Connectors?
25
7.3k
    RCarlyle
    That style Ultimachine is selling is pretty good, it's basically the same as the standard Dupont 0.1" housings but with locking tabs. I also like Molex KK though.
    My only real problem with the Dupont style is the variability of fit. If you get smallish header pins (like RADDS comes with) and largish female crimps, it ends up super loose and there isn't much you can do about it.
      I find it much easier to remove pins from the Molex shells than from the Dupont shells. I also find that the Molex crimp connections are 100% reliable, whereas with Dupont crimps I get the occasionally invisible bad crimp connection. But that may just mean that my crimp tool fits the Molex crimp pins better.
        ianlee74
        @dc42:
        They are Molex KK connectors. The shells are part number 22-01-20x4 where X is the number of pins, and the crimp pins are 08-50-0032. Compatible JST connectors are also available.
        Does someone have the DigiKey links for these parts handy? I'm not coming up with an "20x4" variant - only "20x7". Maybe my DigiKey foo is not up to the task today 😞
        Also, in addition to including a connectors kit with the boards, it would be really handy if folks that sold the boards also offered bulk packs of the connectors. It would be nice to be able to pick up extras at the same time as ordering boards & other parts.
        Thanks!
          I'm sorry, I got a digit wrong, it should have been 22-01-20x5 not 20x4.
          Edit: here is the 4-way shell on Digikey: http://www.digikey.com/product-search/en?keywords=22-01-2045
            T3P3Tony administrators
            @ianlee74:
            Hi Ian
            If you would like an additional batch of connectors then drop us an email with what you had in mind and we can invoice you (won't be much) so that they go with your order.
            I will discuss with Roland about the logistical hassle of adding bulk connector packs as an additional stock item. It would save on delivery but it does add a bit of a picking and packing task for a very low value set.
            Cheers
            Tony
              Toddimus
              I got some of these and they seem to work well too:
              Housings:
              http://www.digikey.com/product-search/en?keywords=WM2000-ND
              http://www.digikey.com/product-search/en?keywords=WM2001-ND
              http://www.digikey.com/product-search/en?keywords=WM2002-ND
              Crimp pins:
              http://www.digikey.com/product-search/en?keywords=WM2623-ND
                @T3P3Tony:
                @ianlee74:
                Hi Ian
                Cheers
                Tony
                How about adding "Additional Duet accessory kit" as a stock item?
                  ianlee74
                  Thanks, David. Good to know my Digikey foo isn't as bad as I suspected.
                  @dc42:
                    uk25
                    I used these KF2510 connectors from Aliexpress (4-pin, 3-pin, 2-pin)… they are supplied with crimping terminals and exactly the same as Molex KK.
                    There are cheaper sets, but I can't confirm their quality.
                      Hugues
                      What is the male connector reference for the extansion board, i plan to wire my external driver to it but i only find some connector with ribon cable.
                      Thanks !
                        If you want the full 50 ways then this one looks suitable to me http://uk.farnell.com/amphenol-fci/65846-012lf/connector-receptacle-50-position/dp/1924648?aa=true&vw=&selectedCategoryId=&categoryId=700000005017&eq=N%3D203442%2B110049686%2B110178988%2B113176173%2B113190048%2B2031%26amp%3BNs%3DP_STORE_MARKETING_RANK_FARNELL_UK%257c0%257c%257cP_MAN_PART_NUM%257c0%26amp%3BNtpc%3D1%26amp%3BNtpr%3D1&searchView=table&iscrfnonsku=false. I have previously used similar connectors with fewer positions to connect wires to the expansion connector.
                          James
                          Some motors and printer kits come with JST XH style connectors. I can tell you that if you use a dremel to sand off the JST XH locking protrusions, and switch which holes the wires are in, the JST XH will fit onto the Molex KK connector.
                          But, some of you are probably cringing right now. I am too a bit. So, are there connectors you can buy to convert JST XH 2S and 3S to the appropriate Molex KK? I looked a bit and didn't see any.
                          Sort of a silly issue, since I know the board comes with the pins and connectors, but I just don't trust my crimping ability. I've already sheared the wire in half a couple times. But, while that is annoying, at least you know you did it. It's invisible errors that worry me.
                          James
                            Knaudler
                            Hello
                            yes sand off the JST works. thanks
                            now I get a new crimping tool for jst, molex kk usw….
                            that looks better.
                            would be nice to buy finished Molex KK to jst (6-pin) Cables (1m) for Steppers
                            and 2-pin , 3-pin for other things
                              You can buy JST to DuPont stepper cables from suppliers such as Robotdigg, and they will fit the Molex KK connectors, with the disadvantage that they are not polarised and don't lock in place. However, the pinouts of JST connectors on stepper motors are not standardised, so you may have to swap pins around in the Dupont shell like I had to.
                                Knaudler
                                Hello
                                with this cheap Crimping tool it works
                                looking for: IZOKEE Crimpzange
                                last night I tundes my CR-10 with duet wifi - with original Case - works
                                works great - using the ext. Mosfet from CR-10
                                the printer is no Silent - great
                                and works up to 300MM/sec !!!
