Problems with homing the x-axis
Hello everyone
I have a problem with my printer / duet board.
Suddenly (after 1,5 years working perfectly) it is not possible to home the x-axis.
If I send the command, the printer head is moving just a small distance right and left (along the x-axis) from its position. The distance is about 1 or 2 cm. Also there is a strange noise.
During that failed homing process, the duet shows the following message:
G28 X
Warning: motor phase B may be disconnected reported by driver(s) 0I have checked the stepper motor for a mecahnical failure. But the stepper seems to be ok.
Can you help me and give me some advice? How can I check wether the On-Board Driver on the Duet Board is defective?
I use a DuetBoard 2 (Ethernet) with firmware version 3.2.1
Please tell me, if i should post any further information
@heinrich-platau fully check the wiring for your motor.
use a multimeter so you can verify each of the coils -
You are right!! Problem solved!
I thought about the worst case but I'd better check the most obvious error.
Thread can be closed!
