    Temperature controlled LED display
    Gcode meta commands
    1.7k
    • OwenDundefined
      OwenD
      I decided to do some more work on this as a bit of a project.
      I don't have any LED strips to test with as yet, but I believe this will work.
      I have created two macros.
      One that does all the hard work. (set_led_by_temp.gcode)
      It will gradually change colours based on the values you set for LOW, MEDIUM & HIGH heat.
      Above or below this values it will set a constant colour.
      The brightness may also be scaled depending on how close it is to the next break point.
      The other macro would be called from your slicer start code after setting the nozzle temp.
      It will keep calling the first macro until the target temp is reached and then will set the LED's to white.
      You could call it at the end of the print by creating a similar macro waiting for cool down.
      Macro to put in start code
      ; set_LED_while_heating.g
      ; Parameters can be passed for Tool number and target temp
      ; S = target temperature
      ; T = Tool number
      ; D = delay between checks
      ; example in Prusa slicer start code
      ; M568 P[current_extruder] R{"{heat.coldExtrudeTemperature+5}"} S[first_layer_temperature_0] A2
      ; M98 P"set_LED_while_heating.gcode" S[first_layer_temperature_0] T[current_extruder] D3
      ; M116
      var toolNumber = 0
      var targetTemp = 120
      var delay = 3
      var heaterNumber = tools[var.toolNumber].heaters[0]
      if exists(param.T)
      	set var.toolNumber = param.T
      if exists(param.S)
      	set var.targetTemp = param.S
      if exists(param.D)
      	set var.delay = param.D
      while heat.heaters[var.heaterNumber].current < var.targetTemp
      	M98 P"set_led_by_temp.gcode"
      	G4 S{var.delay}
      ; done heating, so set to white
      M150 R255 U255 B255 W255 P255 F0 ; set pixels
      Main macro
      ; set_led_by_temp.gcode
      ; This macro sets neopixels based on tool heater temp
      ; It should be called from daemon.g to achieve continual updates
      ; or by another macro with a loop if you only want to change colours during heatup
      ;example macro called from your slicer start code before after temps, but before M116
      ;while heat.heaters[1].current < 120
      ;    M98 P"set_led_by_temp.gcode"
      ;    G4 S3
      ;M150 R255 U255 B255 W255 P255 F0 ; set pixels
      ; LED strip pixel count must equal number of tools * pixels per tool
      ; For multiple tools the neopixels must be daisy chained or a continuos strip
      ; The colour will gradually scale from one to the next.
      ; define the LED (should be in config.g as the value is remembered between calls)
      ;M150 X2 Q3000000      ; set LED type to NeoPixel bit banged type and set SPI frequency to 3MHz
      var RGBW = false  ; set to true if LED is RGBW type, oherwise set to false
      var logging = true ; set to true if you want echos to appear in console to help see what the values are.  Otherwise set false
      ; adjust these variable temps to suit requirements.
