Mistake True bed levelling G32
@sgk which is why i think you have the stepper motors the wrong way round
@jay_s_uk but when I do home all the 2 z motors go well together they are synchronized
@sgk if you have them mapped the wrong way round, RRF will adjust the wrong one
@jay_s_uk I could solve this problem how do you have an idea please
@sgk change your z mapping in M584 from Z3:4 to Z4:3
@jay_s_uk
ha ok i will try now thank -
@jay_s_uk I have this as an error
Error: Z probe readings not consistent -
@sgk says it all really. the z probe readings are the same within the tolerance band thats set. I'm not sure how good the IR probe is with PEI surfaces
@jay_s_uk with the duet 2 card I never had a problem with the pei
@sgk
@jay_s_uk merci pour tout jay_s
@sgk
I found the problem because of daylight, I don't know why with duet 2 it never does it to me and with duet 3 it does it to me. but even if I put a white sheet on the pei it does it do the same error. -
@sgk IR probes aren't great with direct sunlight
@jay_s_uk
even with a white sheet. What can you advise me specifically? -
@sgk i've never got on with them when i've tried them
@jay_s_uk and what probe do you have?
@sgk on my machines now I use Euclid probes https://euclidprobe.github.io/ that can be picked up when used.
I have in the past used BFPtouches https://www.thingiverse.com/thing:2890290
I'm not a fan of normal bltouches as they seem to cause too many issues for people.
inductive can be good but you need to be able to adjust for temperature affecting the readings -
@jay_s_uk I agree with you the ones I had before I had bltouch and I also had only problems he only had the ir that it was fine but now that I am in duet 3 only problems too
