    Mistake True bed levelling G32
    2.1k
      jay_s_uk @A Former User
      @sgk well when the tool is at X0, is it nearest the motor called "left z stepper" or is it closest to the one called "right z stepper"?
        A Former User @jay_s_uk
        @jay_s_uk to the left
        jay_s_ukundefined 1 Reply Last reply Reply Quote 1
          @sgk which indicates that the firmware setup is correct then and its left to either be a mechanical issue, e.g. x axis twist or maybe the IR probe doesn't like being so close to the edge of the bed
          A Former User? 2 Replies Last reply Reply Quote 0
            @jay_s_uk
            the impression that I have is that each time I do g32 the bed does not get level and it always goes down more and more on the side
              @jay_s_uk I could make a video to better understand
                @sgk which is why i think you have the stepper motors the wrong way round
                  @jay_s_uk but when I do home all the 2 z motors go well together they are synchronized
                    @sgk if you have them mapped the wrong way round, RRF will adjust the wrong one
                      @jay_s_uk I could solve this problem how do you have an idea please
                        @sgk change your z mapping in M584 from Z3:4 to Z4:3
                        A Former User? 3 Replies Last reply Reply Quote 0
                          @jay_s_uk
                          ha ok i will try now thank
                            @jay_s_uk I have this as an error
                            Error: Z probe readings not consistent
                                @sgk says it all really. the z probe readings are the same within the tolerance band thats set. I'm not sure how good the IR probe is with PEI surfaces
                                  @jay_s_uk with the duet 2 card I never had a problem with the pei
                                    @sgk 🤷
                                      @jay_s_uk merci pour tout jay_s 👍
                                        @jay_s_uk if I change this parameter by this him the
                                        M558 P8 C"io2.in" A2 H5 F120 T15000
                                        A5
                                          A Former User @A Former User
                                          @sgk
                                          I found the problem because of daylight, I don't know why with duet 2 it never does it to me and with duet 3 it does it to me. but even if I put a white sheet on the pei it does it do the same error.
                                            @sgk IR probes aren't great with direct sunlight
