    BL "not" touching...
    439
    • zBeebleundefined
      zBeeble @zBeeble
      @zbeeble adding something to my own data, Duet2wifi, firmware 3.41
      • OwenDundefined
        OwenD @zBeeble
        @zbeeble
        My BlTouch on Duet 2 Wifi has the following configuration
        M950 S0 C"exp.heater3"                                      ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H6 F600:120 T4800 A10 S0.018 R0.5 B1         ; set Z probe type to bltouch and the dive height + speeds - turn off heaters when probing
        G31 P500 X26.2 Y-1 Z0.96                                  	; set Z probe trigger value, offset and trigger height
        EDIT
        Also have you created deployprobe.g & retractprobe.g ?
        ; deployprobe.g
        ; called to deploy a physical Z probe
        ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sat Jan 04 2020 09:46:45 GMT+1000 (Australian Eastern Standard Time)
        ;echo "deploying probe"
        M280 P0 S10 ; deploy BLTouch
        ; retractprobe.g
        ; called to retract a physical Z probe
        ;echo "Retracting probe"
        M280 P0 S80 ; retract BLTouch
        zBeebleundefined 1 Reply Last reply Reply Quote 0
        • zBeebleundefined
          zBeeble @OwenD
          @owend I have the deployprobe.g and the retractprobe.g (do I have to do anything but name the file?) for P558, can you elucidate on the parameters you have that I don't have? You have A, S, R and B
          OwenDundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD @zBeeble
            @zbeeble
            Your deploy and retract files must have the M280 commands shown above.
            M558 details are here
            • zBeebleundefined
              zBeeble @OwenD
              @owend They do have that. No comments, tho.
                Phaedrux Moderator @zBeeble
                @zbeeble said in BL "not" touching...:
                Double check that this is the pin you're actually connected to and that the wire has continuity.
                Does the BLtouch pin drop in and out when first powered up?
                If you send M401 and M402 does the pin pop in and out?
                Does your homing file use G30 for the Z homing section?
                Are the deploy and retract files in the sys folder along side config.g?
                Can you send M98 P"config.g" and post the response here?
                • zBeebleundefined
                  zBeeble @Phaedrux
                  @phaedrux said in BL "not" touching...:
                  Drops twice, red light stays on.
                  M401 -> deploys, light off.
                  M402 -> retracts, red light back on.
                  My homez.g:
                  G91               ; relative positioning
                  G1 H2 Z5 F6000    ; lift Z relative to current position
                  G1 H1 Z-205 F1800 ; move Z down until the endstop is triggered
                  G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
                  Yes. deployprobe.g contains simply
                  M280 P0 S10
                  and rectractprobe.g contains simply
                  M280 P0 S90
                  2022-08-06, 3:23:04 p.m. 	M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  • mikeabuilderundefined
                    mikeabuilder
                    Let's make sure we know what you mean by "BL Touch does not touch". This sounds like you mean that when the command to probe is given, the bed stops before getting to the probe. Is this the case? Or is the bed not moving at all?
                    Also, when connecting a new endstop (or Z probe), a good practice is to trigger the probe by hand far from the stop or probe hitting their target. For the BLtouch, move the print head out to maybe 50mm from the bed, then run zhome.g. You should see the probe deploy, then the printhead with probe moving towards the bed. Reach in and touch the probe with your finger to be sure it triggers and the print head stops moving. Now you know the probe is working, and those 50mm of space give you time to shut off the power before a crash happens if the probe is not working.
                    Is that your whole config.g? It looks like it is missing everything it needs except the networking. Did you use the configuration tool to generate a config.g? If not, you can use this to create a set of files to start with: https://configtool.reprapfirmware.org/Start
                    I use a BLTouch and in my config.g I do not configure the BLTouch as an endstop (because it will not be triggered to stop nozzle crash, like a limit switch can). In my config.g, I set up a Z probe. Here are the lines in my config.g:
                    M574 X1 S1 P"!io2.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
                    M574 Y2 S1 P"!io8.in"                         ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io18.in
                    M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
                    M558 P9 C"io7.in" H5 F120 T6000              ; set Z probe type to bltouch and the dive height + speeds
                    G31 P500 X-31 Y-2 Z2.5                          ; set Z probe trigger value, offset and trigger height
                    The pins you call out in the "S" commands in the M574, M950, and M558 will depend on your board and where you connected the probe and switches.
                    Then, in my homez.g, I don't use a G1 H1 command. This is because the touch is not an "end stop" and I got scared about whether it would work properly. How does it know to deploy the probe before starting to move? Someone here may explain it better. Instead, I use a G1 to move the probe to the center of the bed, then a simple G30 command to do the probing. G30 is a probe command and knows to deploy the probe before moving.
                    ;################;! Move the probe to the center of the bed quickly.
                    G1 X150 Y125 F6000
                    ;################;! Probe the bed and set the probe trigger point to Z=0
                    G30
                    My complete zhome is longer because it looks to see if the X and Y axes are homed and if not it calls the homex.g and homey.g files first, so when it moves to the center of the bed it knows where it it.
                    OwenDundefined 1 Reply Last reply Reply Quote 1
                    • OwenDundefined
                      OwenD @mikeabuilder
                      @mikeabuilder said in BL "not" touching...:
                      That's the problem.
                      The OP doesn't have G30, so the probe isn't told to deploy.
                      G30 calls deployprobe.g and retractprobe.g as required.
                        My homez.g:
                        G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Z-205 F1800 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                        This is the problem.
                        Remove this
                        And replace it with this
                        G1 X150 Y150 F6000
                        G30
                        This would be the same for the homeall.g file if it also has a z homing section.
                        Alter the X150 Y150 to position the probe wherever you want to set Z0. Usually the center of the bed.
                        But just to be safe, you should go through this to make sure the probe works in a controlled test first.
                        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
