvesting also looks feasible with a four phase full rectifier bridge, a small capacitor and a 5-30V -> 3.3 DC/DC converter. The energy is available as long as the stepper is energized, regardless if it moves or not and on what microstep/phase it happened to stop. Could also add a small battery rechargeable or not, if needed.
          As for the client software, I am thinking of a reference python client that people can use to create desktop apps or as reference design for mobile and other clients.
          As I said, it's still at an early phase and I don't know for certain that this is feasible.
          Any thoughts?
          oliofundefined 1 Reply Last reply Reply Quote 4
          • oliofundefined
            oliof @zapta
            @zapta I'll take five.
            • zaptaundefined
              zapta @oliof
              @oliof said in Anybody wants a stepper motor analyzer?:
              Will keep it in mind. My preference would be to provide it to a few developers that will build real apps (for desktop, mobile, or web bluetooth).
              One challenge I hit is how to calibrate zero current if the MCU is not powered when the current is zero. 😉
              • zaptaundefined
                zapta @zapta
                Had more progress with the BLE stepper probe and was able to display on a PC a real time step and speed graphs over BLE (using python/Bleak/Pyqtgraph and the PC side). Sill need to do some tests, e.g. of the energy harvesting, but it feels feasible. The MCU and the radio consumes about 3ma and the current sensors about 5ma each (all at 3.3v), for a total of ~40mw. This is the current schematic (not tested):
                If anybody thinks that I am doing something terribly wrong (e.g. damaging the Duet's driver) now it's the time to speak 😉
                • rickykwongwmundefined
                  rickykwongwm @zapta
                  @zapta
                  I come from Hong Kong, I would like to order a PCB , how can I contact you and place a order?
                  • zaptaundefined
                    zapta @rickykwongwm
                    @rickykwongwm, PCB of what version, the one with touch screen or the experimental one with bluetooth?
                    rickykwongwmundefined 1 Reply Last reply Reply Quote 0
                      rickykwongwm @zapta
                      @zapta
                      I prefer a set of PCB with touch screen, but experimental one only is also acceptable .
                      could u leave your contact to me with quotation ?
                      • brucedewaldundefined
                        brucedewald
                        I wonder if you have the stepper motor analyzer with touch screen. If you do, can you send me a quotation for the cost including shipping? I am from Winnipeg, Canada.
                        Yours sincerely,
                        Bruce Dewald.
                        zaptaundefined Th0mpyundefined 2 Replies Last reply Reply Quote 0
                        • zaptaundefined
                          zapta @brucedewald
                          @brucedewald , sorry, I don't have any left. The goal of this project was to put a reference design in the public domain rather than actually producing them.
                          • Th0mpyundefined
                            Th0mpy @brucedewald
                            @brucedewald I still have some available from my original batch. If you're interested send me a direct message.
                            Usually the team that scores the most points wins the game.
                            Adamfilipundefined 1 Reply Last reply Reply Quote 0
                            • Adamfilipundefined
                              Adamfilip @Th0mpy
                              This post is deleted!
                              Th0mpyundefined 1 Reply Last reply Reply Quote 0
                              • Th0mpyundefined
                                Th0mpy @Adamfilip
                                @adamfilip I suggest you read the thread above 🙂
                                • zaptaundefined
                                  zapta @Th0mpy
                                  The second iteration of the Bluetooth version went out to JLCPCB. They install all the SMD parts except for the bluetooth module and the two current sensors. Still working on it but the core functionality already works. This version doesn't need external power, just connection to the stepper wires.
                                  https://github.com/zapta/ble_stepper_monitor
                                  zaptaundefined 1 Reply Last reply Reply Quote 1
                                  • nyaruundefined
                                    nyaru
                                    Hi.
                                    I am planning to sell a small quantity of this analyzer in Japan for CNC users.
                                    I found a cheap current sensor CC6920BSO-5A made in China at LCSC and tested it. LCSC Part No: #C2880430
                                    This sensor also drive in 3.3V.
                                    With this, the current sensor can also be mounted on the board in JLCPCB.
                                    I want to share you the test result.
                                    There appears noises on the signal. But I think It is not a problem to get rough forms of waveform.
                                    movies:
                                    https://youtu.be/GVSU9TVF_7k
                                    https://youtu.be/dTQMCF_6i5k
                                    zaptaundefined 2 Replies Last reply Reply Quote 0
                                    • zaptaundefined
                                      zapta @nyaru
                                      @nyaru, that's very useful, especially the availability from JLCPCB. Thanks.
                                      I have hard time downloading the datasheet from LCPCB. Do you happen to have it?
                                      If the sensitivity of this chip is lower, e.g. 200mv/A instead of 400mv/A, it can be compensated in firmware.
                                      Do CNC users typically need higher current range than 3D printers?
                                      Edit: The firmware does basic signal filtering which reduces the impact of the noise. https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/platformio/src/acquisition/analyzer.cpp#L323
                                      nyaruundefined 1 Reply Last reply Reply Quote 0
                                      • nyaruundefined
                                        nyaru @zapta
                                        @zapta
                                        You can see it from another current value sensor page.
                                        https://www.lcsc.com/product-detail/Current-Sensors_Cross-chip-CC6920BSO-10A_C2880431.html
                                        I already changed sensitivity to 264mV/A in firmware. and it works well.
                                        Yes. Milling and Cutting something in CNC machine need more power than 3D printer. I used 3A stepper motor in my CNC machine.
                                        Thanks for telling it! This may be the reason why analyzers are less noises than oscilloscopes.
                                        • zaptaundefined
                                          zapta @nyaru
                                          @nyaru, thanks for the datasheet link. It does work.
                                          BTW, the design has some support for sensor selection using configuration resistors. May or may not be useful for you.
                                          https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/platformio/src/misc/hardware_config.cpp#L53
                                          • zaptaundefined
                                            zapta @zapta
                                            Here is a sample screenshot of a Windows/python client that talks with the experimental BLE stepper monitor and displays the data in real time. In this example the stepper runs on 12V which causes current reduction in higher speed (shown by the arrows). This is reflected in the current graph, the current vs speed histogram, and the oscilloscope view.
                                            The Python client is here https://github.com/zapta/ble_stepper_monitor/tree/main/python . Hopefully somebody can write a similar one for mobile devices.
                                            The probe is powered from the stepper signals and thus can be left embedded in the printer and be connected to any time. Each probe has a unique address which is shown at the upper left part of the picture.
