    Duet3D USB connection is not working
    Using Duet Controllers
    555
      Phaedrux Moderator @jay_s_uk
      @jay_s_uk said in Duet3D USB connection is not working:
      @phaedrux @Marethyu bossa doesn't work with a duet 3 mini 5+. you need to double tap the reset button to make a USB drive appear. then drag the .uf2 file over, which will cause it to reboot
      Thanks for the catch!
      • Marethyuundefined
        Marethyu
        The Duet 3 mini 5+ has no reset jumper only a reset button.
        I also tried double tapping the reset button, but this didn't change anything and COM-port is still not showing up.
          jay_s_uk @Marethyu
          @marethyu it doesn't show as a com port, it shows as a folder, like a usb drive
            droftarts administrators
            @marethyu for manual Mini 5+ firmware update, see https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#duet-3-mini-5-wifiethernet
            • Marethyuundefined
              Marethyu
              @jay_s_uk no matter what I do, neither a COM port nor a folder is displayed.
              The only two things that work reliably are the 5V and 3.3V LEDs.
              @droftarts I've already read that, but it can't be executed because I can't get a working connection to the board.
                droftarts administrators @Marethyu
                @marethyu Is there any way you can confirm that your USB leads are definitely data leads? Many USB leads sold are power only. Is there any damage to the USB port on the Duet?
                It is strange that the STATUS LED is off, not flashing or pulsing. If you double click the reset button does it pulse from bright to dim and back again, even though it doesn't show up on the desktop?
                • Marethyuundefined
                  Marethyu
                  As I wrote before I tried different ports, cables and computers without any effect.
                  The USB cable I use now was previously used for data transfer and it worked perfectly. So I'm sure it's a USB data cable.
                  I can't see any damage to the Duet's micro USB port. I also compared the USB port of the Duet with the micro USB port of a Raspberry pi, but can't find any differences.
                  The STATUS LED does not light up, blink or pulse when I connect the board to the computer. When I double tap the reset button nothing happens.
                    @marethyu Okay, I think we need to replace the board under warranty. How long ago did you purchase the board from RatRig?
                    • Marethyuundefined
                      Marethyu
                      I bought the board in February 2022.
                        Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
