    Height Map Padding
    Duet Web Control
    1.7k
    • CCS86undefined
      CCS86
      By changing this character to a 0, it collapses the text. This seems to show that the text is just trying to fill an over-sized pane:
      • CCS86undefined
        CCS86
        Okay, I think I figured out what is going on:
        • The statistics pane wants to scale vertically to match the height of the tallest pane
        • The middle heightmap pane is set to a fixed aspect ratio, so when the window is in a very wide aspect ratio, the middle pane gets very tall and forces the statistics pane too tall
        • The left pane which lists your saved height maps also auto scales height taller when the list gets long, so it can also force the statistics pane to be too tall
        Screen recording that shows the issue dynamically:
        2022-08-04-11-07-59.mp4
        I'm not sure what the cleanest solution is here. Maybe DWC could lookup the current monitor aspect ratio to decide which aspect ratio the height map pane should be.
        It would also be nice if the height map list pane was scrollable itself, instead of autosizing and forcing the other panes to be too tall to fit.
        Norderundefined 1 Reply Last reply Reply Quote 0
        • Norderundefined
          Norder @CCS86
          @ccs86
          if so then it's a case for @chrishamm who programmed the DWC, if I'm not mistaken.
          DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
          Thingiverse
            jay_s_uk @Norder
            @norder it's an issue for @Sindarius as I mentioned previously as he programmed the height map plugin
            Sindariusundefined 1 Reply Last reply Reply Quote 2
            • Sindariusundefined
              Sindarius @jay_s_uk
              @jay_s_uk I rewrote the 3D component of the heightmap plugin which replaced ThreeJS to BabylonJS which is used for the G-Code Viewer. It does come down to adjusting how the controls layout and resize in code.
              CCS86undefined 1 Reply Last reply Reply Quote 3
              • CCS86undefined
                CCS86 @Sindarius
                @sindarius said in Height Map Padding:
                Is that something you are able to change, or is it in the DWC code?
                Sindariusundefined 1 Reply Last reply Reply Quote 0
                  Sindarius @CCS86
                  @ccs86 It has to be changed in the plugin which is bundled with DWC.
                  CCS86undefined 1 Reply Last reply Reply Quote 1
                  • CCS86undefined
                    CCS86 @Sindarius
                    Is it something user editable, like a config file?
                    If not, would you be willing to push an update?
                      Sindarius @CCS86
                      @ccs86 Not user editable unless you download DWC and make the modifications yourself and make your own build of DWC. It's something I can look at but it won't be today.
                      • CCS86undefined
                        CCS86 @Sindarius
                        Just checking to see if the change made it into the new DWC release.
                          Sindarius @CCS86
                          @ccs86 I have not had time to make any changes to the heightmap at this point.
                          CCS86undefined 2 Replies Last reply Reply Quote 0
                          • CCS86undefined
                            CCS86 @Sindarius
                            Just checking in.
                            • CCS86undefined
                              CCS86 @Sindarius
                              @Sindarius said in Height Map Padding:
                              Do you think you might have time for this soon?
                                Sindarius @CCS86
                                @CCS86 I made some changes to the control that will likely be in 3.5
                                CCS86undefined 2 Replies Last reply Reply Quote 1
                                • CCS86undefined
                                  CCS86 @Sindarius
                                  Thank you!
                                  • CCS86undefined
                                    CCS86 @Sindarius
                                    Did this change make it into 3.5 beta 1?
                                    Sindariusundefined 1 Reply Last reply Reply Quote 1
                                      Sindarius @CCS86
                                      • CCS86undefined
                                        CCS86 @Sindarius
                                        Looks great, thanks!
