    Input shaping help
    1.1k
      jay_s_uk @jamaicarasta
      @jamaicarasta yes, but try and avoid ei2 and ei3 as they can slow down the print
      jamaicarastaundefined 1 Reply Last reply Reply Quote 0
      • jamaicarastaundefined
        jamaicarasta @jay_s_uk
        @jay_s_uk Ok, what is the fastest shaper? than i will try it first with a test print
          @jamaicarasta work down the list, so MZV, ZVD etc
            @jay_s_uk and what is the center shaper hz?
              @jamaicarasta thats the frequency in the input shaping is applied around. so you want to pick either the largest peak if you only have one or the middle of the peaks. the plugin will show you how much it thinks the peaks will be reduced by
                @jay_s_uk ok,but with the command M593 I enter the value 41hz which is displayed in my file on the left, right? But where is the center shaper entered?
                  @jamaicarasta there is a box on the right to set the centre frequency value.
                  Most of the input shapers are centred around this value (MZV isn't)
                  jamaicarastaundefined 3 Replies Last reply Reply Quote 0
                    @jay_s_uk ok
                      @jay_s_uk ok i understand, i must activate the hook when i change the center frequency
                        @jay_s_uk and can i delete the acc file in my system?
                          @jamaicarasta the file generated by the original accelerometer plugin? yes
                          jamaicarastaundefined 2 Replies Last reply Reply Quote 0
                            @jay_s_uk yes first try without your tips
                              @jay_s_ukDo I understand that correctly, nothing is required in the system files. The M593 P"zvd" F46 command in the config file is sufficient.
                                @jamaicarasta correct
                                  @jay_s_uk Thanks for your help man, now the Test print. That was the Print yesterday without shaper. 100mm/s and 7000accel. Not bad with 7000accel. Voron 350 with lgx lite and carbon x axis and 1 mgn12 rail.