      var lowTemp = 30
      var medTemp = 70
      var highTemp = 120
      ; brightness will be scaled between lowBrightness and highBrightness according to how close it is the max for range
      ; eg. between low temp and med temp
      ; once over high temp it will scale between high temp and max heater temp as set in config.g
      ; to not scale brightness, set both values the same
      var lowBrightness = 100
      var highBrightness = 255
      ; number of pixels on the strip that are assigned to each tool e.g first five are tool 1, second 5 are tool 2 etc
      ; if only one tool is used, set to total number of led's on strip
      var pixelsPerTool = 5
      ; Common RGB colours (R,G,B)
      ; RED -		255,0,0
      ; YELLOW -	255,255,0
      ; ORANGE -	255,165,0
      ; BLUE -	0,0,255
      ; LIME -	0,255,0
      ; GREEN -	0,128,0
      ; MAGENTA - 255,0,255
      ; WHITE -	255,255,255
      ; OFF -		0,0,0
      ;adjust values following to achieve desired colors for each range
      ; this will be so much easier when we have arrays ;-)
      ; all values must be integers between 0 & 255
      ; high temp values (anything over high temp  will be set to this)
      var highRed = 255
      var highGreen = 12
      var highBlue = 40
      var highWhite = 0 ; only used on RGBW type
      ;medium temp values
      var midRed = 200
      var midGreen = 128
      var midBlue = 20
      var midWhite = 40 ; only used on RGBW type
      ;low temp values
      var lowRed = 0
      var lowGreen = 255
      var lowBlue = 0
      var lowWhite = 60 ; only used on RGBW type
      ; cold temp values (anything under low temp will be set to this)
      var coldRed = 0
      var coldGreen = 0
      var coldBlue = 255
      var coldWhite = 0 ; only used on RGBW type
      ; #############################  SHOULD NOT NEED TO EDIT PAST HERE   ################################
      ; create other needed variables
      var thisHeater= 0
      var thisHeaterTemp = 0
      var upperTemp = 0
      var thisTool= 0
      var F=0
      var maxTemp = 0
      var brightScale = 0
      var redValue = 0
      var greenValue = 0
      var blueValue = 0
      var whiteValue = 0
      var setBrightness = 0
      var redScale= 0
      var greenScale = 0
      var blueScale = 0
      var whiteScale = 0
      var lowValue = 0
      var highValue = 0
      ; sanity checks
      if (var.lowBrightness < 0) || (var.highBrightness > 255) || (var.highBrightness < var.lowBrightness)
      	echo "Invalid brightness settings.  Must be between 0 & 255.  High must be > than low.  Setting to defaults (Low 100, high 255)"
      	set var.lowBrightness = 100
      	set var.highBrightness = 255
      if (var.lowTemp <= 0) || (var.medTemp <= var.lowTemp) || (var.highTemp <= var.medTemp)
      	echo "Invalid temp range setings - resetting to defaults (low=50, medium=130,high=180)"
      	set var.lowTemp = 50
      	set var.medTemp = 130
      	set var.highTemp = 180
      if (var.logging != true) && (var.logging != false)
      	echo "Invalid logging value- must be true or false"
      	set var.logging = false
      ; gather the tool temperatures
      while iterations < #tools ; loop through the tools
      	set var.thisTool = iterations
      	set var.upperTemp = 0 ; reset the upper temp
      	set var.maxTemp = 0 ; reset the max temp
      	set var.lowValue = 0
      	set var.highValue = 0
      	while iterations < #tools[var.thisTool].heaters ; loop through the heaters on each tool and get max temp
      		if var.logging = true
      			echo "Checking tool", var.thisTool, "heater", iterations
      		set var.thisHeater = tools[var.thisTool].heaters[iterations]
      		set var.thisHeaterTemp = heat.heaters[var.thisHeater].current
      			echo "Heater", iterations, ". Temp =", var.thisHeaterTemp
      		if var.thisHeaterTemp > var.upperTemp
      			set var.upperTemp = var.thisHeaterTemp
      			set var.maxTemp = heat.heaters[var.thisHeater].max
      		echo "Max temp of heaters is" , var.upperTemp
      	; determine if there will be more commands in this loop
      	if iterations = #tools - 1
      		set var.F = 0
      	else
      		set var.F = 1
