Solved Suppress driver warning message
Dear Community and @dc42 ,
we have installed a special print head for which we do not tap all four pins of the motor connector. All you have to do is rub off 2 phases and the integrated servo driver of the print head recognizes the speed and position to be driven. The problem here is that we are of course entitled to receive the driver error message. This in turn blocks our console in the long run and thus blocks the host when sending commands via USB. We are currently using firmware 3.4.1.
So my question is, how is it possible to display the message only once and then not further?
Disabling the driver is of course not an option.Thanks for your help
@cr3d if you set the motor current to less than 500mA then the message should be suppressed.
@dc42 Thank you!
It worked
