    DuetWifi 2 and LIS3DH wiring
    28
    4.4k
      dc42 administrators @nick9one1
      @nick9one1 see https://duet3d.dozuki.com/Wiki/Gcode#Section_M955_Configure_Accelerometer. The default SPI frequency used to be 4MHz in 3.3beta3 but is 2MHz in 3.3RC2.
      • nurooundefined
        nuroo
        @nick9one1
        Thank you for posting your questions and asking for help interpreting the instruction for using this sensor with duet2 board. Some pinout diagrams differ in pin names then instructions. This made the instructions confusing to me.
        "On Duet WiFi, Duet Ethernet and Duet Maestro all the SPI CS pins have interrupt capability, so you can use any two spare CS pins on the daughter board connector. For example, on a Duet WiFi or Duet Ethernet you could connect the accelerometer CS pin to SPI.CS3, and the INT1 pin to SPI.CS4. [Note: if you already have one daughter board plugged into the main board and you wish to connect to SPI.CS3 and SPI.CS4 on the top of that daughter board, the daughter board passes SPI.CS3 and SPI.CS4 to the pin positions directly above the SPI.CS1 and SPI.CS2 pins on the main board. This is so that a second daughter board stacked on top automatically uses SPI.CS3 and SPI.CS4 instead of SPI.CS1 and SPI.CS2.] Use this command to tell RRF about the accelerometer:"
        Anyway your updated diagram is gold. Something like it should really be included in the instructions.
        Until reprap has something as informative - these two videos using it with klipper helped me understand the concepts and practical uses of using an accelerometer on your 3d printer:
        https://youtu.be/OoWQUcFimX8
        https://youtu.be/IezqWVZZ_iI
        Hopefully I can get this specific sensor by the time 3.4 is released.
        • nurooundefined
          nuroo
          This post got me up and running on a railcore. Had to change some pins in config setup to use daughter board spi. Im getting data thru the plugin as well. Looking forward to rrf 3.4
          • muleundefined
            mule
            Just a quick info:
            The picture of the adafruit LIS3DH on https://duet3d.dozuki.com/Wiki/Accelerometers is misleading because the V3.3 from the duet is connected to 3Vo (Output) instead of the VIN (Input) pin. Maybe it is better to remove it.
            droftartsundefined 2 Replies Last reply Reply Quote 1
              droftarts administrators @mule
              @mule Thanks. Do you mean this one? https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/Y1YiEWyeIEP5qi4Q
              I see what you mean. I'll try and get @dc42 to take another picture. For now I'll put a note on the page.
                @mule From @dc42:
                connecting +3.3V from Duet to 3V0 is correct. In practice, connecting it to Vcc works too.
                Connecting to Vcc would be necessary if we were using 5V supply
                So I'll leave as is.
                • muleundefined
                  mule
                  For me it did not work to connect +3.3V from duet to the output of the adafruit board. Maybe there are different boards with different layouts being sold by adafruit?
                  nick9one1undefined 1 Reply Last reply Reply Quote 0
                  • nick9one1undefined
                    nick9one1 @mule
                    Glad my diagram helped!
                    I never got it working on the Duet2 WiFi, but have recently upgraded to a 3 Mini 5+ and trying again...
                    https://forum.duet3d.com/topic/25904/mini-3-5-and-lis3dh-wiring/2
                    • MrTundefined
                      MrT
                      HI , I also have a duet wifi2 and just got my self an LIS3DH to try out, I was wondering if it was possible to use other pins then the temp board pins as it is in use already .
                      I do not use a screen or so .
                      thanks in advance for the help
                      Best Regards
                      Manuel
                        jay_s_uk @MrT
                        @mrt no, you need to use hardware SPI pins. You can however use an accelerometer and 1 temp daughterboard. Just use the CS2 and CS3 pins