      	; Set the group of LEDs based on the temperature
      	; high temp range so just set to high temp colour values, bt scale brightness up to max heater temp
      	if var.upperTemp >= var.highTemp
      		set var.brightScale = (var.highBrightness - var.lowBrightness) / (var.maxTemp - var.highTemp)
      		set var.setBrightness = floor((var.brightScale * (var.thisHeaterTemp - var.highTemp)) + 0.5) + var.lowBrightness ;
      		set var.redValue = var.highRed ;
      		set var.blueValue = var.highBlue
      		set var.greenValue = var.highGreen
      		set var.whiteValue = var.highWhite
      			echo "Temp is > ", var.highTemp
      			echo "RGB(W) values set to -" , var.redValue, var.greenValue, var.blueValue, var.whiteValue
      			echo "Brightness set to", var.setBrightness
      		; medium range - colours will be scaled between lowtemp and medium tempas will brightness
      	elif var.upperTemp >= var.medTemp
      		set var.brightScale = (var.highBrightness - var.lowBrightness) / (var.highTemp - var.medTemp)
      		set var.setBrightness = floor(var.brightScale * (var.thisHeaterTemp -  var.medTemp) + 0.5) + var.lowBrightness ;
      		set var.lowValue = min(var.highRed,var.midRed)
      		set var.highValue = max(var.highRed,var.midRed)
      		set var.redScale = (var.highValue - var.lowValue) / (var.highTemp - var.medTemp)
      		set var.lowValue = min(var.highGreen,var.midGreen)
      		set var.highValue = max(var.highGreen,var.midGreen)
      		set var.greenScale = (var.highValue - var.lowValue) / (var.highTemp - var.medTemp)
      		set var.lowValue = min(var.highBlue,var.midBlue)
      		set var.highValue = max(var.highBlue,var.midBlue)
      		set var.blueScale = (var.highValue - var.lowValue) / (var.highTemp - var.medTemp)
      		set var.lowValue = min(var.highWhite,var.midWhite)
      		set var.highValue = max(var.highWhite,var.midWhite)
      		set var.whiteScale = (var.highValue - var.lowValue) / (var.highTemp - var.medTemp)
      		if var.midRed < var.highRed
      			set var.redValue = floor((var.redScale * (var.thisHeaterTemp - var.medTemp)) + 0.5) + var.midRed
      		else
      			set var.redValue = var.midRed - floor((var.redScale * (var.thisHeaterTemp - var.medTemp)) + 0.5)
      		if var.midGreen < var.highGreen
      			set var.greenValue = floor((var.greenScale * (var.thisHeaterTemp - var.medTemp)) + 0.5) + var.midGreen
      		else
      			set var.greenValue = var.midGreen -  floor((var.greenScale * (var.thisHeaterTemp - var.medTemp)) + 0.5)
      		if var.midBlue < var.highBlue
      			set var.blueValue = floor((var.blueScale * (var.thisHeaterTemp - var.medTemp)) + 0.5) + var.midBlue
      		else
      			set var.blueValue = var.midBlue - floor((var.blueScale * (var.thisHeaterTemp - var.medTemp)) + 0.5)
      		if var.midWhite < var.highWhite
      			set var.whiteValue = floor((var.whiteScale * (var.thisHeaterTemp - var.medTemp)) + 0.5) + var.midWhite
      		else
      			set var.whiteValue = var.midWhite - floor((var.blueScale * (var.thisHeaterTemp - var.medTemp)) + 0.5)
      			echo "Temp is > ", var.medTemp, "but < ", var.highTemp
      		; low temp range - colours will be scaled between cold tempand medium temp range, as will brightness
      	elif var.upperTemp >= var.lowTemp
      		set var.brightScale = (var.highBrightness - var.lowBrightness) / (var.medTemp - var.lowTemp)
      		set var.setBrightness = floor(var.brightScale * (var.thisHeaterTemp -  var.lowTemp) + 0.5) + var.lowBrightness ;
      		set var.lowValue = min(var.midRed,var.lowRed)
      		set var.highValue = max(var.midRed,var.lowRed)
      		set var.redScale = (var.highValue - var.lowValue) / (var.medTemp - var.lowTemp)
      		set var.lowValue = min(var.midGreen,var.lowGreen)
      		set var.highValue = max(var.midGreen,var.lowGreen)
      		set var.greenScale = (var.highValue - var.lowValue) / (var.medTemp - var.lowTemp)
      		set var.lowValue = min(var.midBlue,var.lowBlue)
      		set var.highValue = max(var.midBlue,var.lowBlue)
      		set var.blueScale = (var.highValue - var.lowValue) / (var.medTemp - var.lowTemp)
      		set var.lowValue = min(var.midWhite,var.lowWhite)
      		set var.highValue = max(var.midWhite,var.lowWhite)
