Can I connect a wired camera to my Duet 2 Wifi?
My Duet controlled machine
611
    TRATOON
    Hello, I was wondering if it is possible to connect a wired camera to my Duet 2 WiFi or if I could connect a RaspberryPi with a camera on it to the Duet 2 Wifi.
    undefined 1 Reply Last reply 27 Jul 2022, 20:59 Reply Quote 0
      droftarts administrators @TRATOON
      @tratoon There's a couple of options to use a RPi + camera on this page: https://docs.duet3d.com/User_manual/Reference/DWC_webcam
      undefined 2 Replies Last reply 27 Jul 2022, 21:50 Reply Quote 0
        TRATOON @droftarts
        @droftarts I plan on buying a Duet 3 and a RaspberryPi 4B and install it on my printer and run it on Duet+SBC mode. Do you recommend a camera, and is there anyway to create a timelapse (@resam 's integration only works in non Duet+SBC mode).
          TRATOON @droftarts
          @droftarts More specifically, would it be possible to use MotionEye OS on Raspberry Pi 4 With Duet 3 in Duet+SBC mode using a Logitech C270 and have layer by layer time-lapse? If so, how would I get the time-lapse part of it setup?
          undefined 1 Reply Last reply 27 Jul 2022, 22:42 Reply Quote 0
            @tratoon See further down the page I already linked: https://docs.duet3d.com/en/User_manual/Reference/DWC_webcam#motion-on-a-raspberry-pi-running-dsf. See motion supported hardware for supported cameras.
            I don't know if DuetLapse works in SBC mode.
            undefined 1 Reply Last reply 28 Jul 2022, 03:07 Reply Quote 0
              TRATOON @droftarts
              @droftarts Is it possible to create a timelapse using motion?
              undefined 1 Reply Last reply 28 Jul 2022, 05:42 Reply Quote 0
                Phaedrux Moderator @TRATOON
                @tratoon said in Can I connect a wired camera to my Duet 2 Wifi?:
                With Duet Lapse yes
                undefined 3 Replies Last reply 28 Jul 2022, 15:11 Reply Quote 0
                  TRATOON @Phaedrux
                  @phaedrux Can I use Duet lapse in SBC Mode?
                    TRATOON @Phaedrux
                    @phaedrux And what wired camera would you recommend for this setup (preferably at 1080p) that is compatible with Duet Lapse?
                    undefined 1 Reply Last reply 28 Jul 2022, 17:43 Reply Quote 0
                      TRATOON @Phaedrux
                      @phaedrux Since I plan on usinga Raspberry Pi 4B 8GB for this setup would I need to supply external power to the Pi or not?
                        @tratoon as it’s controlled by motion, it’s any camera supported by motion, as I linked earlier.
                        Yes, an external PSU for the RPi is recommended.
                        3 out of 11
