Magnetic Filament Sensor and Toolboard
    lilmike
    Trying to implement a magnetic filament sensor on a toolboard.
    Toolboard ID is 20, filament sensor is connected to IO1 in on the toolboard
    M569 P20.0 S0 ; physical drive 20.0 goes backwards
    M584 X0.0 Y0.1 Z0.2 E20.0 ; set drive mapping
    M591 D20 P3 C"20io1.in" S0 R70:130 L24.8 E3.0
    I get the message "Error: M591: parameter 'D' too high"
    Clearly, I have something messed up.
    When I use M591 D0 P3 C"20io1.in" S0 R70:130 L24.8 E3.0, I get the message:
    "Error: M591: Filament monitor port must be on same board as extruder driver"
    What am I missing?
    undefined 1 Reply Last reply 12 Aug 2022, 06:57 Reply Quote 0
      jay_s_uk @lilmike
      @lilmike driver numbers are the extruder number and start at 0. Change D20 to D0
      undefined 1 Reply Last reply 12 Aug 2022, 07:32 Reply Quote 0
        lilmike @jay_s_uk
        @jay_s_uk
        Tried that, not working. I have to be missing something basic.
        undefined undefined 2 Replies Last reply 12 Aug 2022, 08:54 Reply Quote 0
          jay_s_uk @lilmike
          @lilmike can you post the whole of your config
            droftarts administrators @lilmike
            @lilmike said in Magnetic Filament Sensor and Toolboard:
            To address board 20, you need a full stop between the '20' and the port, eg:
            M591 D0 P3 C"20.io1.in" S0 R70:130 L24.8 E3.0
            undefined 1 Reply Last reply 12 Aug 2022, 16:40 Reply Quote 1
              lilmike @droftarts
              @droftarts
              Thank you, it appears that was all it takes.
              I knew I was missing something simple.
              • undefined dc42 marked this topic as a question 14 Aug 2022, 15:14
              • undefined dc42 has marked this topic as solved 14 Aug 2022, 15:14
              5 out of 6