      		set var.whiteScale = (var.highValue - var.lowValue) / (var.medTemp - var.lowTemp)
      		if var.lowRed < var.midRed
      			set var.redValue = floor((var.redScale * (var.thisHeaterTemp - var.lowTemp)) + 0.5) + var.lowRed
      		else
      			set var.redValue = var.lowRed - floor((var.redScale * (var.thisHeaterTemp - var.lowTemp)) + 0.5)
      		if var.lowGreen < var.midGreen
      			set var.greenValue = floor((var.greenScale * (var.thisHeaterTemp - var.lowTemp)) + 0.5) + var.lowGreen
      		else
      			set var.greenValue = var.lowGreen - floor((var.greenScale * (var.thisHeaterTemp - var.lowTemp)) + 0.5)
      		if var.lowBlue < var.midBlue
      			set var.blueValue = floor((var.blueScale * (var.thisHeaterTemp - var.lowTemp)) + 0.5) + var.lowBlue
      		else
      			set var.blueValue = var.lowBlue - floor((var.blueScale * (var.thisHeaterTemp - var.lowTemp)) + 0.5)
      		if var.lowWhite < var.midWhite
      			set var.whiteValue = floor((var.whiteScale * (var.thisHeaterTemp - var.lowTemp)) + 0.5) + var.lowWhite
      		else
      			set var.whiteValue = var.lowWhite - floor((var.whiteScale * (var.thisHeaterTemp - var.lowTemp)) + 0.5)
      			echo "Temp is > ", var.lowTemp, "but < ", var.medTemp
      	; cold temp range, so just set colour to cold value but scale brightness between zero and low temp value
      	else
      		set var.brightScale =   (var.highBrightness - var.lowBrightness) /(var.lowTemp - 0)
      		set var.setBrightness = floor(var.brightScale * (var.thisHeaterTemp - 0) + 0.5) + var.lowBrightness ;
      		set var.redValue = var.coldRed
      		set var.greenValue = var.coldGreen
      		set var.blueValue = var.coldBlue
      		set var.whiteValue = var.coldWhite
      			echo "Temp is < ", var.lowTemp
      	; finally, set the LED strip to the desired colour and brightness
      	if var.RGBW = true
      		M150 R{var.redValue} U{var.greenValue} B{var.blueValue} W{var.whiteValue} P{var.setBrightness} S{var.pixelsPerTool} F{var.F} ; set pixels
      	else
      		M150 R{var.redValue} U{var.greenValue} B{var.blueValue} P{var.setBrightness} S{var.pixelsPerTool} F{var.F} ; set pixels
      set_led_by_temp.gcode set_LED_while_heating.gcode
      Rushmere3Dundefined 2 Replies Last reply Reply Quote 1
      • Rushmere3Dundefined
        Rushmere3D @OwenD
        @owend That's awesome, I've not had a chance to try the new code yet because 1) it's still quite hot in my small workshop and 2) I don't currently use PrusaSlicer for my toolchanger so haven't changed the code for S3D yet.
        But I will give it a go.
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          Rushmere3D @OwenD
          @owend
          Hey, had a go at using this today and It's not quite working. Below in my start gcode for single T3 printing, bare in mind on the toolchanger homing and ABL need to be done before a tool is picked up. What's happening is it basically get's to the point where the temp has been set and heating begins but even once at temp it just sits and does nothing but cycle through checking the tools/heaters.
          I have both macros in the macro folder for ref.
          M104
          T-1
          M140 S[first_layer_bed_temperature]
          ;M568 P0 A2 R[standby_temperature_delta] S[first_layer_temperature] ; set active and standby temps
          ;M568 P1 A2 R[standby_temperature_delta] S[first_layer_temperature] ; set active and standby temps
          ;M568 P2 A2 R[standby_temperature_delta] S[first_layer_temperature] ; set active and standby temps
          M568 P3 A2 R[standby_temperature_delta] S[first_layer_temperature] ; set active and standby temps
          M98 P"/macros/set_led_while_heating.g" S[first_layer_temperature] T[current_extruder] D3
          G28 ;
          G29 ; enable mesh
          M116
          OwenDundefined 2 Replies Last reply Reply Quote 0
          • OwenDundefined
            OwenD @Rushmere3D
            @rushmere3d
            I'll have a look, but probably not before the weekend
            Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
              Rushmere3D @OwenD
              @owend No problem, no rush.
