    Connectors?
    25
    7.3k
      I'm sorry, I got a digit wrong, it should have been 22-01-20x5 not 20x4.
      Edit: here is the 4-way shell on Digikey: http://www.digikey.com/product-search/en?keywords=22-01-2045
        T3P3Tony administrators
        @ianlee74:
        Also, in addition to including a connectors kit with the boards, it would be really handy if folks that sold the boards also offered bulk packs of the connectors. It would be nice to be able to pick up extras at the same time as ordering boards & other parts.
        Hi Ian
        If you would like an additional batch of connectors then drop us an email with what you had in mind and we can invoice you (won't be much) so that they go with your order.
        I will discuss with Roland about the logistical hassle of adding bulk connector packs as an additional stock item. It would save on delivery but it does add a bit of a picking and packing task for a very low value set.
        Cheers
        Tony
        • Toddimusundefined
          Toddimus
          I got some of these and they seem to work well too:
          Housings:
          http://www.digikey.com/product-search/en?keywords=WM2000-ND
          http://www.digikey.com/product-search/en?keywords=WM2001-ND
          http://www.digikey.com/product-search/en?keywords=WM2002-ND
          Crimp pins:
          http://www.digikey.com/product-search/en?keywords=WM2623-ND
            @T3P3Tony:
            @ianlee74:
            Hi Ian
            Cheers
            Tony
            How about adding "Additional Duet accessory kit" as a stock item?
            • ianlee74undefined
              ianlee74
              Thanks, David. Good to know my Digikey foo isn't as bad as I suspected.
              @dc42:
              • uk25undefined
                uk25
                I used these KF2510 connectors from Aliexpress (4-pin, 3-pin, 2-pin)… they are supplied with crimping terminals and exactly the same as Molex KK.
                There are cheaper sets, but I can't confirm their quality.
                • Huguesundefined
                  Hugues
                  What is the male connector reference for the extansion board, i plan to wire my external driver to it but i only find some connector with ribon cable.
                  Thanks !
                    If you want the full 50 ways then this one looks suitable to me http://uk.farnell.com/amphenol-fci/65846-012lf/connector-receptacle-50-position/dp/1924648?aa=true&vw=&selectedCategoryId=&categoryId=700000005017&eq=N%3D203442%2B110049686%2B110178988%2B113176173%2B113190048%2B2031%26amp%3BNs%3DP_STORE_MARKETING_RANK_FARNELL_UK%257c0%257c%257cP_MAN_PART_NUM%257c0%26amp%3BNtpc%3D1%26amp%3BNtpr%3D1&searchView=table&iscrfnonsku=false. I have previously used similar connectors with fewer positions to connect wires to the expansion connector.
                    • Jamesundefined
                      James
                      Some motors and printer kits come with JST XH style connectors. I can tell you that if you use a dremel to sand off the JST XH locking protrusions, and switch which holes the wires are in, the JST XH will fit onto the Molex KK connector.
                      But, some of you are probably cringing right now. I am too a bit. So, are there connectors you can buy to convert JST XH 2S and 3S to the appropriate Molex KK? I looked a bit and didn't see any.
                      Sort of a silly issue, since I know the board comes with the pins and connectors, but I just don't trust my crimping ability. I've already sheared the wire in half a couple times. But, while that is annoying, at least you know you did it. It's invisible errors that worry me.
                      James
                      • Knaudlerundefined
                        Knaudler
                        Hello
                        yes sand off the JST works. thanks
                        now I get a new crimping tool for jst, molex kk usw….
                        that looks better.
                        would be nice to buy finished Molex KK to jst (6-pin) Cables (1m) for Steppers
                        and 2-pin , 3-pin for other things
                          You can buy JST to DuPont stepper cables from suppliers such as Robotdigg, and they will fit the Molex KK connectors, with the disadvantage that they are not polarised and don't lock in place. However, the pinouts of JST connectors on stepper motors are not standardised, so you may have to swap pins around in the Dupont shell like I had to.
                          • Knaudlerundefined
                            Knaudler
                            Hello
                            with this cheap Crimping tool it works
                            looking for: IZOKEE Crimpzange
                            last night I tundes my CR-10 with duet wifi - with original Case - works
                            works great - using the ext. Mosfet from CR-10
                            the printer is no Silent - great
                            and works up to 300MM/sec !!!
