    DWC disconnects but only whilst printing
    Duet Web Control
    712
    • digimaticundefined
      digimatic @Notepad
      @notepad
      Oh now that is interesting as I recently added another stepper and a servo for a wiper solution, and thinking about it I don't think I had this problem before then.
      There is no reason for either to be powered whilst printing, so I'll try adding something to power them down and see if that makes a difference.
        dc42 administrators @digimatic
        @digimatic what do you have the microstepping set to (M350 in config.g)? Setting microstepping too high can cause the available CPU time to be taken up by generating step pulses when moving at speed, resulting in the web server getting too little CPU time. We recommend x16 with interpolation enabled for most machines, except that extruders with low steps/mm (e.g. 100 at x16 microstepping) can benefit from x32.
        digimaticundefined 1 Reply Last reply Reply Quote 0
          digimatic @dc42
          I have everything set to x16 microstepping and interpolation, other than the coupler that has the interpolation disabled in the default E3D provided config)
          M350 E16:16:16:16 I1
          M350 C16 I10
          M350 X16 Y16 Z16 I1
          C being the coupler (this is an E3D Toolchanger)
          Recently I added:
          M350 A16 I1
          A axis being the height adjustment stepper for my Pebble Wiper
          engikeneerundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • engikeneerundefined
            engikeneer @digimatic
            @digimatic Is yours a Duet2 wifi or ethernet?
            I have had something similar happen on my e3d toolchanger with a Duet ethernet. It appears to temporarily drop connection to DWC when the XY motors are moving, so I had assumed EMI of some sort.
            I also have a paneldue attached but that seems to be okay...
            i3 clone with a bunch of mods
              @digimatic please upgrade to release 3.4.2rc2 in case the bug fixes in the wifi and Ethernet code in that release are relevant to this issue.
              If the issue persists, please post a M122 report.
                digimatic @dc42
                Updated to 3.4.2rc2. Updated DWC and the Wifi server as well just to be sure. Problem still persists.
                M122 causes my machine to reset with no output to console beforehand (tried telnet and via DWC) . Sorry how am I supposed to use M122 ?
                Also reinforcing either interference or too busy microstepping. Call me crazy but the disconnects seem to happen very much around the time of a layer change. (I don't have the slicer inserting any gcode for layer transitions)
                digimaticundefined Phaedruxundefined dc42undefined 3 Replies Last reply Reply Quote 0
                  digimatic @digimatic
                  But moving Z for example when not printing doesn't.
                    droftarts administrators @digimatic
                    @digimatic Check if your SD card is causing the problem; see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
                      Phaedrux Moderator @digimatic
                      @digimatic said in DWC disconnects but only whilst printing:
                      Are you sure you didn't send M112 by mistake? That will perform a reset.
                      EDIT: Actually, you may have been affected by this bug: https://forum.duet3d.com/topic/29577/m122-causes-reset-on-3-4-2-rc2?_=1660415932643
                        digimatic @droftarts
                        @droftarts
                        SD card checks out ok, also the 500 errors I get shouldn't be requiring reglular loads from SD, I'd say SD failure is more likely to impact loading the site pages themselves not the API server, looking at the code.
                          digimatic @Phaedrux
                          @phaedrux
                          Yes it is that bug, thanks I'll try the fixed build in pastebin so i can get the M122 output.
                            There is a bug in the Duet 2 builds of RRF that causes this. See https://forum.duet3d.com/post/292098 for fixed binaries.
