    Led on the duet mother board lights up
    • bigwood247undefined
      bigwood247
      Hi I have had a duet wifi for a wile now but recently have had a problem with the led lighting up when I move my y axis and x axis even when there's no power going to the board I use a ac relay for a keenovo 800 watt silicone bed
        Can you give us some more detail?
        See here for how to help us help you: https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
        When you move the axis by hand, the motors become generators and create a current of their own which flows back into the board and lights up the LEDs. If you do this too fast you can generate enough current to cause damage.
        Otherwise I can't figure out what issue you're trying to describe.
        bigwood247undefined 1 Reply Last reply Reply Quote 0
          bigwood247 @Phaedrux
          @phaedrux ill try to explain it a little better i have had this duet 2 wifi for over a year working great but recently i tried to hook up a a berd air part cooling pump directly to the pwm fan output and i think i blew the fan port or something because now ever time that turn off the power compleatly and i then try to move my x/y axis manually with my hand the little red led illumates near the usb in and i hear like high pitched wine as well when the led iillumantes
            Yes it sounds like something isn't right. Does it work when the berd air is not running? If so, I would stop using that until you figure this out to prevent more permanent damage.
            How exactly do you have the pump connected?
              dc42 administrators @bigwood247
              @bigwood247 said in Led on the duet mother board lights up:
              That's normal. When you move the motors by hand they act as generators. The stepper driver chips feed the power they generate into the fused side of the VIN supply.