              Shall I try the set_led_by_temp as a daemon.g? rather than being called from a macro.
              Thanks for your help.
              OwenDundefined 1 Reply Last reply Reply Quote 0
              • OwenDundefined
                OwenD @Rushmere3D
                @rushmere3d
                You could call it in daemon.g
                Perhaps set up a global variable so that you can only call it when you've set that variable to true.
                So in your slicer have
                set global.WarmUp = true
                // set all temps etc
                // do homing
                Set global.WarmUp = false
                Then in daemon.g
                If global.Warmup= true
                M98 P"path-to-macro.g"
                • OwenDundefined
                  OwenD @Rushmere3D
                  @rushmere3d
                  The problem was that you did not have any tools selected and I was using the selected tool to determine which heater to monitor in the while loop.
                  This revised file will work with no tool selected.
                  ; T = Tool number
                  ; M116
                  var toolNumber = 0
                  var thisTool = 0
                  if exists(param.T)
                  if exists(param.S)
                  var delay = 3
                  if exists(param.D)
                  ;echo "Tool number is ", var.toolNumber
                  if var.toolNumber != -1
                  		M98 P"0:/macros/conditional_g_code_macros/set_led_by_temp.gcode"
                  		G4 S{var.delay}
                  else
                  		;echo "Testing heat.heaters[tools[" , var.thisTool, "].heaters[0]]"
                  		if (heat.heaters[{tools[var.thisTool].heaters[0]}].state="standby")
                  			while (heat.heaters[{tools[var.thisTool].heaters[0]}].current) < (heat.heaters[{tools[var.thisTool].heaters[0]}].standby)
                  				G4 S{var.delay}
                  		if (heat.heaters[tools[var.thisTool].heaters[0]].state="active")
                  			;echo "active"
                  			while (heat.heaters[tools[var.thisTool].heaters[0]].current) < (heat.heaters[tools[var.thisTool].heaters[0]].active)
                  				G4 S{var.delay}
                  • OwenDundefined OwenD referenced this topic
                  • Nightowlundefined
                    Nightowl
                    @nightowl said in Temperature controlled LED display:
                    I'm going to learn from this to control a series of neopixel LEDs to change colour depending on the spindle speed for my CNC machine, and also have 3-colour LEDs to show my machine in Safe (Green: switched on but not in use/file not loaded), Pause (Orange) and Red (Running a project).
                    Any thoughts on this, please?
                    I was thinking of buying this 1m length (of 144LEDs/m) and cutting it to length, but isn't the current rating (20A) a bit high?
                    Thanks
                    Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                    I'm still on my learning curve, so take everything I say with caution!
                    RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
                    OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • OwenDundefined
                      OwenD @Nightowl
                      @nightowl
                      You will need an external 5v power supply for the LED's.
                      Wiring info here
                        dc42 administrators @Nightowl
                        @nightowl the current consumption is up to 60mA per LED, times 144 for a 1m length is 8.64A maximum. So you will need a separate 5V PSU for them, but a 10A one will do.
                        • cosmowaveundefined cosmowave referenced this topic
                        • Hugsyundefined
                          Hugsy
                          I strongly advise to not put any M98 inside daemon.g as it can disrupt the main DDARRing and cause stutter in the movement. What I usually do is copy the macro inside the daemon.g and even then some commands might disrupt the movement, at least not the whole macro will cause problems. Maybe we can queue the commands in a different G-Code queue with RRF3.5 to avoid all of this.
                            dc42 administrators @Hugsy
                            @Hugsy said in Temperature controlled LED display:
                            The main issue with doing too much in daemon.g is contention for the SD card. Using M98 causes it to open the macro file, which involve several SD card accesses.
                            Also there should be a delay command inside the while loop in daemon.g so that there are periods of time when daemon.g id not competing for resources. This delay should normally be at least 1 second, but more is better if you don't need daemon.g to react faster to changes.
